Overclock.net › Forums › AMD › AMD CPUs › 4350 or 6300?
4350 or 6300?
post #1 of 9
Currently I am on Athlon X3 455 with MSI 970 Gaming mobo with AC Frezer A30 cooler.
They cost the same (3€ are between them) but the 4350 has higher clocks out of the box on the other hand it has less cores.
6300 has more cores and lower clock out of the box but it should be able to reach 4,2 GHz easily enough. I had the 6300 before and it run at 4,3 GHz without any problems.
Is it possible that I could reach higher frequency with the 4350? This is mainly a gaming rig and games will benefit more from the increased clock speed than from the 6 cores at lower speed.
What are your experiences with overclocking this CPUs? Which one you think I should get?
post #2 of 9
Get the 6300 recent games can use more than 4 cores and ocing helps aswell but in games that need singlethread better a higher frequency but amd isnt good for singlethread
post #3 of 9
6300
post #4 of 9
6300 isn't that hard to OC on a decent board, 4350 might go a bit higher.
If you mostly play games where you feel your cpu single thread performance is holding you back you might consider a g3258 and OC that.
If you game games that need more than 2 cores, then you might as well get the 6 core for supreme multi core performance. (edit: or want to do some sort of heavy multitasking stuff)
g3258 vs 4350 are very close in multicore performance at same clocks. (at least in the ~4 thread range c;)
edit: I rather appreciate this chart http://www.overclock.net/t/1493307/relative-access-to-execution-throughput-comparison-chart
edit: also just throwing that out there but a great deal of games run perfectly fine on AMD with a little OC, if you game on 60hz monitor, even the most poorly coded games. unless it's an MMO where 100 dudes stand around on the same spot, and the game uses 1 thread only. Or Arma3. Though these would still be playable.
Edited by Tivan - 1/10/15 at 5:13pm
Cute PC
(15 items)
4930k@4200 Sabertooth x79 R9 290 Tri-X@950/1250 4x4GB@2133CL9
Hard DriveCoolingOSMonitor
Crucial BX100 Mugen 4 Win7 Benq xl2411z
NEC EA231WMi QPad-MK50 (reds) Seasonic S12G 750 Define R4
MouseMouse PadAudio
Deathadder 3.5G BE Razer Goliathus Speed Edition Large Onboard
Cute PC
(15 items)
MouseMouse PadAudio
post #5 of 9
Ma Rig...
(19 items)
AMD FX 8320 @ 4.42Ghz  Gigabyte 990XA-UD3 Rev.3 AM3+ Inno3D HerxuleZ X2 GTX 970 4GB GGDR5 HyperX FURY 16 GB White DDR3 @ 1866Mhz
256GB Samsung 840 Pro SSD  WD 3.5" 1TB Hitachi 3.5" 500GB  WD 3.5" 250GB
Optical DriveCoolingOSMonitor
Samsung 18x DVD ROM Sata Cooler Master Hyper Evo 212 (x2 120mm fan P&P) Windows 8.1 Professional 64Bit Samsung S24D300HS 24"
Samsung S24B150BL 24"  MechanicalEagle Z-77 87 Key OCZ StealthXStream ii 600w Vaporise V9 Blue Mid ATX Case
MouseMouse PadAudio
Logitec G302 Daedalus Prime Razer Goliathus Speed Edition Medium Corsair Raptor HS40 7.1
Intel Core i7 2600 @ 3.4Ghz Intel DQ67SW LGA 1155 MSI GTX 1070 ARMOR OC 8Gb GGDR5 Corsair XMS 20Gb's DDR3 @ 1333Mhz
Hard DriveHard DriveHard DriveCooling
256GB Samsung 840 Pro SSD  240GB Kingston UV400 SSD 1TB WD + 500GB WD Zalman CNPS5X Performa
OSMonitorMonitorKeyboard
Windows 7 Home Premium 64bit LG 29" 29UM58-P IPS 21:9 Ultrawide  LG 22" 22M47VQ IPS MOTOSPEED Inflictor CK104
PowerCaseMouseMouse Pad
Aerocool Integrator 500W AvP Viper Black Mini Tower  Logitech G402 Hyperion Fury Razer Golothus Speed
Audio
Corsair HS40 + Logitec Z333 Speakers + Sub
Ma Rig...
(19 items)
MouseMouse PadAudio
Audio
post #6 of 9
Kukumonster
A pleasant surprise :)
Cooler Master USP 100 Black Edition
Value redefined.
Amd Athlon II X3 435
Core i5 2320 Intel DH67BL Sapphire R9 285 Corsair 8GB (4x2)
Kingston HyperX Fury 240GB  WD Blue 1TB Seagate Barracuda 500GB Noctua NH-C14S
CoolingOSMonitorPower
Noctua NF-A140*2 Windows 10 Pro (TP) LG 22" 1080p  Seasonic G-550 F3 550W
Cooler Master USP100 Black Edition
Kukumonster
Value redefined.
post #7 of 9
Unlock the 455 and call it a day, or stretch your cash when you can and go FX8***.
I have the x3 445 in my son's rig running as an x4 propus @ 3.6 (limited by the board's non-cooled VRM's)
It does surprisingly well with a 7950. Not sure if the MSI 970 has ACC or any other features capable of unlocking the chip though, I would assume so.....
The 6300 would also be a decent CPU for you too, but the 4 actual cores (if you can use them all) on your x3, will destroy a 4350 since those chips use 2 modules, with two less efficient "semi-cores" on each module.
Edited by Agent Smith1984 - 1/11/15 at 7:08am
Daddy's Gamer
(15 items)
Son's Gamer
PROJECT WIFEY
(11 items)
FX-9590 @ 5GHz Asus 990FX Sabertooth Rev 2.0 MSI Gaming 390X G. Skill Trident X 4x4GB
Hard DriveHard DriveCoolingOS
Samsung 850 EVO 250GB Seagate Barracuda 1TB SATA 3  LEPA 240AC Windows 10 x64 Pro
LG 55UB8500 55" 4K 3D TV Logitech MK350 Rosewill HIVE 850 NZXT S340
MouseMouse PadOther
Logitech G700s Aukey Smooth 36" Gaming Pad Logitech Driving Force GT
AMD Phenom X6 1065T @ 4GHz - 1.45v MSI 970 Gaming XFX DD 7870 Black Edition @ 1200/1500 G. Skill Trident-X 8GB
ADATA SP550 240GB SSD Lite On 24x DVD  Corsair H80i Windows 10
MonitorPowerCase
46" 1080P LED TV Raidmax RX850 Apevia X-Dreamer 3 Pink
Daddy's Gamer
(15 items)
Son's Gamer
PROJECT WIFEY
(11 items)
MouseMouse PadOther
MonitorPowerCase
post #8 of 9
The 6300 would be my choice. If your budget was a smidge more, consider an 8320. If not, the 6300 would be ideal.
post #9 of 9
6300 for sure lol. I've had a few of these chips and I think it's the best AMD has to offer overall.
  Back to Forum: AMD CPUs
