Overclock.net › Forums › Components › Monitors and Displays › 2560x1080p HELP
2560x1080p HELP
post #1 of 9
I recently purchased two lg 29" ultrawide 21:9 2560x1080p monitors and i cant get one of them to display in 2560x1080p no the display on both look identical but when i go on the settings it says that display 1 is 1920x1080p and display 2 is 2560x1080p Now it wont let me change the resolution on display 1 it says 1920x1080p recommended resolution. I tried reinstalling the driver of my gpu and nothing ive tried preety much everything now the wall paper on the display 2 looks blurry a little and it looks oerfevtly fine on display 1 weird? What can i do to change the resolution to 2560x1080p
post #2 of 9
These are daisy chained DisplayPort?
Skylake Is Here!
(17 items)
Intel i7 6700K Batch #L535B021 4.7Ghz @ 1.296V GIGABYTE G1 Gaming GA-Z170X-Gaming 7 EVGA Geforce GTX 970 SSC ACX 2.0+ G.SKILL TridentZ 16GB DDR4 3000
Hard DriveHard DriveHard DriveCooling
Samsung 950 Pro M.2 512GB  Crucial BX100 250 GB SanDisk SSDPlus 240 GB NZXT Kraken X61
OSMonitorKeyboardPower
Windows 8.1 & 10 Dell UltraSharp 2913WM 21:9 2560x1080 Ducky Shine 4, CODE WASD, Deck Legend, G710+ EVGA SuperNova G2 850W
CaseMouseMouse PadAudio
Phanteks Enthoo Evolv ATX Mid-Tower Ducky Secret SteelSeries Fostex Purple Heart TH-X00
Audio
AKG K553 Pro, Philips SHP9500, Superlux 668B, S...
Skylake Is Here!
(17 items)
Audio
post #3 of 9
Well the one thats not displaying 2560x1080p am using a mini display port to hdmi adapter but monitor 2 is straight hdmi
post #4 of 9
What is the model number of the monitor?
Skylake Is Here!
(17 items)
Audio
Skylake Is Here!
(17 items)
Audio
post #5 of 9
29um57
post #6 of 9
Try two HDMI cables if your video card has an extra HDMI port. On my monitor if I connect to HDMI with DisplayPort also connected the DisplayPort gets override and only signal comes from the HDMI port. Maybe you might need a splitter or something.
Skylake Is Here!
(17 items)
Audio
Skylake Is Here!
(17 items)
Audio
post #7 of 9
Thats weird because am using two hdmi cables but sincey gpu only has one hdmi i used a mini display to hdmi and plugged an hdmi cable to it. It makes no sense
post #8 of 9
I just bought a 29um67p as well and I had a similar issue. IT wouldnt let my select 2560x1080 no matter what I did. HDMI, DisplayPort, wiping drivers. Turns out, it was the custom bios my 7950 was running. Once I switched back to the stock bios, it was right there in the screen settings.
Sucks though cuz now my GPU runs about 10c hotter.
post #9 of 9
Ill check that out when i get home tonight i mean i havent overclocked or ran any custom.bios on my.gpu but i can check thanx.
  Back to Forum: Monitors and Displays
