Overclock.net › Forums › Components › Mice › 3366/3360 vs. 3310
3366/3360 vs. 3310
post #1 of 20
So I've been hearing a lot of hype about the 3366/3360 sensor but I still don't know exactly why it's an upgrade over the 3310. Can anyone explain to me the reasons why the 3366/3360 is so hyped?
post #2 of 20
less variance, lower latency, higher cpi, less jitter on higher cpi steps, higher fps
post #3 of 20
Thanks for the clarification, though isn't higher CPI (or DPI) the same thing as higher FPS?
post #4 of 20
no
post #5 of 20
Feel free to flame or correct me if I'm wrong, but think of CPI as sensor resolution, the ability of it to detect an image shift when the sensor position on the surface has changed and how much shift is required for it to register a 1 pixel movement change. Think of interpolation (A CPI higher than the hardware capabilities of the sensor) as zooming in so much that you lose focus and the image gets blurry and you have to post-process the image to help clean up the noise that is created by lack of image precision and clarity, which ruins the feel of the tracking.
Then think of *FPS* as how FAST a sensor is capable of repeatedly capturing an image and updating it. You can have a low resolution sensor (e.g. 800 CPI max) and have a sensor operate at 12000 FPS, so even though the internal resolution is low, it will operate instantly and with no lag or delay--it will just require more "movement" to register a 1 pixel change.
SB Rig
i7-2600k Gigabyte P67A-UD5 B3 R9 290X 16GB
WD 2 TB, WD 1 TB, 250gb Liteon ihbs212 blu-ray burner/reader XP+W7 Benq XL2720Z
Ducky Shine 69/Year of the Goat/Shine 5 Seasonic Platinum X1000 Corsair 760T Logitech G502 with r0ach approved ™ sensor
Mouse Pad
Puretrak Talent
SB Rig
Mouse Pad
Puretrak Talent
post #6 of 20
Wow thanks for the explanation, this makes it much easier to understand. As for the 3366/3360, do they also interpolate the higher DPI steps? And do they have a "native" step in-which tracking works best on?
post #7 of 20
3360/66 doesn't really have native steps, they are all equally good, but it's a good idea to stay under 1600-2000 (because no one needs more, end of story).
post #8 of 20
To me, 3366 feels more alive ,more "lethal" , yet less consistent. I have to be in the zone in order to take advantage of the sensor.
3310 is more forgiving ,easier to move around, more consistent, less raw.
If I had to use an expression, 3310 is easier to pick up and get you going, 3366 can allow you to reach greatness.
First Build
(16 items)
Secondary Rig
Intel Core 2 Duo E7400 @ 3.41GHz Gigabyte GA-P31-ES3G Galaxy 9800GT  A-Data 2x2GB DDR2 840Mhz OC
Samsung 140GB 7200RPM Standard one Stock Intel Heatsink Windows 7 Ultimate 64-bit
15.4 Dell HP CoolerMaster 460W Elite Foxconn ZL-142A
Mouse
Microsoft Laptop
i7-3930k GIGABYTE GA-X79-UD4 EVGA GTX 780 ACX  EVGA GTX 780 ACX
RAMHard DriveHard DriveCooling
CORSAIR Vengeance 16GB (4 x 4GB) 1600MHz WD Blue WD10EZEX 1TB Sata III Crucial M4 128GB Sata III SSD Corsair H100i
PowerCase
SeaSonic X Series X-850 NZXT SWITCH 810 White
First Build
(16 items)
Secondary Rig
Mouse
Microsoft Laptop
PowerCase
post #9 of 20
There is a difference between the two - you have to use them to experience it.
I have both 3310 and 3366/3360 mice and you can notice the difference when playing games like DOTA 2. The 3310 mice is more picky with surfaces though - it actually made me buy a new mouse pad to use it correctly .
Edited by Peter Nixeus - 4/28/16 at 1:10pm
My Girlfriend #3
(15 items)
AMD FX-8350 4.0GHz 8-Core Processor Gigabyte 970A-UD3H XFX AMD Radeon RX 480 8GB OC Black Edition GSkill Sniper 8GB DDR3
Hard DriveHard DriveCoolingOS
Crucial MX100 128GB SSD Toshiba 2TB 7200RPM HDD NZXT Kraken X41 Water Cooler Windows 8.1 Pro
NX-VUE24 Freesync 144Hz Gaming Monitor Nixeus MODA v2 Mechanical Keyboard - Brown Swit... Enermax Triathlor 550W Modular PSU NZXT S340
MouseMouse PadAudioAudio
Nixeus REVEL PMW3360 Gaming Mouse ROCCAT SENSE Nixeus ARC 4.0 Bluetoth Speakers (Prototype) Nixeus Rival Headphones (Prototype)
Intel i5-3570K Gigabyte H77N-Wifi Mini-iTX Gigabyte Windforce Nvidia GTX 670  Corsair Vengeance 8GB DDR3 1600
Samsung 830 SSD 128GB Seagate Barracuda 1TB 7200RPM NZXT Kraken X31 Water Cooler Windows 8.1
Nixeus Vue 27" IPS LED 2560x1440 DisplayPort MA... Nixeus MODA Mechanical Keyboard - Brown Switch ... Enermax Triathlor 550W Modular PSU Cool Master Elite 130 Mini-iTX Case
MouseMouse PadAudio
SteelSeries DOTA 2 Rival Mouse SteelSeries QcK Nixeus Earphones ER-BKSL14
AMD Phenom II X4 965 Processor Black Edition MSI 870A-G54 XFX AMD Radeon 7850 1GB Corsair XMS DDR3 8GB
Seagate Barracuda 2TB 7200RPM LG CD/DVD Combo Drive Antech H20 950 Khuler Windows 7 Ultimate
Nixeus Vue 27" H-IPS 2560x1440 WQHD Monitor NX... Nixeus MODA Mechanical Keyboard - Brown Switch ... OCZ Fatal1ty Modular 550 Watt Modular PSU Roswill Challenger-U3 Mid-Tower ATX Case
Mouse
Gigabyte M6800
My Girlfriend #3
(15 items)
MouseMouse PadAudio
Mouse
Gigabyte M6800
post #10 of 20
Talking from a neutral perspective since I'm dumb and don't know anything technical, I feel the 3366 is just more snappy/responsive. Think DA 2013/chroma, minus the synapse interfering. I generally have to move the mouse less, to achieve more. While with the 3310, I kinda need to give more effort if I want to be precise, even at the same DPI. This just feels smooth and powerful.
imo the difference between the 3366 and the 3310 is not groundbreaking, specielly the Zowie ones, but it still IS better, but not worth it if you don't feel comfortable with the shape/features of the mouse you're getting, just because of the sensor.
Rather have 3310 comfortable mouse, than a 3366 heavy lifting brick.
  Back to Forum: Mice
