Overclock.net › Forums › Components › Power Supplies › 2004 PC ; Can it start a fire ?
post #1 of 6
Hello !
I have this 2004 computer : mainboard MSI 865PE neo2v , processor pentium 4 3,2 mhz northwood , kingston memory DDR1, Maxtor HDD 200gb PATA133 and I think a noname psu SIRTEC.
If I change the psu with a good one , can I use the pc withought risk of fire ?
I will be using 24/7 non stop at a selling point , is there any risk of fire from the other components ?I wown't overclock anything .
Thank you ,
1440p RIG
(11 items)
Intel 3570K GA-Z77X-UD4H MSI 390  16 GB Corsair
INTEL SSD 520 120GB& WD 1TB BLACK N/A THERMALRIGHT MACHO Windows 10
MonitorPowerCase
DELL U2713HM Corsair RM650i (got from RMA) NZXT H2
1440p RIG
(11 items)
MonitorPowerCase
post #2 of 6
The PSU is really the only risk of a fire. But, even in 2004, power supplies had failure protection built in. I've never heard of a PSU fire other than someone running way too much off a low power, cheap PSU. Stay within the specs and you should be fine, or replace it with a new $40 on sale special.
post #3 of 6
A question , I want to buy this psu http://www.corsair.com/en-us/cx-series-cx450m-450-watt-80-plus-bronze-certified-modular-atx-psu-na . It has ATX : ''Supports ATX12V 2.4/2.3/2.2/2.01 and EPS12V 2.92 standards''
Would it be ok if my mainboard is ATX 1 and CPU pins are JPW1 ?
Thank you .
1440p RIG
(11 items)
MonitorPowerCase
1440p RIG
(11 items)
MonitorPowerCase
post #4 of 6
Thank you .
It should since the Corsair has a 20+4 pins cable and 4 pins EPS cable. To be sure check the pinout of the Corsair PSU, but i'm pretty sure it fits.
Edited by TUFinside - 7/13/16 at 4:56am
post #5 of 6
I'm sure it fits , problem is if there is any problem if the specs differ ATX 1 to other Atx. Speaking of fire or something .
1440p RIG
(11 items)
MonitorPowerCase
1440p RIG
(11 items)
MonitorPowerCase
post #6 of 6
... If I change the psu with a good one , can I use the pc withought risk of fire ? ...
Yes. But check that the capacitors in that aging mobo ain't bloated/oozing.
Would it be ok if my mainboard is ATX 1 and CPU pins are JPW1 ? ...
Yes, no problem.
HAL-9011
(14 items)
Phenom II 960T X6 4.1GHz ASUS M4A89GTD Pro Radeon HD 6870 16 GB DDR3 1600MHz 8·8·8·24
OCZ Vertex 4 128GB OCZ Vertex 2 120GB WD Caviar Black 1TB LG DVD-RW
CoolingCoolingOSOS
Noctua NH-D14 Accelero S1 R.2 + 2x NF-F12 Se7en x64 Se7en x32
PowerCase
Antec TP-650W CM HAF 912 +
HAL-9011
(14 items)
CoolingCoolingOSOS
PowerCase
  Back to Forum: Power Supplies
