Overclock.net › Forums › Graphics Cards › AMD/ATI › 390X or 480?
390X or 480?
post #1 of 22
I'm looking to get a new video card in the next couple of months and am having trouble deciding which one to get. I've narrowed it down to these two cards, but wanted some more input on those that are current with these gpus.
I plan on eventually adding a second card for CF, so that has me leaning towards the 480. But, after comparing benches of the cards the 390x appears to be superior in every way, sans heat and power consumption.
What would you pick in my situation? Thanks.
edit: I am at 1440p
post #2 of 22
1) Forget CFX. Not worth it. If you want more performance just wait more for a faster GPU.
2) 390X is faster but at the same time is older, uses more power and runs hotter. I would say RX480 is a better buy right now even if its 5-10% slower. A good OC will match 390X.
Ishimura
(21 items)
Silent Knight
Intel Core i7 3770K @ 4.6GHz ASRock Z77E-ITX eVGA GTX 1080 Ti Hybrid AVEXIR Blitz 1.1 16GB DDR3-2400MHz CL10
Hard DriveHard DriveCoolingCooling
SanDisk Ultra II 960GB Toshiba X300 5TB Corsair H100i GTX eVGA Hybrid Water Cooler
CoolingOSMonitorKeyboard
4x GentleTyphoon AP-15 Windows 10 Pro 64-Bit Philips Brilliance BDM4065UC 4K Razer BlackWidow Chroma
PowerCaseMouseMouse Pad
eVGA SuperNOVA 750 G3 Define Nano S Logitech G502 Proteus Core PECHAM Gaming Mouse Pad XX-Large
AudioAudioAudioAudio
Audioengine D1 DAC Mackie CR Series CR3 Audio-Technica ATH-M50 Sennheiser HD 598
Audio
Sony XB950BT
AMD Phenom II X4 955 @ 4.2GHz ASUS M4A79XTD EVO AMD Radeon HD 7970 3GB @ 1200/1500 2x 4GB G.SKILL Ripjaws X DDR3-1600
Hard DriveHard DriveHard DriveCooling
OCZ Agility 3 60GB WD Caviar Green 1.5TB 2 x Seagate Barracuda 2TB XSPC Raystorm
CoolingCoolingOSPower
EK-FC7970 XSPC RS360 Windows 10 Pro 64-Bit Corsair TX750
NZXT Switch 810
Ishimura
(21 items)
Silent Knight
Audio
Sony XB950BT
NZXT Switch 810
post #3 of 22
I would do 480. You can always CF later if need to.
Spare Parts
(8 items)
intel i5 750 Lynnfield Gigabyte GA-P55-USB3 ASUS Strix GTX 960 G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin...
Hard DriveCoolingCoolingCooling
Crucial BX100 SSD 500GB EKWB EK-KIT L120 Corsair SP120 Koolance 2x140mm Radiator HX-CU1402V
CoolingCoolingOSMonitor
Corsair AF140 Bitspower VG-NGTX960 Windows 7 Ultimate 64 bit Samsung Curved 27" S27D590C
Corsair Strafe RGB Apevia Iceburg 680 watts Apevia X-Sniper 2 EVGA Torq X3 Laser
AMD Phenom 9750 ASUS M3A78-CM PNY XLR8 GTX 460 Corsair XMS2 (4 x 1GB)
Hard DriveCoolingCoolingPower
Hitachi 5K500 Silenx 92mm EFFIZIO Corsair SP 120 Red LED Antec 500watt
Intel Core i5-6400 Skylake ASRock A170A-X1/3.1 Gigabye G1 Gaming GTX 970 Windforce CORSAIR Vengeance LPX 16GB (4 x 4GB) 288-Pin DD...
CoolingCoolingCoolingCooling
Bykski CPU-XPR-A High Performance Acrylic Nicke... EKWB Acrylic Nickel GPU Block Monsoon MMRS Reservoir Bykski BY-PUMP-XPH-PA Water Cooling Pump
Koolance 240 30 FPI Radiator Magicool 280 14 FPI Radiator Bitfenix Spectre PWM 120mm Fan ML140 140mm PWM Premium Magnetic Levitation Fan
OSPowerCase
Windows 10 Pro Corsair RM Series 850 Thermaltake Suppressor F31
Spare Parts
(8 items)
OSPowerCase
post #4 of 22
I agree with above post, I would stray away from CF setups unless you are familiar with them and have had good luck with them.
I have had multi CF setups before and all of them gave me headaches and issues. If you are deadset on these cards I personally would choose the 480 over the 390x, but if your running 1440p and are not biased on brand, have you looked into spending a little more money and checking out the GTX1070?
post #5 of 22
I'm wanting more reasons to get the 480, and you've given me another. Thanks. However, I have been a multi gpu user for years and disagree with CF not being worth it.
post #6 of 22
If I can find a 1070 for MSRP I'd consider it. I have no loyalty towards either brand. I'm currently using nvidia and typically alternate between the two each upgrade cycle.
post #7 of 22
CF is personal preference and especially the games you play. Some love it some hate it. Some deal with it just because it looks friggin cool.
Spare Parts
(8 items)
OSPowerCase
Spare Parts
(8 items)
OSPowerCase
post #8 of 22
I am the same way now, but in the past years I actually have been (to some extent) an AMD fanboy because older nVidia cards gave me nothing but issues in themselves, but with these new gen cards it changed a lot for me. I recently purchased a new 27inch 1440p monitor and my 290X just wasn't cutting it. The options that I had in mind was to purchase a 480 and then getting another one for CF setup or just get the 1070. I chose the 1070 because of 2 main reasons. 1, After long thought, I did not want to go back to a CF setup. I don't want the extra heat or sound, and would prefer to completely ignore any CF issue that I may come across. 2, I found a seller here on OCN selling a 1070 for a very good price so I jumped on it.
But seeing how you have CF experience and you'll most likely be fine, I honestly think going CF 480 or the 1070 are still really good options, plus they are both new gen cards which is always nice.
post #9 of 22
Here is the thing. With both SLI and CFX I only recommend it if no better single GPU exists out there. Right now no AMD card should be CFX. For SLI maybe 1080s or if super rich Titan X.
When it works if's fine but if you play a lot of games it starts to show it's ugly side. I used to only play games where CFX was not necessary like Dota 2, SC2 and Battlefield where its worked really well but now that I am at 4K I need CFX for 80% of the games I play but most just do not work well. 390X is a old card now compare to what is out there. 1070 will be a lot better then 2 x 390X or 480s in everyday game-play. As far as 390X vs 480. For reference my 290X which in reality uses less power then 390X hits 60C with WC. That is very hot. I can't image how this card would run on air on summer days. CFX will just make things terrible. My rule is to have WC if CF these 250W+ cards.
Ishimura
(21 items)
Silent Knight
Audio
Sony XB950BT
NZXT Switch 810
Ishimura
(21 items)
Silent Knight
Audio
Sony XB950BT
NZXT Switch 810
post #10 of 22
290X referenced air user here, I also live in FL. The card gets friggen HOT... i mean REALLY HOT and REALLY LOUD. Also a reason i chose to upgrade to a single 1070.
  Back to Forum: AMD/ATI
