Overclock.net › Forums › Intel › Intel Motherboards › 0198: System Security - Unauthorized BIOS update attempted.
post #1 of 7
Ok, so I bought an IBM Think Center off Ebay and Bios had a password on it, so I pulled out the CMOS battery for 60 seconds to hopefully reset the password - bad idea aparently.
Now on start up it's saying
"ERROR
0162: Configuration Error - Default configuration used
ERROR
ERROR
0197: System Security - Unauthorized SMOS change detected"
Unauthorized? It's authorized because I say it's authorized! Damnit!
Anyway, the bloke on Ebay said he lost the cmos password, so now I need some help...
Anyway, I can't turn on the computer without putting in a password and saving, which I can't do because I have no password, so what can I do? I'm almost on my way to buying a new motherboard....
(This was posted in Intel General, and sorry for double posting but I think this is the place the thread should be...)
E8500 Gigabyte GA-x48-DS5 ATI 4870 2x2GB Team Dark, 1066Mhz
2x500GB Seagate, 1x1TB Seagate None! Windows XP 2x22" Asus Widescreen
PowerCase
850Watt Thermaltake Toughpower Thermaltake DH-101
PowerCase
post #2 of 7
Is it a laptop or desktop? If you have a laptop, chances are that the eBay seller scammed you because it's known by many that you will have hard times recovering the password.
#well
(19 items)
Lenovo L530
(8 items)
Intel Core i7 4770k Gigabyte Z87X-UD4H XFX Radeon HD 6950 Corsair CMX8GX3M2A2000C9
Samsung EVO 840 Hitachi HDS722020ALA330 Generic DVD±RW Burner Noctua NH-D14
OSMonitorMonitorKeyboard
Windows 8.1 Dell U2711 LG W2453 Ducky DK9008 Overclock.net Edition, Cherry MX B...
PowerCaseMouseMouse Pad
Corsair TX850 Antec Three Hundred Corsair Raptor M40 QPAD HeatoN M
AudioAudioAudio
E-MU Tracker|pre Beyerdynamic DT-770 250 Ohm AntLion ModMIc
CPUGraphicsRAMRAM
Intel Ivy Bridge 3210M Intel HD 4000 Graphics Soldered Corsair Vengeance
500GB DVD-+RW Windows 7 Professional 1600x900
#well
(19 items)
Lenovo L530
(8 items)
AudioAudioAudio
CPUGraphicsRAMRAM
post #3 of 7
It's a desktop.
PowerCase
PowerCase
post #4 of 7
what is the exact make and model?? as you can get bypass passwords for most mobo's for problems just like this.
AMD 64 4200 M2N-E SLI ATI 5770 1gb 3gb ddr2
WD500, WD300 22x DVD Write Windows 7 Ultimate 64bit 19" Widescreen acer
KeyboardPowerMouseMouse Pad
M$ ps2 600w Toughpower Logitech G9 Qpad Large
post #5 of 7
It's an IBM Think Centre 8171-LMC
Mobo seems to be... (all I can see on the mobo is) IBM DDR Rev : 3.2
PowerCase
PowerCase
post #6 of 7
Actually, I just remembered, It's also called an "S51" or something by IBM on thier website. Where would I find this bypass? IBM website?
PowerCase
PowerCase
post #7 of 7
Problem solved, after hours of trawling the internet I came up with a pretty vage post that said there was a set of jumpers to clear the chip with all the security passwords (http://www.mail-archive.com/twinclin.../msg00051.html) After searching the mobo I found 1 jumper with no jumpercap on it. So anyway, gave it a shoot and it came up with all the above error messages and.... "All passwords and security settings have been cleared"
Me: 1, IBM: 6 hours of wasted time, but still, 0
PowerCase
PowerCase
  Back to Forum: Intel Motherboards
