Just a quick question for my upcoming build. I'm going to be going x99 and I want to get 32 gigs or ram, yes I know it's overkill and you guys would suggest 16 gigs, but let's just stick to 32.
I originally wanted to get 32 gigs (4x8gb) of 3000mhz corsair vengeance lpx: http://www.corsair.com/en-us/vengeance-lpx-32gb-4x8gb-ddr4-dram-3000mhz-c15-memory-kit-black-cmk32gx4m4c3000c15
But, now I'm decided whether to get 2666 mhz and OC it to 2800mhz, will there be much of a difference if any at all if i go 2666 instead of 3000? I will be mostly gaming and I also will be getting into using adobe programs. Also, one more question, why is the 2666 mhz ram more expensive than the 3000mhz ram listed above?: http://www.corsair.com/en-us/vengeance-lpx-32gb-4x8gb-ddr4-dram-2666mhz-c16-memory-kit-white-cmk32gx4m4a2666c16w
Thanks
Thanks
