Overclock.net › Forums › Intel › Intel Motherboards › 680i
680i
post #1 of 15
Guys I have been searching this site and the net for info on the 680i boards for weeks trying to decide which board to buy. I have also thought alot about what I want the board to do so here are my priorities.
1. Must be very stable
2. Must be easy to water cool
3. Must be able to overclock an E6600 to 3.0 to 3.6 GHz
4. Must be able to run SLI at full x16 on both cards
5. Must be stable and compatiable with XFX brand 8800GTS Vid cards
6. Must be stable and compatiable with X-Fi extreme music sound card
7. Price of the Motherboard does not matter.
8. Must be compatiable and stable with Gskill PC2(8000) memory
I know most everyone on here recomends the P5N32-E and if that will do the job well I will go with it But I want this build to be as perfect as possiable. I want to build it and forget it.
Any and all suggestions and comments welcome.
GamersDreamV2
(16 items)
AMD FX-8350 Vishera AM3+ Asus Crosshair V Formula-Z XFX Radeon HD 7950 Double D XFX Radeon HD 7950 Double D
RAMHard DriveOptical DriveCooling
G-Skill Ripjaws Z Series DDR3 OCZ Agility 3 SSD (main), Seagate 250GB HDD (ba... Sony DVD Burner Corsair H100i
OSMonitorKeyboardPower
Windows 7 Home Premium LG 23" Widescreen Steel Series Stealth Keyboard OCZ ZX Series 1000W Fully-Modular 80Plus Gold
CaseMouseMouse PadAudio
Corsair Carbide Series 500R Black Steel Series Diablo 3 Mouse Allsop Supreme FX III on board audio
GamersDreamV2
(16 items)
post #2 of 15
EVGA NF68-A1 is a good choice
Gamer
Intel E6600 @ 3.4 425x8 EVGA 680i NF68-A1 BFG 8800 GTS OC2 620/1000 OCZ Plat Rev2 DDR 800 4x1GB
WD 74GB Raptor & WD 500GB Caviar LITE-ON 20X DVD-+ Burner Vista Ultimate x64 Dell 19" FP
PowerCase
Thermaltake Toughpower 700w Thermaltake Aguila
Gamer
PowerCase
post #3 of 15
Is yours on air or water cooling?
GamersDreamV2
(16 items)
GamersDreamV2
(16 items)
post #4 of 15
You're sys temps a bit high did you install Nvorce fan or any other activec coolong on SPP?
The 680i A1 is Awesome, It was my First ever build and not a single problem.
I highly recommend it.
I7 Beta
(16 items)
Corre i7 4770k ASRock Z87 Killer EVGA GTX 770 ACX SC 8Gb G.Skill Ripjaws 2400
Samsung 840 Evo 250 WD Black 1tb LG Hyper 212 Evo
Win7 Home Premium Samsung T240HD Logitech G15 Corsair HX 650
CaseMouseAudio
Stacker 830 Razer Sound Blaster Z
I7 Beta
(16 items)
CaseMouseAudio
post #5 of 15
I'm using a Scythe Infinity with a TT Thunderblade strapped to it.
Load temps do not get above 55 so I'm happy & yes I'm using the NB cooler that came with the board
Gamer
PowerCase
Gamer
PowerCase
post #6 of 15
I have both the Evga 680i and the Asus P5N32-E, and I can say that the Asus is better. Just make sure you get chipset cooling.
post #7 of 15
Id go with the ASUS board. They usaully have the best Intel boards.
Very nice!
Core 2 Duo E6600 Asus P5N32-E SLI EVGA 8800GTX 2 x 1GB GSkill HZ
2 x WD Caviar SE16 250GB Sony NEC Optiarc 18x SATA DVD Windows XP Pro Gateway FPD2485W 24"
Logitech G15 PC P&C Silencer 610W Thermaltake Tsunami Logitech MX518
Very nice!
post #8 of 15
I guess I will go with the P5N32 I was already leaning that way from the things I have read on this site and the internet. I just hope I don't have any issues with my X-Fi card 1 I love the card and 2 I can't stand sound glitches of any kind. Sound glitches are my pet peev. I was considering the new Gigabyte board but it is $150 dollars higher and although the reviews say it is supper stable (something I realy want in a board) It is over priced for what it can do and has use-less (at least to me) features on it. Who uses four RJ45 connections any way.
Well any way thanks four your help and advice.
GamersDreamV2
(16 items)
GamersDreamV2
(16 items)
post #9 of 15
I've also had the EVGA and the Asus 680i boards (started with the EVGA). I also recommend the asus for a variety of reasons, foremost being better overclocking.
Which Gigabyte board is $150 more expensive than the Asus P5N32-E (thats more than the Asus Striker?)
Murder Box II
(18 items)
Home PC
(15 items)
Intel 6800K Asus X99-A II Zotac 1080Ti AMP Extreme Edition G. Skill Trident Z - 32GB/ 3200Hz/CL14/Quad
Hard DriveCoolingOSMonitor
Sandisk Extreme Pro 480GB Corsair H100i V2 - w/ML120 Pro Fans Windows 10 Home 64 Bit Acer Z35P 1440P G-Sync
Steelseries Merc  EVGA Supernova G2 1000W Corsair 450D Mionix Naos 8200
Mouse PadAudioAudioOther
Inwin Batmat Aluminum Sound Blaster Z Logitech Z906 - 5.1 Maxnomic Commander S-III Gaming Chair
Intel G3440 Asus B85M-E/CSM EVGA GTX 950 Patriot Viper 3 - 2x8GB 1600hz
Samsung EVO 850 - 500GB + 4TB/3TB x 2/2TB WD Green LG CH12LS28 Bluray Scythe Big Shuriken 2 w/Corsair SP120 Fan Windows 10 64 Bit
Samsung 75" TV.... GooBang Doo MX3 Corsair CX430 V2 NMEDIAPC HTPC 6000B w/ Pro LCD Module
Mouse
GooBang Doo MX3
Murder Box II
(18 items)
Home PC
(15 items)
Mouse
GooBang Doo MX3
post #10 of 15
It's their 680i board
http://www.newegg.com/Product/Produc...82E16813128037
I just ordered this
http://www.newegg.com/Product/Produc...82E16813131073
http://www.newegg.com/Product/Produc...82E16814150172
I am planning to add a stacker 830, E6600, Gskill PC8500 mem, and a PC P&C silencer 750 watt PSU to it later for now I will just use this to upgrade my current build. When I finish getting all of this I plan to turn my current build into a server.
GamersDreamV2
(16 items)
GamersDreamV2
(16 items)
  Back to Forum: Intel Motherboards
