Overclock.net › Forums › AMD › AMD CPUs › 96oC slight heat issue
post #1 of 7
As you can see the highlighted temp in red is alarmingly high...i dont know what it is but i have read that this can be the N/B temp the temp idles at 37oC.Can anyone help as im totally stuck and im also worried that something in my case is this temperature
Core 2 Quad Q6600 @3.2Ghz Asus P5N-T Deluxe 2x BFG 8800GTS 640 SLi 4GB Crucial Ballistix Tracer Pc8500
Hard DriveOSMonitorPower
750GB Xp Pro/Vista x64 Ultimate dual boot 19" Philips Widescreen 750w Silverstone Modular
Cm690 Dominator
Cm690 Dominator
post #2 of 7
does anybody have any ideas?
Cm690 Dominator
Cm690 Dominator
post #3 of 7
Update your version, it's a common problem on older revisions of Everest
X79 Build
Intel Core i7-6950X @ 4.0Ghz Asus Rampage V Extreme [Bios:3101] 2x EVGA GeForce Titan X SC Editions in SLI 32GB (4×8) Corsair Dominator Platinums (3000Mhz)
Samsung 950 Pro 512GB M.2 Nvme 2x 256GB Vertex 4 SSD (RAID-0) 2x 2TB Seagate Barracuda [Storage] Pioneer BDR-207DBK Blu-ray Writer
CoolingOSMonitorPower
Corsair H105 (Push/Pull) Windows 10 Pro x64 2x 27" Asus PG278Q ROG Swift 144hz  Corsair AX1500i Digital ATX 80 Plus Titanium
CaseAudio
Lian Li PC-O8WX ATX Cube Case Logitech Z906 5.1 Surround
i7-3930K (C2) @ (4.6Ghz) Asus Rampage IV Extreme X79 (Bios 3204) 3x EVGA GTX780Ti's SC Editions 32GB (4x8GB) G-Skill TridentX 2400Mhz
2x 256GB OCZ Vertex 4's (RAID-0) 2x 2TB Seagate Barracuda 7200.14 64MB Cache Pioneer BDR-207DBK Blu-ray Writer Corsair H105 (Push/Pull)
OSMonitorPowerCase
Win7 Pro 64Bit & Win10 Pro 64Bit Asus ROG Swift (2560x1440 @144hz) Corsair AX1200 + Corsair RED sleeved cables Coolermaster Cosmos II Ultra
X79 Build
CaseAudio
OSMonitorPowerCase
post #4 of 7
Try getting the newer version or it may be that your chipset fan isn't working
Server
(16 items)
Intel i7 930 @ 4ghz EVGA X58 SLI ATI 4870 12GB DDR3 1600mhz
Hard DriveOptical DriveCoolingCooling
OCZ Vertex 4 120GB SDD, 4TB Seagates DVD-RW XSPC 360 Radiator Swiftech MCP355 w Petra block
Heatkiller Rev. 3 liquid cooling block Windows 7 X64 23" LG Flatron + 22" Acer OCZ GameXstreme 700watt
Corsair 700D
Server
(16 items)
Corsair 700D
post #5 of 7
my board doesnt have a chipset fan as standard although i have got one stuck to the top of the northbridge.is that what the aux temp is?ive put my hand on the side of the N/B heatsink and it doesnt feel 96oC
Cm690 Dominator
Cm690 Dominator
post #6 of 7
I said what you needed to do, so don't panic man.
X79 Build
CaseAudio
OSMonitorPowerCase
X79 Build
CaseAudio
OSMonitorPowerCase
post #7 of 7
I bet it's the PWM temperature. 96C is warm, but typically PWM circuitry is good up to 120C. Mine get as high as 80c, but that's expected, since they're passively cooled.
mitx
(16 items)
Intel i5 3570K 4.5ghz ASRock Z77E-ITX Sapphire R9 290x Tri-X 1200/1500 Crucial Ballistix Tactical LP 2x8 GB 8-8-8-24-1T
Samsung 840 Pro 256gb Western Digital Velociraptor Western Digital WD15EARX Western Digital WD15EADS
CoolingOSMonitorKeyboard
Silverstone NT06-Pro Windows 10 x64 LG 29UM67 Logitech G710+
PowerCaseMouseAudio
Silverstone SG08 600W PSU Silverstone SG08B Logitech G700 Pioneer SE-A1000
mitx
(16 items)
PowerCaseMouseAudio
  Back to Forum: AMD CPUs
