Overclock.net › Forums › Components › Hard Drives & Storage › 74Gig Raptor..Or is it?
post #1 of 17
Hi Folks,
Yeah so I've been benching my 8mb and 16mb Raptors against each other individually.
I noticed a very strange thing, all apps identify one Raptor as a 74Gig.
Now the really strange part, the capacity is seen as 148gig
What do I believe, is this a Raptor150 in disguise?
Screens attached, I attached the most reliable 2, the Raptor in question is disk J in Disk management.
Well lay it on me, what do you think??????
Mighty-iTX
(12 items)
One foot in..
(17 items)
mATX
(12 items)
i7-4770K M7-Impact Strix GTX980 Samsung
Hard DriveCoolingOSMonitor
Crucial M4 256 Glacer 240L W8.1 K272HUL
Saitek Seasonic X-650 Prodigy MX518
4770K/45/43 Maximus VI Extreme R290X R290X
RAMHard DriveHard DriveOptical Drive
Samsung Crucial M4 64GB RAIDR LSSWM
CoolingOSMonitorKeyboard
Cooler Master Glacer 7 Ultimate 64 SyncMaster Eclipse
PowerCaseMouseMouse Pad
XFX 1050 BE 600T Silver MX518 Desk
i5-4330 Z87 Gryphon GTX690 G.Skill RipJawsX
WD Blacks Hyper 212 W8.1 ACER
Logitech Ultra X3 1000w Corsair 230T Orange Razer
Mighty-iTX
(12 items)
One foot in..
(17 items)
mATX
(12 items)
post #2 of 17
What's the model number on the hard drive? You may want to go to WD and check the hard drive's warranty. When you type in the serial, it should also tell you what model you have.
Once again...
i7 920 [4.28GHz, HT] Asus P6T + Broadcom NetXtreme II VisionTek HD5850 [900/1200] + Galaxy GT240 2x4GB G.Skill Ripjaw X [1632 MHz]
Hard DriveOSMonitorKeyboard
Intel X25-M 160GB + 3xRAID0 500GB 7200.12 Window 7 Pro 64 Acer H243H + Samsung 226BW XARMOR-U9BL
Antec Truepower New 750W Li Lian PC-V2100 [10x120mm fans] Logitech G9 X-Trac Pro
Once again...
post #3 of 17
Odd stuff but based on the model WD740ADFD it's a 74g model.
http://www.wdc.com/en/products/produ...sp?driveid=244
The 150g model is WD1500ADFD
Refreshed Duo
E8500 E0@4.25Ghz (500x8.5) Gigabyte GA-EP45-UD3P EVGA GTX285 (720/1674/2772) 2x2gb G.SKILL PC8500
3xWD 250GB RAID0 Sony DVD/CDR/RW Windows 7 Ultimate x64 ACER 24" P241WAID LCD
Logitech G15 (Original) OCZ GameXStream 700w SLI ThermalTake Armor Black Logitech G5
Mouse Pad
Razor XACT
Refreshed Duo
Mouse Pad
Razor XACT
post #4 of 17
Man this is crazy, I just deleted the partition and created a new and it went to 148 as well.
IDK what to think
Mighty-iTX
(12 items)
One foot in..
(17 items)
mATX
(12 items)
Mighty-iTX
(12 items)
One foot in..
(17 items)
mATX
(12 items)
post #5 of 17
what....the....heck??????
post #6 of 17
I know. Make loads of folders. Fill the hard drive up -- if it goes much over the 74GB .. then it's a bigger HDD. If it actually puts data onto the 130+ GB of space that it says it has... it must be telling the truth about its space
AMD X2 3800+ Manchester Asus A8N-SLi SE nForce4 BFG 8800GTS OC 640MB @ 661/2Ghz Nanya 1GB DDR400
160 GB WD Caviar Acer DVD+-RW 16x Windows XP Pro x64 Acer AL1916WS 19" Wide
Logitech Explorer Hiper Type-R Modular 580W Thermaltake Soprano Black Logitech 500 G-Optical
Mouse Pad
£3 Generic :D
Mouse Pad
£3 Generic :D
post #7 of 17
IDK what to think
The data would suggest that this is the case.
It would not be the first piece of hardware that has been incorrectly labelled/packaged by the manufacturer. My 8800GTS was sold as a 320MB version. when I got it home it was the 640MB version in disguise
http://www.overclock.net/nvidia/1678...ing-issue.html
You could try say writing 80GB+ to the disk, if it works than you must have the 2 platter 150GB version not the single platter 74GB version Just an idea (beat me to it JohnRogers lol )
Desktop
Opteron 165 CCBBE 0615DPMW 2.6GHz (9x290) DFI NF4 SLI-D (HR-05-SLI Passive Chipset Cooler) BFG 8800GTS OC 640MB 620/1860 Mushkin Redline 4x1GB DDR475 (3-3-2-7 2T)
3x 74GB WD Raptor (RAID 0) + 2.2TB of SATA HDDs NEC DVD/RW SATA XP Home Edition SP3 IIyama H481S 19' TFT 1280x1024
Eluminix (Backlight) OCZ Modstream520w 28A,12v Single Rail Antec P182 Razer, Copperhead Blue
Mouse Pad
Razer Exactamat
Desktop
Mouse Pad
Razer Exactamat
post #8 of 17
Hi Folks,
Simple. If that Raptor was the first one in an array or a 150GB partition, it will show up as the entire size of the partition because that is where the files are indexed. Format the drive and you should see its normal size.
BladeRunner v3.0
(11 items)
Intel Core i7-5930K @ 4.6GHz Core, 4.4GHz Cache ASUS X99 Sabertooth Sapphire R9 380 Dual-X OC G.Skill TridentZ 32GB DDR4 @ 13-15-13-33-1T 320...
Hard DriveCoolingOSKeyboard
Samsung 850 Pro 512GB Noctua NH-D15S Windows 10 Home 64-bit Logitech G910 Orion Spark
PowerCaseMouse
EVGA SuperNova 1000W T2 NZXT Phantom 820 Black Logitech G5
BladeRunner v3.0
(11 items)
PowerCaseMouse
post #9 of 17
Not a bad idea, I guess I could transfer all 140gigs of my pr0n and see what happens.
Mighty-iTX
(12 items)
One foot in..
(17 items)
mATX
(12 items)
Mighty-iTX
(12 items)
One foot in..
(17 items)
mATX
(12 items)
post #10 of 17
I have formatted it and partitioned it, deleted and did it again.
Mighty-iTX
(12 items)
One foot in..
(17 items)
mATX
(12 items)
Mighty-iTX
(12 items)
One foot in..
(17 items)
mATX
(12 items)
  Back to Forum: Hard Drives & Storage
