Overclock.net › Forums › Intel › Intel CPUs › 6320 oc to 3.15 wall
post #1 of 3
tried keeping same bios settings and just upping cpu/fsb mhz and got several bugs, vcore was at 1.45(so bios says) games kept crashing or getting effects texture glitches. im running at 3.15 now with 1:1 and everything is fine. ive turned all the extra crap off in bios, did the ctrl f1 to get extra options, upped vdimm to 2.1v fsb/mch +.1v, pci-e 100, 7x , 450fsb, fan on NB, fan for RAM. anything else yall think i could try to get to about 3.5 or so?
almost done(8800)
c2d 6320 1.8@3150 1:1 Gigabyte DS3 x1950 pro 256 2G Patriot EP 800@900
80g Sata 7200rpm dvdrw/dl x2 xp pro 19" flat crt
generic okia 500W 712-4HLW-BK rosewill laser
almost done(8800)
post #2 of 3
have you messed with your ram timings at all
Coeus
AMD 940 Msi 970a-g46 2x xfx 7970 G Skill NQ PC1333 4x2
Seagate 7200.9 160gb need Windows 10 64bit Sharp 32inch
Power
Thermaltake 1350
Coeus
Power
Thermaltake 1350
post #3 of 3
i did, then it went haywire so i set it back to auto. thats really the only way its stable. but the timings arent too bad 5 5 5 15 i think. its in my "stats" link in sig
almost done(8800)
almost done(8800)
  Back to Forum: Intel CPUs
