Overclock.net › Forums › Graphics Cards › NVIDIA › 6800
6800
post #1 of 11
i recently bought one along with my x850xt.
the 6800 is pcie and has a area for the 6pin connector but isnt installed. if i install one, will it run better? oc better? fry? nothing?
post #2 of 11
so there isn't an actual 6-pin connector on it, so you would have to solder one on?? is it just a regular 6800 or 6800GT, i'm really not sure but if you have it spare and just want to tweak around go for it,
And as far as frying it i don't think so, it'll probably just pull power from it if it needs it and the pcix16 slot isn't sufficient.
but i'm not really 100% for sure what would happen.
D
(15 items)
The Sheep Skinner
Intel i7 6700 Gigabyte Z170N-Gaming5 Sapphire Radeon R9 Fury Tri-X 3840 G.Skill TridentZ
Hard DriveCoolingCoolingCooling
960 EVO 500GB EK SE 240mm, Magicool slim 240mm EK Supreme HF CU Gold EKFC-Fury X WB
OSMonitorPowerCase
Win 10 Pro Acer XG270HU EVGA 750W  Evolv ITX
MouseMouse Pad
Naos7000 Corsair MM600
C2D E8400 DFI LT P35 Radeon HD4890 OCZ 2GB 800MHz
500GB Asus multi DVD W7 U Samsung 2232BW+
PowerCase
Corsair HX520W CM 690
D
(15 items)
The Sheep Skinner
OSMonitorPowerCase
MouseMouse Pad
PowerCase
post #3 of 11
Does it have no power connector at all?
Morpheus Mini
(7 items)
i7-6700T SN970 GTX 960 Crucial CT102464BF160B
Hard DriveOSAudio
Samsung 850 Evo M.2 Windows 10 Pro MOTU Audio Express
Morpheus Mini
(7 items)
Hard DriveOSAudio
post #4 of 11
Im confused... u make it sound like it needs a power connector
post #5 of 11
just to try it
post #6 of 11
well there is none. it wont work without it.
post #7 of 11
it works fine without it. alot of cards come as that looks
post #8 of 11
hmm sounds interesting
try it
MacBook Pro
Intel Core 2 Duo 2.33Ghz Apple x1600 256mb 3Gb Apple 667mhz
200Gb Sata 5400rpm Apple Slot Loading SuperDrive 8x Window Vista Ultimate + Mac OS X Tiger 17" Glossy
Illuminated Apple 85watt Magsafe + Battery MacBook Pro 17" Razer Diamondback
Mouse Pad
Desk
MacBook Pro
Mouse Pad
Desk
post #9 of 11
try it
i want to, i just need to find the 6pin connector piece
post #10 of 11
well it doesn't look like one had been soldered on it to begin with, soo, i'm not sure if it would still work or not, i know my agp 6800GT had to have a secondary power connector, but i'm not sure about the later pcix16 ones.
D
(15 items)
The Sheep Skinner
OSMonitorPowerCase
MouseMouse Pad
PowerCase
D
(15 items)
The Sheep Skinner
OSMonitorPowerCase
MouseMouse Pad
PowerCase
  Back to Forum: NVIDIA
