Overclock.net › Forums › Graphics Cards › Graphics Cards - General › 2250 on 3dmark06...
2250 on 3dmark06...
post #1 of 10
... for my system does that look right? it showed me that I was on the low end of similar systems. Does anyone know of what I can do without buying anything to make it run better. my average framerates were like 8 for the graphics and .55 for the cpu. Seems pretty bad, but I also don't know too much. Any advice is much needed, thanks
My System
E6300 ASUS P5n Sli 8800 GTS SSC 640mb 2gb Kingston ddr2 667
WD-sata2 250gb 16mb 7200 LG Super Multi DVD/CD-RW Windows XP Princeton 20.1" widescreen LCD
PowerCaseMouse
420W APEVIA X-Infinity Logitech G-9
My System
PowerCaseMouse
post #2 of 10
What GPU you got?
EDIT: I appear to be slightly blind.. lol
Black
C2D E2140 / 2.8Ghz / 350x8 / 1.275Vcore Gigabyte P35C DS3R Sapphire X1950Pro 256MB 4GB OCZ DDR2 1000 Reapers? Or something.
Hard DriveOptical DriveOSKeyboard
WD5000AAKS LG DVD-RW Windows XP Pro Logitech Media Keyboard
PowerCaseMouseMouse Pad
Corsair VX 550W Antec P182 Logitech MX518 None
Black
post #3 of 10
Yeah that is bad, I got 4900 on my laptop with mobile x1650 and CoreDuo.
post #4 of 10
If you had a single core CPU, the score would be perfectly normal for a 7600GS. I'm thinking its not recognizing the second core.
Install the windows dual core optimizer patch. You should see an 800 point gain.
i5 4430 MSI H81M-P33 MSI GTX960 2x4GB GSKILL DDR3 1600
Hard DriveOSPowerMouse
Samsung EVO 850 256GB Win 10 EVGA 500B Zowie EC2-A
Mouse PadAudioOther
Zowie GSR SHP 9500S + FIO E10K ASUS VG248QE Black 24" 144Hz 1ms
Mouse PadAudioOther
post #5 of 10
It should be at least 1k more I'd say.
Thuban
AMD Phenom II X6 1090T Black Edition Thuban ASUS Crosshair IV Formula AM3 AMD 890FX GIGABYTE GV-R697OC-2GD Radeon HD 6970 Mushkin Enhanced Blackline 8GB (2 x 4GB)
Hard DriveOptical DriveMonitorKeyboard
Western Digital Caviar Black WD7502AAEX 750GB 7200 SONY Black Blu-ray Burner SATA Acer G245HBbd Black 24" QUMAX Xarmor U9Plus Black Wired Mechanical
PowerCaseMouse
COOLER MASTER Silent Pro Gold Series RSC00-80GAD3- Fractal Design Define XL Black ATX Full Tower R.A.T. 9
Thuban
PowerCaseMouse
post #6 of 10
i just searched for 3dmark06 and a thread came up where people listed their scores and mine seems around what they got for 7600gs. It just still seems low. But I guess you get what you pay for.
My System
PowerCaseMouse
My System
PowerCaseMouse
post #7 of 10
Thats really low.. even I got 2800 :\\
My Rigasaurus-reX
Toledo 3800 X2 E6 (CCBWE) DFI nF4 LanParty Ultra-D XFX 6800GS 500/1200 2x512MB OCZ Enhanced Latency
250GB WD-Caviar 16M 3GB/s NEC ND-3550A Windows XP Pro SP2 17in. ŁĊĐ
Logitech G11 Åntec TRUEPOWERII 550W ThermalTake Tsunami Logitech G7 Wireless
Mouse Pad
SteelPad S&S
My Rigasaurus-reX
Mouse Pad
SteelPad S&S
post #8 of 10
Thats definitely not good..i got 3575 with my old venice at 2570mhz and 7600gt at 645/885....Overclock your cpu and gpu as much as you can...concentrate more on your 7600gs though, use ati tool and keep upping the core until you get artifacts then back off around 10mhz..do the same for the memory. Also i recommend the Z-tweaked 91.47 drivers, they yielded me the best results. Let us know what you get.
My System
(15 items)
4790K delidded @4.9ghz Asus Z97 Deluxe Wifi EVGA GTX 980 SC 2 x 8GB Corsair Vengence 2400
Crucial MX200 250gb + 1tb Lg Bluray EK Supreme, TC PA120.3, D5 Vario, San Ace Windows 7 Ultimate
32" LG7000 1920x1080 Logitech S510 XFX 650Watt XXX Modular Edition Custom Modded
MouseAudio
Logitech S510 Mission M74 Denon PMA 355
My System
(15 items)
MouseAudio
post #9 of 10
guys 1. its a 7600GS 2. 3dmark barely utilizes the second core on cpus.
Clevo P650RP6-G
(6 items)
CPUGraphicsRAMHard Drive
Intel i7 6700HQ nVidia GTX1060 6GB Kingston HyperX Impact 2133MHZ 16GB INTEL 600p 128GB
Hard DriveOS
Samsung 850 EVO 1TB Windows 10 Pro 64
Clevo P650RP6-G
(6 items)
Hard DriveOS
post #10 of 10
3DMark defineately uses the second (and third/fourth) cores on CPUs.
Your CPU test Framerate is surprisingly low. I'm guessing somethings up with the CPU and not the graphics card.
Optiplex 790
(6 items)
Some shit.
(7 items)
E7200 3.6GHZ 9*400 1.25v Gigabyte P35-DS3R BFG 9800GTX OC 2*1GB Kingston HyperX D9GKX 1200MHZ C5, 2.0V
80GB WD SATAII NEC 3550A DL DVD+/-RW Win XP Home HP W2007
Microsoft Digital Media Pro XClio Goodpower 500W Cooler Master Centurion 5 Logitech G5
i5 2400 Sapphire HD6670 LP 4GB DDR3 500GB 7200RPM
OSMonitor
Windows 7 Professional 2 x Dell 2408WFP
i5 3317U HD4000 4GB DDR3 128GB SSD
Optical DriveOSMonitor
Who needs one? OSX 10.8 11" 1366x768
Optiplex 790
(6 items)
Some shit.
(7 items)
OSMonitor
  Back to Forum: Graphics Cards - General
