Overclock.net › Forums › Graphics Cards › AMD/ATI › 1950gt HEAT!!!
1950gt HEAT!!!
post #1 of 4
well i was just wondering where the gt should be idling at while at stock and what should full load be?
i did some mild moding, i replaced some of the rubber heat pad under the sink that go over the memory and i also used some AS5 on the gpu itself. im still using the stock cooler.
my idle temp at stock is 49-50C
at full load i can reach almost 67C
now when i start to overclock it , stable at 634mhz gpu/756mhz mem
i idle at 55C
Full load at 77C.
is that too hot!!!
do u think i mest up by messing with the cooler or did i just not put it on properly?
my system crashed a couple minutes ago when the temp got to 79C
kinda made me worrie
cheep build :D
Cd2 e4300 ga-945p-ds3 sapphire x1950gt 2*1gig adata ddr667
OS
xp/F7
cheep build :D
OS
xp/F7
post #2 of 4
You will be fine if it crashes. As long as you didn't add excessive voltage, you have nothing to worry about. As for the temps. I'm not sure what the temps should be like on the 1950GT, but for reference, my X1800XT used to run at 82C max load and never showed any problems.
post #3 of 4
Perhaps you should consider a cooler from Zalman?
the VF7-00 CU or the Vf-900
The VF-700 CU did wonders for my hot and loud X850XT
Good luck!
X220
(6 items)
Intel Core i7-3820 MSI X79-GD45 MSI GTX465 GE unlocked to 470 16GB Corsair Vengeance LP
128GB Crucial M4 1TB WD Black 1TB WD Black 640GB WD Black
Hard DriveCoolingOSMonitor
2TB WD Green Noctua D14 Windows 7 Ultimate 64-Bit 2x Samsung 22" 2253BW
PowerCaseAudio
Corsair HX650 Fractal Define R2 Fii E10 DAC
CPUGraphicsRAMMonitor
Core i5 2520 Intel HD3000 Gskill  12.5" IPS
CaseMouse
Thinkpad NUB
X220
(6 items)
PowerCaseAudio
CaseMouse
Thinkpad NUB
post #4 of 4
Good luck!
will it fit on my card?
and does it blow massive ammounts of heat away from my gpu?
i can push the card a little higher but im affraid to
cheep build :D
OS
xp/F7
cheep build :D
OS
xp/F7
  Back to Forum: AMD/ATI
