Overclock.net › Forums › Graphics Cards › NVIDIA › 640 or 320
640 or 320
Poll Results: Which one will u choose
  • 48% (36)
    8800GTS 640
  • 52% (39)
    8800GTS 320
75 Total Votes
post #1 of 37
What will you choose if ur going to buy a 8800GTS?
My System
(14 items)
i5 2500k ASRock Z68 Extreme3 Gen3 CrossFire HD6870 8GB G.Skill Ripjaws
Hard DriveOptical DriveCoolingMonitor
160G Seagate, 200G Samsung, 320G WD Pioneer Dual layer watercooled Chimei 22'
G15 Cosair HX650 Thermaltake Armor LCS MX518
Mouse Pad
Red
My System
(14 items)
Mouse Pad
Red
post #2 of 37
640MB. More future proof for games using larger texture packs that will utilize the extra memory.
post #3 of 37
if you dont have a large screen, the 320 performs just as well as the 640.
if you have 22-24" or over, get the 640.
post #4 of 37
Resolutions are only one thing to consider. Games today can take up to 512MB of Vram ( on your video card ) Future games will use this amount and more. Especially DX10 apps like crysis.
post #5 of 37
If you really want to future proof then get GTX. 320MB represents a really great bargain over the 640MB version.
Under-Utilized
(14 items)
3570K Z77-D3H XFX RX480 RS Corsair Vengeance
Hard DriveHard DriveCoolingOS
HyperX 3K 120GB 3TB Storage Hyper 212 Plus Windows 10
MonitorKeyboardPowerMouse
24" CFG70  SideWinder X6 550 Watt Logitech G602
Mouse PadAudio
Razer eXactMat X Objective2 +ODAC
Under-Utilized
(14 items)
Mouse PadAudio
post #6 of 37
640, its at least gives you the best for future costs if you dont plan on upgrading again in a while.
Intel Core 2 Duo E6700 @ 3.65g MSI MS-7350 / P6N SLI Platinum GeForce 8800GTS 640mb OCZ 2GB DDR2 800MHz/PC2-6400
Sata 2 400gig 16mb Liteon dvd rw/ram Windows Vista Ultimate 64bit 22 inch LG tft widescreen
Labtec flat Thermaltake Toughpower 600w Acase Xclio Logitech Lazer MX™ Revolution
Mouse Pad
none
Mouse Pad
none
post #7 of 37
He can SLi (after 2-4 years later)
Under-Utilized
(14 items)
Mouse PadAudio
Under-Utilized
(14 items)
Mouse PadAudio
post #8 of 37
yer but no point sli a 320 thou not much gain from it, now sli the 640, yep worth it all the way
Mouse Pad
none
Mouse Pad
none
post #9 of 37
Except that that's wrong. >.>
Why pay $100 more for minimal gain? 320.
post #10 of 37
i have the 320 and love it, but if was doing over i'd spend the extra $60 for the extra 320 vram
  Back to Forum: NVIDIA
