Overclock.net › Forums › Intel › Intel CPUs › 2160 overclocking help and cpu coolers reviewed
post #1 of 13
2.8ghz so far soon to be 3ghz when i get ultra120.
Cpu Cooling;
Thermalright ultra 120 xtreme
Thermalright is no stranger to the high end heatsink market. It is one of the best coolers i personally think to date. Their designs have performed near the top of the pack for years, and the Ultra-120 promises to be no exception. http://www.silentpcreview.com/files/...0/contents.jpg
Also its packaging is good because it is not over the top.http://www.silentpcreview.com/files/...20/packing.jpg
http://www.silentpcreview.com/files/...ra-120/box.jpg
Despite its size, motherboard compatibility should be fairly good, as the fins are high enough above the base to avoid most of the components on the motherboard. Besides, the modern sockets that the Ultra-120 is compatible with allow for plenty of room around the CPU. Compatibility issues are more likely to arise with motherboard / case combinations where the heatsink hangs over one edge of the motherboard. At the time of writing, Thermalright did not list any incompatible motherboards on their web site.
http://www.silentpcreview.com/files/.../installed.jpg
The results i will show soon
L
i7 920 Asus P6T 8800GT Zotac AMP Edition OCZ 3GB 1600
Hard DriveOptical DriveOSPower
WD 500GB + 320GB WD Pioneer vista Ultimate 32 bit Zalman 850 watt HP
post #2 of 13
Goodluck, i have the same chip with a Tuniq Tower, and i am not thermal limited. I've got it at 3.6 now on 1.55v and fiddeliing around with it seeing if i can lower it. So the problem will be the vcore sooner then your temps, especially with a TRUE
BTW what fans you're gonna attach?
2600k @ 4.6ghz 1.356Vcore Gigabyte's z68x-ud3h GTX 780 ti @ 1220mhz (boost) Corsair Lowprofile 4x4GB
Hard DriveHard DriveCoolingOS
samsung spinpoint F1(TB) + 2TB + WD 3TB OCZ 60GB SSD Scythe Mugen 2 win 7 64bit
MonitorMonitorKeyboardPower
Samsung Syncmaster 2493HM Dell 19" tft 4:3 g15 Antec cp-850
CaseMouseAudioAudio
Antec Twelve hundred g500 Logitech's z906 Auzentech Forte
CaseMouseAudioAudio
post #3 of 13
my 2160 is at 9x310 and the vcore is about 1.575. it is 100% stable so far but i will be getting a new cpu cooler probably a zerotherm NV120. thanks for you help
post #4 of 13
wowowowow slow down there! 1.575 for 2.8GHZ? most people can pull this of with stock volts. with 1.575 i can get to 3.7ghz! Be sure your vcore isn't on auto. Set it at 1.45 and see how far you can come, probably around 3.2-3.4 1.575 will drasticly shorten your cpu lifetime
CaseMouseAudioAudio
CaseMouseAudioAudio
post #5 of 13
I wil try the vcore that low but i dont think it will work because for some reason it needs so
much volts when playing games other wise it restarts. could this be because of my standard cooling? as for the fans i am not sure yet. i will be running them at close to full speed so i am not worried about slience. i have completed OCCT and it was completely stable but the temp got up to 63C and stayed there all the time!! is that right. i will be using it for gaming so it needs to be completely stable.
post #6 of 13
you prolly have hit a fsb wall
Coeus
Amd Ryzen 5 1600x broken Evga GTX 1060 SSC Corsair Vengeance LPX
San Disc SSD need Windows 10 64bit Sharp 32inch
Power
Thermaltake 1350
Coeus
Power
Thermaltake 1350
post #7 of 13
True, built one that did 2.8 on just enough vcore above stock to make up for the v droop on a ds3l. Cool running also with just a ac7.
The Boss
CPUMotherboardGraphics
FX8350 GIGABYTE GA-990FXA-UD3 R9 280X
The Boss
post #8 of 13
Thanks for your help. it could possibly the fsb wall but shouldnt it go higher?? any way if you have any more info on a good water cooling setup or a good heat sink please let me know.
post #9 of 13
A FSB wall is a FSB wall.
At 421MHz FSB my system will not boot, no matter multiplier, the cooling, or the voltage. At 420 I can get it 100% stable near stock volts if I drop down to 6x multiplier.
Still, I've never seen an E21xx with an FSB wall of only ~310.
But yeah, 1.575v is way too much.
Primary
(15 items)
Secondary
In progress
(10 items)
5820K @ 4.2/3.5GHz core/uncore, 1.175/1.15v Gigabyte X99 SOC Champion (F22n) Gigabyte AORUS GTX 1080 Ti (F3P) @ 2025/1485, 1... 4x4GiB Crucial @ 2667, 12-12-12-28-T1, 1.34v
Hard DriveHard DriveHard DriveCooling
Plextor M6e 128GB (fw 1.06) M.2 (PCI-E 2.0 2x) 2x Crucial M4 256GB 4x WD Scorpio Black 500GB Noctua NH-D15
OSMonitorKeyboardPower
Windows 7 Professional x64 SP1 BenQ BL3200PT Filco Majestouch Tenkeyless (MX Brown) Corsair RM1000x
CaseMouseAudio
Fractal Design Define R4 Logitech G402 Realtek ALC1150 + M-Audio AV40
X5670 @ 4.4/3.2GHz core/uncore, 1.36 vcore, 1.2... Gigabyte X58A-UD5 r2.0 w/FF3mod10 BIOS Sapphire Fury Nitro OC+ @ 1053/500, 1.225vGPU/1... 2x Samsung MV-3V4G3D/US @ 2000, 10-11-11-30-T1,...
1x Crucial BLT4G3D1608ET3LX0 @ 2000, 10-11-11-3... OCZ (Toshiba) Trion 150 120GB Hyundai Sapphire 120GB 3x Hitachi Deskstar 7k1000.C 1TB
CoolingOSPowerCase
Noctua NH-D14 Windows 7 Pro x64 SP1 Antec TP-750 Fractal Design R5
Audio
ASUS Xonar DS
i7-6800K @ 4.3/3.5GHz core/uncore, 1.36/1.2v ASRock X99 OC Formula (P3.10) GTX 780 (temporary) 4x4GiB Crucial DDR4-2400 @ 11-13-12-28-T2, 1.33v
Intel 600p 256GB NVMe 2x HGST Travelstar 7k1000 1TB Corsair H55 (temporary) Windows Server 2016 Datacenter
PowerCase
Seasonic SS-860XP2 Corsair Carbide Air 540
Primary
(15 items)
Secondary
In progress
(10 items)
CaseMouseAudio
CoolingOSPowerCase
Audio
ASUS Xonar DS
PowerCase
post #10 of 13
I will put the vcore at 1.5 and i will come back with the fsb speed. also is speedfan a temp sensor called AUX is at 125c!!!what the hell is AUX??? also is my ram timings OK? thanks again to everyone for their help
  Back to Forum: Intel CPUs
