Overclock.net › Forums › Graphics Cards › NVIDIA › 129*C on EVGA 8800GTS G92!?!
post #1 of 11
I just got done playing Project Reality and as always I had HWMonitor running in the background. After playing for about 2 hours straight I came out and it said my max GPU temp was 129C!!!!!!!!!!!! AAHHHHHHHH!!!!!!!! Is this a misread or could it really have gone that high? I have Rivatuner setup with fan profiles, but I hear that it sometimes does not work properly. I have noticed this while idling. I have never seen a real reading above 56C, even when playing COD4 on high settings with my GPU overclocked. Playing PR just now I had no overclocks running and my case fans are all blasting.
I have also had some strange and outrageous temp readings on HWMonitor, but they are always completely obvious that they are wrong, like -12,938,293, or 121,231 quite literally. But 129C actually seems like it could be right.
Is there any way to get Riva to record my temps for longer than just a few minutes? It seems now when I save a "log" it is only as long as the window can show in the Hardware Monitoring window. I wouldn't mind having it use a lot of space to save my entire game.
Should I RMA the card just in case? I've been kind of weary about it lately. Something just doesn't feel right.
post #2 of 11
yea maybe you should RMA it, the temp sensor might be faulty but you should RMA for that too lol
is it hot to the touch when it gets that high? mine typically loads around 55*C with overclocks and stock fan at 65%
(now if u had a 7900, i wouldnt know what to tell you, mine used to get up to 100C under load, and i used it for a year till i replaced it with my g92 lol)
edit: nvm, i think ur software could also be the culprit, might be reading the sensors wrong, i just realized u said it dodnt go over 56C in COD4
AMD Phenom II X6 1075T ASUS M4A88TD/USB3 EVGA GTX470 8GB A-Data DDR3-1600
Hard DriveOSMonitorKeyboard
2x 250GB WD Blue, SATA3 Windows 7 Professional 24" 1920x1080 Logitech G19
PowerCaseMouse
650w Corsair TX Antec 900 Logitech Mx518
PowerCaseMouse
post #3 of 11
That is scary,
Id try simulating what happened again, using a different temperature monitor (Ntune or ATITool)
i5 2500k Asus P67-M Pro HD 4890 2x4gb Gskill DDR3 16000
60gb Force 3 SSD + 1TB Caviar Black Samsung 22X DVD Windows 7 x64 Ultimate LG IPS 23"
Razer Black Widow Ultimate Silverstone 700W Corsair 600T Logitech G500
post #4 of 11
Poor little guy. :cry: I've only had it for 2 weeks. I am sending my 680i in for step up. I will try and call EVGA next week and see if I can send the card in at the same time.
Does ATI-tool keep track of the max temp reached? That is why I love HW Monitor because it shows the max temps for everything.
I don't know what to think about this. I get different temp readings for almost every program I try to run. Usually Rivatuner and HW Monitor seem right, and they are almost always the same temp. GPU-Z is NEVER right!
Right now idling with fan at 60% according to Rivatuner:
Rivatuner - 41
HW Monitor - 41
ATI Tool - 41
GPUZ - 33 I don't think that is right.....
post #5 of 11
download and run RTHIBL in conjunction with the ntune monitoring software. RTHIBL will max out your card and give you a good idea of what the top temp is.
Murder Box II
(18 items)
Home PC
(15 items)
Intel 8700k Gigabyte Aorus Z370 Gaming 7 Zotac 1080Ti AMP Extreme Edition G. Skill Trident Z - 32GB/ 3200Hz/CL14/Dual
Hard DriveCoolingOSMonitor
Sandisk Extreme Pro 480GB Swiftech H240 X2 Prestige AIO Windows 10 Home 64 Bit Acer Z35P 1440P G-Sync
Delux T9 Pro / Logitech K360 EVGA Supernova G2 1000W Corsair 750D Airflow Mionix Naos 7000
Mouse PadAudioAudioOther
Perixx DX-3000LAL Aluminum Sound Blaster Z Logitech Z906 - 5.1 Maxnomic Commander S-III Gaming Chair
Intel G3440 Asus B85M-E/CSM EVGA GTX 950 Patriot Viper 3 - 2x8GB 1600hz
Samsung EVO 850 - 500GB + 4TB/3TB x 2/2TB WD Green LG CH12LS28 Bluray Scythe Big Shuriken 2 w/Corsair SP120 Fan Windows 10 64 Bit
Samsung 75" TV.... GooBang Doo MX3 Corsair CX430 V2 NMEDIAPC HTPC 6000B w/ Pro LCD Module
Mouse
GooBang Doo MX3
Murder Box II
(18 items)
Home PC
(15 items)
Mouse
GooBang Doo MX3
post #6 of 11
Touch the card and see if you get burned. If not...the sensor is definitely faulty.
FX Rig
AMD FX-8320e Gigabyte GA-970A-UD3P Sapphire R9 380 4GB 2x8GB Crucial Ballistix DDR3-1600
Intel 240GB SSD HGST 4TB Storage DVD-RW Cooler Master Hyper 212 EVO
OSMonitorPowerCase
Windows 7 x64 AOC 27" 1080p Corsair CX750m Corsair 200R
Audio
Asus Xonar DS
FX Rig
OSMonitorPowerCase
Audio
Asus Xonar DS
post #7 of 11
i use atitool for gpu temps. but then again for me they both read the same temperature.
MIVE
(15 items)
i5 2500k (4.7ghz at 1.33v) Asus Maximus IV Extreme MSI GTX 980 Ti 6G Gaming  8GB (2x4GB) G. Skil Sniper
Crucial M4 Corsair H105 Windows 10 x64 Asus ROG Swift
Corsair K70 RGB Rapidfire OCZ ZX1000W Corsair 600C Corsair M65 Pro
AudioOtherOther
V-Moda Crossfade Wireless headphones Sennheiser HX 6XX headphones Schitt Fulla 2 DAC/AMP
MIVE
(15 items)
AudioOtherOther
post #8 of 11
Ntune should not be used. Everyone here will tell you that. It's screwed over both Windows installs AND BIOS.
Touching it though isn't really a good thing to do imo.. My Ultra gets very hot to the touch.. Not really enough to burn you, but very close. Are you sure the fan is spinning properly and not going on and off? I'd either RMA it, or try an aftermarket cooler.
Lantia
Q6600 G0 @ 3.0Ghz 1.285v ABIT IP35 Pro EVGA GTX280 SC / Hauppauge HVR 1800 8 GB Super Talent DDR2 800
2x WD SE16 500GB Asus DVD-RW 1814BLT & LG GGC-H20L BR/HD-DVD Vista Ultimate x64 SP 1 Acer P221W 22" & Acer AL2216 22"
Microsoft Reclussa Rosewill RX750-D-B NZXT Zero Logitech G7
Mouse Pad
XTRAC RIPPER XL & XTRAC X-Trac D-Gel Wrist Rest
Lantia
Mouse Pad
post #9 of 11
ATI Tool artifact scan for 10 minutes... currently running I am getting
Riva - 53
ATI-Tool 53 (Updates a little slower than Riva though, it said 52 a second ago now it is 53)
HW Monitor - 53
GPUZ - 44.5
HW Monitor says my max was 54C. That is about normal and what it usually gets to. I'm going to touch it and see what happens. The back of the PC board is like warm water. I'd call it colder than bath water.
The air coming out of the exhaust is also just barely warm. The outside of the heatsink shroud is warm to the touch, but not extremely hot at all.
Ok, something is seriously wrong here. I was just watching GPU-Z and it jumped to 109.5C and then back down to 45.5. *sigh*
post #10 of 11
Riva - 53
HW Monitor - 53
GPUZ - 44.5
Yeah your heat sensors are messed up
GE60
CPUGraphicsHard DriveOS
Intel Core i5 4200M Geforce GTX760M 750GB WD Scorpio Black Windows 7 Home Premium
MonitorKeyboardMouseMouse Pad
15.6" CM Quickfire Rapid CM Xornet Steelseries QcK+
GE60
  Back to Forum: NVIDIA
