Overclock.net › Forums › Intel › Intel Motherboards › 780i
780i
post #1 of 14
Does anyone recommend this item? Because I would really like to consider upgrading for the Tri-SLI.
Azor's Tank...zor
Intel Core 2 Quad Q6600 G0 @ 3.5ghz Asus Maximus Formula X38 Sapphire HD 4870 OCZ 779 2 x 2 Gb
Hard DriveOSMonitorKeyboard
WD 160GB/ Samsung 1TB Windows 7 Enterprise 64-bit SAMSUNG ToC T240HD 24" and ViewSonic VA903b 19" Logitech G11
PowerCaseMouseMouse Pad
850W Thermaltake ToughPower Cooler Master Stacker 830 Evo Logitech G5 Laser X-TRAC Ripper 17"
Azor's Tank...zor
post #2 of 14
i recommend it, add the current parts that you have on ur sig and youll be smoking. plus your staying ahead in the game as far as mobo wise
My Current Rig
Intel Q6600 G0 evga 780i ftw EVGA 8800GT @ 700/1800/900 8GB Crucial Ballistix
WD 160GB AAJS, 640GB AAKS Asus Vista Ultimate x64 Bit SP1 Samsung Synmaster 2253BW
Saitek *Dead* Thermaltake Powertough 750W Thermaltake Armor logitech MX518
My Current Rig
post #3 of 14
I like mines....and so far stable at 4.2ghz with my e8400 thinking of going 4.4
Who's next
intel core i7 965 Gigabyte x58 extreme on water 2 gtx 295s corsair dominators 3 gig DDR3 1600 mhz
velociraptor 300 gigx2 (raid 0) sony bd-rom bdu-xs10s-hp light scribe dvd-rw windows vista 64bit samsung 24"x2, 92" with sim c3x 1080p pj
broken hp lol Toughpower 1200 watt cosmos s g5
Who's next
post #4 of 14
If you has the cash then why not?
Smee 2.0
(14 items)
Smee 2.0
(14 items)
post #5 of 14
I would recommend the 780i but not tri-sli...tri-sli with the 8800GTXs are not justified by the performance price ratio but I would suggest 8800GTs you can easily get close to 16k and above with 8800GT SLI and that Q6600 upped a bit more to maybe 3.2-3.6 very solid board with the P03 bios
LittleDevil
i7 930 Asus Rampage III Gene EVGA GTX 470 Corsair Dominator 3 x 2GB DDR3 1600
OCZ Vertex 2 60GB SSD Windows 7 Home premium 64-bit Samsung P2770H Logitech G19
PowerCaseMouse
Corsair HX750W NZXT Vulcan Logitech G9
LittleDevil
PowerCaseMouse
post #6 of 14
I haven't been thrilled so far. Some of the problems are endemic Nvidia, some are construction, some are the 780i being a warmed over 680i. If SLI is important, I would get the 790i and DDR3.
Now the board I have is really the reference design. Maybe the Asus is better.
Number 1
Q6600 B3 EVGA 780i A1 MSI GTX260/192 2x2GB Corsair Dominator PC1066
1x500GB Maxtor 1 Asus SATA Vista x64 Ultimate 32" 1080P TV
Logitech Wave USB 1000w Cooler Master Lian Li V2000 Ideazon Reaper Edge
Mouse Pad
QPad QT-R
Number 1
Mouse Pad
QPad QT-R
post #7 of 14
I would hold off until some of the known issues have been resolved.
Tae
New Build
Q6600/3.2GHz/1.375V@BIOS eVGA 780i eVGA 8800GTX G.Skill/4x2GB/4-4-4-10-2T/800
Seagate 7200.11/1TB Samsung 20X DVD XP/Vista 64-bit/Working on OSx86 Samsung 2693HM - 25.5"
Saitek Eclipse PC Power & Cooling 750W Antec P182 Logitech G5
New Build
post #8 of 14
Tae
like? some dvd sata drives not being recognized? or is their others that I don't know of?
btw mines doesnt have the dvd player sata problem I actually have an hp dvdrom with lightscribe and a blu ray sony sata drive and no problems with either.
Who's next
Who's next
post #9 of 14
I've never had a sata dvd issue either (plextor sata). the boards (I have 2) are excellent and very stable overclockers. SLI has improved dramatically as well.
Murder Box II
(18 items)
Home PC
(15 items)
Intel 8700k Gigabyte Aorus Z370 Gaming 7 Zotac 1080Ti AMP Extreme Edition G. Skill Trident Z - 32GB/ 3200Hz/CL14/Dual
Hard DriveCoolingOSMonitor
Sandisk Extreme Pro 480GB Swiftech H240 X2 Prestige AIO Windows 10 Home 64 Bit Acer Z35P 1440P G-Sync
Delux T9 Pro / Logitech K360 EVGA Supernova G2 1000W Corsair 750D Airflow Mionix Naos 7000
Mouse PadAudioAudioOther
Perixx DX-3000LAL Aluminum Sound Blaster Z Logitech Z906 - 5.1 Maxnomic Commander S-III Gaming Chair
Intel G3440 Asus B85M-E/CSM EVGA GTX 950 Patriot Viper 3 - 2x8GB 1600hz
Samsung EVO 850 - 500GB + 4TB/3TB x 2/2TB WD Green LG CH12LS28 Bluray Scythe Big Shuriken 2 w/Corsair SP120 Fan Windows 10 64 Bit
Samsung 75" TV.... GooBang Doo MX3 Corsair CX430 V2 NMEDIAPC HTPC 6000B w/ Pro LCD Module
Mouse
GooBang Doo MX3
Murder Box II
(18 items)
Home PC
(15 items)
Mouse
GooBang Doo MX3
post #10 of 14
I heard some issues with not being able to use the burn feature of certain SATA DVD drives. However, the problem I'm experiencing is my optical SATA drives causing constant BSOD's. The issue has been recognized by eVGA and NVIDIA I believe. eVGA for sure because they stated that it was a chipset driver issue and put out new beta drivers for the chipset. Unfortunately for me, the beta is only for Windows XP (I think 32-bit only). I am currently running Vista. I tend to think it's more of a BIOS issue from my attempt to isolate the issue. Either way, I hope they put out a solution soon.
You can check out the evga forums for this issue and other issues such as FF codes. Personally, I haven't ran into the FF code issue, but the BSOD issue is driving me nuts. Or you can just Google "780i BSOD SATA optical" and you'll see some of the complaints.
Tae
New Build
New Build
  Back to Forum: Intel Motherboards
