Overclock.net › Forums › AMD › AMD CPUs › 4200+ OC'd
4200+ OC'd
post #1 of 28
i am using a ECS KN3 SLI2(1.0) with a AMD athlon x2 64 dual core @2.2Ghz
in the bios i set the Voltage to 1.4v droped the HT to x4 and pushed the core up to 2.5ghz well 2.497
Pew Pew
i5 2600k @4.1Ghz ASRock Z68 Extreme3 Gen3 1050 G-Skill Sniper 16GB
WD 500GB DVD burner Corsair H80 win7 64bit
Asus 144hz 1ms / Optiquest Q7 19" MS x4 Sidewinder Thermaltake TP 850w Modular Corsair 800D
Mouse
G400
Pew Pew
Mouse
G400
post #2 of 28
Keep going. That chip should get 2.8ish. Maybe more. Just keep the temps under 50c and don't go any higher than 1.55 for cpu voltage.
My Sandy Rig
(14 items)
Intel i7 2700K 4.8ghz @ 1.32 vcore Asus P8Z68-V/Gen3 PowerColor 7950 Boost Patriot DDR3 1600 4gb x 2
WD 1TB, 750 black LG SATA DVD burner Corsair A70 dual fan 7 Home Premium 64bit
Zalman 23"  Azio PC P & C 750 Silencer NZXT ZERO
MouseMouse Pad
Logitech MX-500 Laser My Desk
My Sandy Rig
(14 items)
MouseMouse Pad
post #3 of 28
Definitely push it. I got 2.7 Ghz on stock voltage so you really shouldn't have a problem.
post #4 of 28
i have a problem going over 2.5 it blue screens on me. and cant go past 10 mins of bieng up before it bluescreens.
Pew Pew
Mouse
G400
Pew Pew
Mouse
G400
post #5 of 28
Have you bumped up the chipset voltage a notch or two? Is your memory on a divider?
My Sandy Rig
(14 items)
MouseMouse Pad
My Sandy Rig
(14 items)
MouseMouse Pad
post #6 of 28
i can only put the voltage to a max of 1.4v at witch its currently set to. and quite stable. but anything past that kills it. and im not sure about memory so here is a link.
*Edit*
not sure witch voltage i should be changing. if some one could link some thread i could find out i would love it.
Pew Pew
Mouse
G400
Pew Pew
Mouse
G400
post #7 of 28
Theres cpuvid and memory voltage. You should be able to push the cpuvid past 1.4. Post a pic of your bios if you need some help
And then
Phenom 9750 @ 3.0 Foxconn A7DA-S XFX HD4770 G.Skill Pi Black 2x2GB
40GB Intel X25-V & 2.5TB Storage Samsung DVD/RW SATA Vista x64 Envision 22"
PowerCase
Antec Basiq Plus 550w Rocketfish Lian Li
And then
PowerCase
post #8 of 28
Defiantly try upping your cpu voltage. Or you also might try slowing your memory speed. Since you're using DDR2 800 RAM which runs stock at 400MHz, and it's currently running at 416. Don't know what kind of memory you are using, but mine was very touchy.
Alpha
AMD 4000+ x2 Brisbane @2.85GHz GA-MA78GM-S2H Intergrated ATI Radeon HD 3200 2GB AData DDR2 800
2 Western Digital HDs, 80GB/160GB Samsung SATA DVD+RW/DVD-RW Windows Vista Ultimate x64 SP1 Samsung SyncMaster 932BW
Power
TurboLink 500W
Alpha
Power
TurboLink 500W
post #9 of 28
I had that same A-data ram before. Worst overclocking ram ever..even when I tried tightening or loosening timings it would not go beyond 400mhz.
And then
PowerCase
And then
PowerCase
post #10 of 28
Yea it is! Plan on upgrading to Ballistix DDR2 1066 later this year along with a Phenom.
Alpha
Power
TurboLink 500W
Alpha
Power
TurboLink 500W
  Back to Forum: AMD CPUs
