667 to 800??
post #1 of 7
my HP dv9620us has 2 gb of DDR2 667 (PC2 5300).
i want to get better memory for it, and at the laptop memory prices im a fool not to. BUT should i stay with the same memory
DDR2 667 (PC2 5300)
or go with
DDR2 800(PC2 6400)
will the computer even benefit from the higher speed? or even accept it?
while im at it, should i just get 4 gb? the laptop has vista x32. and yes i know it only uses 3 gb, but again at the prices of laptop memory im a fool not to, i thought the sp2 of vista was gonna fix the 3gb issues too.
The Cat Box
(14 items)
CPUGraphicsRAMHard Drive
i7-2820QM NVIDIA 555M 8gb Kingston HyperX DDR3 1600 500GB internal, 1TB external
Optical DriveOSMonitorKeyboard
Dual Layer DVD Windows 7 17.3" 1080p Back-lit
PowerCaseMouseMouse Pad
90w power brick Dell XPS Logitech Anywhere Mouse MX SteelSeries 5L
Audio
JBL built in 2.1 speakers, Bose 2.1 desktop audio
The Cat Box
(14 items)
Audio
post #2 of 7
I think it would make a small difference, but you laptop is unlikely to accept it. And yes, you may as well pick up 4gb.
Dark Helmet
Q6600 G0 @ 3.4ghz, 1.39v DFI LP UT P35-T2R XFX 6970 4gb G.Skill PC8000, 2gb G.Skill PC8500
Hard DriveOSMonitorKeyboard
OCZ Vertex 2 60gb, WD Black 1tb, Samsung F1 1tb Windows 7 x64 Samsung 206bw Razer Tarantula
PowerCaseMouse
Seasonic X650 Antec P182 Razer DeathAdder
Dark Helmet
PowerCaseMouse
post #3 of 7
run cpu-z, see what your processor is running at with the ram
667 should be enough
quad core madness
(14 items)
Lapped Intel Core 2 Quad - Q6600 G0 Stepping Asus P5K Deluxe WiFi ATi Sapphire HD 6950 2GB Unlocked 8GB G.Skill Pi Black DDR2-800 PC2-6400
60GB OCZ Solid 2 SSD Samsung SATA 18X DVD Burner Windows 7 Ultimate x64 Dell 3007WFP-HC + 2x 2007FP in PLP
Ducky Shine Blue, MX Red Corsair HX620 620W Lian Li V1000 Plus Black Razer Mamba 2012
Mouse PadAudio
XTrack Ripper XL Creative X-Fi XtremeMusic
quad core madness
(14 items)
Mouse PadAudio
post #4 of 7
Most notebooks on the market don't use DDR2-800 since the 965xM series of Intel chipsets is limited to DDR2-667.
The only ones that do seem to be desktop-book machines like the Asus C90S, which runs on a different chipset.
You'll be best using 667.
Deep Blue Acer
Core 2 Duo T5550 @ 1.83 GHz GeForce 9500M GS 512MB DDR2 3GB DDR2-667 Western Digital 320GB 5400rpm
Optical DriveOSMonitorPower
DVD±RW/BD-ROM Windows Vista Home Premium SP1 16" WXGA LCD 4800 mAh Eight-Cell Battery
Mouse
USB Optical
Deep Blue Acer
Mouse
USB Optical
post #5 of 7
The notebook will match the chipset's capabilities, and no faster. S if you buy the 800, it will run at 667. Your best bet is to make sure and get cas4 ram. My HP dv2125nr is running 2x2Gb G.Skill at cas 4 without a single problem.
And to answer the question about the 4Gb of ram in 32, that will never change. All the SP fixes is the amount of ram the OS recognizes. So if you have 4Gb of ram in a 32bit OS, the OS will report 4Gb, but only use approx. 3Gb.
My System
(16 items)
6850K ASUS X99-AII eVGA GTX 1060 32Gb Team Vulcan DDR4 3000 Cas 15
Samsung 960 EVO NVME Crucial M500 Seagate HDD Samsung F3
CoolingOSMonitorKeyboard
H100i Windows 10 Pro 64 Samsung KU6300 40" Corsair K70 Vengeance
PowerCaseMouse
Seasonic Gold 750W Phantek Enthoo Pro M Logitech G9X
My System
(16 items)
PowerCaseMouse
post #6 of 7
There is no service pack that can fix the 3GB issue. Its a limitation of the 32bit architecture. The fix is to use 64 bit. There is nothing you can do to fully utilized 4GB of ram in a 32bit world.
You can enable the Physical Address Extension for RAM to try and better utilize what you have, but you will never get the full 4GB.
With my desktop I was only able to get 2.75GB in 32bit windows before I upgraded to 64bit. Some of the limitation is affected by motherboard and processor as well. Some people have been able to get as high as 3.5GB, but that is the maximum you can hope for and there is no guarantee you will get that high.
So yes, RAM prices might be great now, but if I was you I would try and see if you can borrow another 2GB from someone and test it out first, because the last thing you want to do is drop some $$$ on 2GB of ram, and only be able to use 750MB of it.
My system
Intel E8400 @4Ghz EVGA 780i XFX HD 5850 4GB G.Skill@900Mhz 1:1 Synced
640GB WD AAKS, 200GB Maxtor 16X DL w/Lightscribe Win7 x64 19" CRT
Logitech Multimedia Ultra X3 1000w CM 690 Roccat Kone v2
Mouse Pad
FuncPad
My system
Mouse Pad
FuncPad
post #7 of 7
thanks evryone, i will be getting the 667 after all. sorry it took so long to respond, had to flatline the ol computer
The Cat Box
(14 items)
Audio
The Cat Box
(14 items)
Audio
  Back to Forum: Laptops and Netbooks
