Overclock.net › Forums › Graphics Cards › NVIDIA › 702 Core clock good OC? at 8800 640 SuperClocked (576Mhz)
post #1 of 10
I was wondering is 702 at core clock good result ?
normal default is 576 at core clock
earlier when i was OCing it like hmm 2 months ago i couldn't get more then 648 hmm strange hmmmm
Intel Core i5 2500K @40x100 Z77A-G43 (MS-7758) MSI RADEON R9 290 GAMING DDR3 CRUCIAL Ballistix Sport bls2cp4g3d1609ds1s...
ADATA SSD S510 120GB WDC WD6400AAKS-65A7B2  SP V70 Asus DVD+/-RW DRW- 2014L1T LightScribe Sata
CoolingOSMonitorPower
Thermaltake ISCG-200 Windows Vista™ Business 64 bit 22'' LG Flatron L226WA-WN OCZ 700W - OCZ700MXSP-EU
CaseMouseMouse PadAudio
Tt Armor VA8003BWS A4Tech X7 Collectionear edition MASS EFFFECT Logitech Z-2300
post #2 of 10
Not bad! Sounds good to me! The (G92) gets more... but that looks good to me!
WaterWorks
Core 2 Quad Q6700 (3.79GHz) ASUS Maximus Formula X38 PNY XLR8 GTX280 1024MB 6GB Dual Channel PC6400 5-4-4-12 (800MHz)
1.18TB RAID 0 + 500GB RAID 0 + 400GB Spare Lite-On Blu-Ray Drive Windows 7 Ultimate x64 I-INC 28" HDMI 1920x1200
Logitch G15 Corsair 900w Cooler Master Cosmos 1000 (Modded) Logitch G5
Mouse Pad
Ergonomic Wrist Support
WaterWorks
Mouse Pad
post #3 of 10
Look in GPU-z I bet you have an A3 revision core, they overclock miles as they are meant for the Ultra.
PC
(14 items)
i5 2500k @ 4.7Ghz Asus P8 P67 Zotac GTX 970 8GB Corsair 1600Mhz
Hard DriveOSMonitorKeyboard
256GB SSD Windows 10 24" 120Hz 1920x1080 Microsoft Sidewinder
PowerCaseMouseMouse Pad
Silverstone ST1000W Antec 900 MX518 SteelSeries SX
Audio
Sennheiser HD650
PC
(14 items)
Audio
Sennheiser HD650
post #4 of 10
thats a nice OC and yes check the revision i had a A3 320mb that did 683 on the core.
Lurking Ninja
Intel Core i7 920 D0 3849B203 4.0GHz/1.164 Evga X58 Classified E759/Koolance X58/BIX 120 TRI SLI GTX 285s.** 6GB 3x2 OCZ Gold 1600mhz
2x WD3200AAKS (RAID0), 1tb AALS Samsumg Wrigtmaster Sb 204/182 Windows 7 Ultimate X64 Gateway HD2401 24"
Logitech G15 V1 Corsair HX1000W Modded Rocketfish Logitech MX Revolution
Mouse Pad
soft cotton?
Lurking Ninja
Mouse Pad
soft cotton?
post #5 of 10
hmm it is unstable or dunno wth even at 684 675 ..
post #6 of 10
675/999 was the most I ever got out of my evga sc 320MB. And I don't think I ever seen a higher OC on a G80 stock. So don't be surprised that your 700 wasn't stable. Ref clocks are only 500, so 700 would be a 40% overclock. OC % increases from reference that high are pretty rare.
xeon X5675 6-core @ 4.1ghz (1.29v, 20x205 +ht ) rampage iii extreme msi rx470 gaming X (the $159 budget king) 3 x 2gb corsair xms3 pc12800 (9-9-9-24-1T@1600MHz)
hynix 250gb ssd (boot), 2tb deskstar (apps),1tb... plextor px-712sa - still the best optical drive... corsair h8o v2 aio W10 home
MonitorPowerCaseAudio
asus vw266h 25.5" (1920x1200) abs sl (enermax revolution) * single 70A rail 850w silverstone rv-03 XFi Titanium
post #7 of 10
I can get 645 core stable when benching, although I keep them at 600 core as the heat build up is hellish.
Blitz
(10 items)
i7 4770k MSI Z87 MPOWER Gigabye GTX970 Corsair Vengeance Pro
Hard DriveCoolingOSPower
Seagate 600 SSD Corsair H55 Windows 8.1 Pro x64 Corsair TX 750
CaseMouse
Fractal Designs R4 Refine Logitech G500
Blitz
(10 items)
CaseMouse
post #8 of 10
My 8800gts 640mb runs 3dmark 06 no problem at 700mhz. It's a little wierd though because when I run it at 690mhz I get a higher 3dmark. Once I get to 715 it gets unstable. I always run the memory clock at 1100.
And I do have the A3 revision. I haven't ever gotten temps over 58c.
First Build
q6600 B3 @ 3.2ghz lapped EVGA 680i SLi 8800gts 640mb @ 680/1100 2x 1gb crucial ddr2 800 @ 950 4-4-4-12
Hard DriveOSKeyboardPower
Seagate 320gb windows xp sp2 & vista 32bit Logitech G15 Tagan 700w
CaseMouse
Antec 900 Logitech G9
First Build
CaseMouse
post #9 of 10
with the 320 a2 core i had i was able to get it to 680/1100
Coeus
Amd Ryzen 5 1600x broken Evga GTX 1060 SSC Corsair Vengeance LPX
San Disc SSD need Windows 10 64bit Sharp 32inch
Power
Thermaltake 1350
Coeus
Power
Thermaltake 1350
post #10 of 10
I see
hmm i was wondering to change that GTS to GT 8800 is that even a good idea ??
it got a little more SP
so would it be a good idea or not ?
  Back to Forum: NVIDIA
