Overclock.net › Forums › Components › Hard Drives & Storage › 7200 vs 10000
7200 vs 10000
post #1 of 17
are the 10k rpms drive worth the buy over the 7200's? is there a noticeable difference? and also what is "raid 0"
Cyclone 900
Q6700 2.66 Ghz Quad Core [OC 3.20Ghz 24/7] EVGA NVIDIA nForce 750i SLI EVGA GeForce 8800GTS KO (G92) 512MB G.Skill 4GB (2x2GB) DDR2 1000
WD Caviar 640GB 7200 Rpm 16MB Cache SAMSUNG 20X DVD±R DVD Burner/LightScribe X2 Windows 7 ENTERPRISE 64bit HP w2207h 22"
Microsoft CORSAIR 750W Antec Nine Hundred Black Steel Microsoft Wireless
Mouse Pad
Gel Pad!
Cyclone 900
Mouse Pad
Gel Pad!
post #2 of 17
Single drive to single drive, it depends... Some of the newer 7200 SATA drives come very close in performance to a Raptor at a price that definitely makes them an attractive purchase versus performance.
Depends... the initial seek time of a Raptor is faster, however the sustained read/write times of the 7200 SATA drives in some cases is faster than a Raptor. It just depends on what you are doing.
I'd suggest that you go read this: http://en.wikipedia.org/wiki/RAID
Raid 0
Striped set without parity/[Non-Redundant Array]. Provides improved performance and additional storage but no fault tolerance. Any disk failure destroys the array, which becomes more likely with more disks in the array. A single disk failure destroys the entire array because when data is written to a RAID 0 drive, the data is broken into fragments. The number of fragments is dictated by the number of disks in the drive. The fragments are written to their respective disks simultaneously on the same sector. This allows smaller sections of the entire chunk of data to be read off the drive in parallel, giving this type of arrangement huge bandwidth. RAID 0 does not implement error checking so any error is unrecoverable. More disks in the array means higher bandwidth, but greater risk of data loss.
Darkside of Fury
Fast and Furious
(11 items)
Intel I7 930 MSI X58 Pro-E XFX Radeon 5850 Black Edition 6GB Kingston HyperX 1600
OCZ 128GB Vertex 2 SSD Samsung 223L Windows 7 Ultimate 64 bit Asus 26" LCD
Logitech G15 Enermax Revolution 85+ CoolerMaster ATCS 840 Logitech G9
Intel Core i3/i5/i7 Z77 MPower (MS-7751) NVIDIA GeForce GTX 670 G-Skill
OCZ Vertex 4 Lite-on DVD Corsair H100 Windows 7 Ultimate
PowerCaseMouse
CoolerMaster Silent Pro 1050 CoolerMaster 690 II Advanced Cyborg MMO 7
Darkside of Fury
Fast and Furious
(11 items)
PowerCaseMouse
post #3 of 17
However, the upcoming VelociRaptor is far beyond any current 7200RPM drive. It is 40% faster!
Here's another good site on RAID with visual aids: www.acnc.com/raid.html
Once again...
i7 920 [4.28GHz, HT] Asus P6T + Broadcom NetXtreme II VisionTek HD5850 [900/1200] + Galaxy GT240 2x4GB G.Skill Ripjaw X [1632 MHz]
Hard DriveOSMonitorKeyboard
Intel X25-M 160GB + 3xRAID0 500GB 7200.12 Window 7 Pro 64 Acer H243H + Samsung 226BW XARMOR-U9BL
PowerCaseMouseMouse Pad
Antec Truepower New 750W Li Lian PC-V2100 [10x120mm fans] Logitech G9 X-Trac Pro
Once again...
post #4 of 17
Depends on what you consider "worth the buy".
Most consumer level 10k rpm drives (i.e. WD raptors), are only slightly faster, overall, than a recent, good 7200rpm drive. In many areas the newest 7,200rpm drives are faster than the raptors. You will also get about three to five times as much space per dollar.
The newest 10k rpm raptors, the Velociraptor, is a substantal improvement over the older raptors, and is all round faster than any 7,200rpm drive. However, the difference in many real world tasks is still not huge, but the cost is.
The reason lower RPM drives are able to compete is because they tend to have much higher areal density on their platters. Essentially more data goes under the read/write heads with each rotation, because the bits are packed closer together. They cannot beat the random access times of the 10k rpm drives, but acess times are only one factor among many.
The best value among drives right now are the new 7,200rpm WD drives with 320GB platters, the Samsung Spinpoint F1s (334GB platter size), and the Seagate 7200.11s, or revised 7200.10s (250GB platters). All of these drives are quite fast and have transfer rates that will match, or beat, most 10k rpm drives. As noted, they do lag behind the 10k rpm drives in access times, but overall performance is usually not far off.
RAID 0 is essentially running two (or more) drives in tandem for twice (or more) the theoretical transfer speeds. Data is split into chunks which are split between the various drives. Pros are improved performance. Cons are increased chances of failure and data loss. When any drive in the RAID 0 is lost, all (or nearly all) data is lost.
Primary
(15 items)
Secondary
In progress
(10 items)
5820K @ 4.2/3.5GHz core/uncore, 1.175/1.15v Gigabyte X99 SOC Champion (F22n) Gigabyte AORUS GTX 1080 Ti (F3P) @ 2025/1485, 1... 4x4GiB Crucial @ 2667, 12-12-12-28-T1, 1.34v
Hard DriveHard DriveHard DriveCooling
Plextor M6e 128GB (fw 1.06) M.2 (PCI-E 2.0 2x) 2x Crucial M4 256GB 4x WD Scorpio Black 500GB Noctua NH-D15
OSMonitorKeyboardPower
Windows 7 Professional x64 SP1 BenQ BL3200PT Filco Majestouch Tenkeyless (MX Brown) Corsair RM1000x
CaseMouseAudio
Fractal Design Define R4 Logitech G402 Realtek ALC1150 + M-Audio AV40
X5670 @ 4.4/3.2GHz core/uncore, 1.36 vcore, 1.2... Gigabyte X58A-UD5 r2.0 w/FF3mod10 BIOS Sapphire Fury Nitro OC+ @ 1053/500, 1.225vGPU/1... 2x Samsung MV-3V4G3D/US @ 2000, 10-11-11-30-T1,...
1x Crucial BLT4G3D1608ET3LX0 @ 2000, 10-11-11-3... OCZ (Toshiba) Trion 150 120GB Hyundai Sapphire 120GB 3x Hitachi Deskstar 7k1000.C 1TB
CoolingOSPowerCase
Noctua NH-D14 Windows 7 Pro x64 SP1 Antec TP-750 Fractal Design R5
Audio
ASUS Xonar DS
i7-6800K @ 4.3/3.5GHz core/uncore, 1.36/1.2v ASRock X99 OC Formula (P3.10) GTX 780 (temporary) 4x4GiB Crucial DDR4-2400 @ 11-13-12-28-T2, 1.33v
Hard DriveHard DriveCoolingOS
Intel 600p 256GB NVMe 2x HGST Travelstar 7k1000 1TB Corsair H55 (temporary) Windows Server 2016 Datacenter
PowerCase
Seasonic SS-860XP2 Corsair Carbide Air 540
Primary
(15 items)
Secondary
In progress
(10 items)
CaseMouseAudio
CoolingOSPowerCase
Audio
ASUS Xonar DS
PowerCase
post #5 of 17
Raptor's are a waste of money at this point, if anything go for a velociraptor.
In Progress...
Q6600 G0 @ 3.6GHz DFI DK P35-T2RS Dark PowerColor 6870 OCZ Reaper 2 x 2 GB
Too Many Windows 7 Pro x64 Samsung 2333SW Logitech G15
PC Power & Cooling Silencer 750W Quad Antec 900 Razer Death Adder Razer Goliathus Control Edition
In Progress...
post #6 of 17
i see so im leaning twards sata now and raid sounds kinda scary... but how often do errors occur and when it means destroys the array does that mean it kills the HD im off to read your link now okay so id like to ask a favor ive got 0-150$ to spend on a hardrive can you point me in a fast direction? [new egg] thanks!
Cyclone 900
Mouse Pad
Gel Pad!
Cyclone 900
Mouse Pad
Gel Pad!
post #7 of 17
There are many possible errors that can occur. If a drive dies, you loose all your data, on all the drives in the RAID 0, but the other drives are not physically damaged and can be used again. If it's simple data corruption that makes one drive unusable, again, you lose all of your data, but the drives themselves are probably fine and can be used again.
I've lost RAID 0 arrays before. Given quality drives, a 100% stable system, and proper care/caution when doing things that could potentially corrupt data, the risk is fairly small for a two drive RAID 0.
I would generally avoid putting brand new drives into a RAID 0, because most drives that fail fail while they are new, or around the time the warranty expires. Very few drives that have been used for a few thousand hours just fail out of the blue. Not banging around the system and keeping drives between 30C and 45C is generally a good idea as well.
Primary
(15 items)
Secondary
In progress
(10 items)
CaseMouseAudio
CoolingOSPowerCase
Audio
ASUS Xonar DS
PowerCase
Primary
(15 items)
Secondary
In progress
(10 items)
CaseMouseAudio
CoolingOSPowerCase
Audio
ASUS Xonar DS
PowerCase
post #8 of 17
If you have the money to spend on one of them, then go for it...
However, performance versus price, it's not worth it (in my opinion). Maybe after the "newness" wears off, and the price comes down a bit, that stance will change.
The OP asked is it "worth" it... so in all fairness, that really does DEPEND based on how much you want to spend, and how much additional cost takes away from the "bang for the buck" factor.
I probably should have said "Current generation" Raptor in my initial response.. please pardon that being left out.
Darkside of Fury
Fast and Furious
(11 items)
PowerCaseMouse
Darkside of Fury
Fast and Furious
(11 items)
PowerCaseMouse
post #9 of 17
If you only have $150 or less to spend, then I'd recommend this drive: 750 GB Seagate 7200.11 SATA
http://www.newegg.com/Product/Produc...82E16822148298
You'd get tons of space, very fast read/write and seek times plus it won't break your budget or risk your data in a RAID 0 array (I'm not a big fan of RAID, but I don't fault the folks who are advocates of it...)
Darkside of Fury
Fast and Furious
(11 items)
PowerCaseMouse
Darkside of Fury
Fast and Furious
(11 items)
PowerCaseMouse
post #10 of 17
kk thats neat but isnt 750 gigs more then ill ever need? and the reviews say its noisy.. but other then that it looks great but i might downgrade to a 500 gig after reading all this about raid 0 is it a great deal fasteR? and when it does encounter an error is the hard dive still usable after all the data is destoried..? and how often do these errors occur or is it completely random maybe the first day you get it or not one for 10 years?
Cyclone 900
Mouse Pad
Gel Pad!
Cyclone 900
Mouse Pad
Gel Pad!
  Back to Forum: Hard Drives & Storage
