Overclock.net › Forums › Components › Memory › 8gigs???
8gigs???
post #1 of 8
i just added more ram into my system... total of 8gigs now... patriot EPP DDR2 800. for some reason it posts but wont load into vista? any ideas?? mobo is a gigabyte ga-m570sli
it's eh...
AMD 6000 X2 Gigabyte GA-M57SLI PNY 8800GT SLi(04092008) Patriot Extreme 2x2GB 6400
OSMonitorPowerCase
Windows XP Pro64(04092008) LG 222WT CoolerMaster 750 REAL POWER PRO CoolerMaster 690
Mouse
Logitech G9
it's eh...
OSMonitorPowerCase
Mouse
Logitech G9
post #2 of 8
64 bit or 32 bit
White Lantern
(16 items)
CPUMotherboardRAMHard Drive
Intel i-5 3570k ASRock Z77 Extreme6 Samsung 2x4gb  Samsung 830 128Gb SSD
WD 1Tb Caviar Blue WD 2Tb Caviar Black Samsung dvd Stock fans
OSMonitorKeyboardPower
Windows 7 Home Premium auria 27" 1440p Razer Black Widow OCZ 1000W ZX Series
CaseMouseMouse PadAudio
NZXT Switch 810 White Razer Deathadder Razer Vespula On Board
White Lantern
(16 items)
post #3 of 8
See if it loads with just your original 4gb. Then try one stick at a time and/or one slot at a time with your new ram.
EDIT: Also, don't AMD boards not like all four slots populated?
Main
Q6600@3.21GHz ASUS P5K-Deluxe 3870x2 4GB G.Skill PQs PC2-8000
Hard DriveOSMonitorKeyboard
1.32TB RAID0 & 750GB Storage Vista Home Premium 64-bit ViewSonic 22" LCD x2 Microsoft Ergonomic
PowerCaseMouseMouse Pad
SILVERSTONE ST1000 Rocket-Li Thingy Logitech G7 meh
Main
post #4 of 8
How do you mean won't load into Vista? Hard freeze? BSOD?
If your using Vista X64 make sure you have SP1 installed.
X79 Build
Intel Core i7-6950X @ 4.0Ghz Asus Rampage V Extreme [Bios:3101] 2x EVGA GeForce Titan X SC Editions in SLI 32GB (4×8) Corsair Dominator Platinums (3000Mhz)
Samsung 950 Pro 512GB M.2 Nvme 2x 256GB Vertex 4 SSD (RAID-0) 2x 2TB Seagate Barracuda [Storage] Pioneer BDR-207DBK Blu-ray Writer
CoolingOSMonitorPower
Corsair H105 (Push/Pull) Windows 10 Pro x64 2x 27" Asus PG278Q ROG Swift 144hz  Corsair AX1500i Digital ATX 80 Plus Titanium
CaseAudio
Lian Li PC-O8WX ATX Cube Case Logitech Z906 5.1 Surround
i7-3930K (C2) @ (4.6Ghz) Asus Rampage IV Extreme X79 (Bios 3204) 3x EVGA GTX780Ti's SC Editions 32GB (4x8GB) G-Skill TridentX 2400Mhz
2x 256GB OCZ Vertex 4's (RAID-0) 2x 2TB Seagate Barracuda 7200.14 64MB Cache Pioneer BDR-207DBK Blu-ray Writer Corsair H105 (Push/Pull)
OSMonitorPowerCase
Win7 Pro 64Bit & Win10 Pro 64Bit Asus ROG Swift (2560x1440 @144hz) Corsair AX1200 + Corsair RED sleeved cables Coolermaster Cosmos II Ultra
X79 Build
CaseAudio
OSMonitorPowerCase
post #5 of 8
That is due to the fact that Vista at first supports 2GB. Try and take the other 6GB out and leave 2GB and you should be fine.
Then go here and download and install it and restart. Then shutdown and install the other 6GB and start the PC again and you should be fine.
Armored MeDuSa
Q9450 ASUS Striker II Extreme 790i eVGA 9800GTX OCZ (2*2) 4GB DDR3 1333MHz
RaptorX 150GB, 2*7200.11 1TB 2*Samsung DVD-RW Vista Ultimate SP1 64Bit Samsung 2232BW 22" Widescreen
Microsoft Ergonomic Desktop 7000 Enermax Galaxy 1000W DXX Armor+ Microsoft Ergonomic Desktop 7000
Armored MeDuSa
post #6 of 8
Could be your board also try running stock if your overclocked. With my board i found out if you run 4 sticks of ram you cant overclock the bus past 420 or so without their being memory errors and not being able to boot into a os.
SABERWOLF
(18 items)
XEON-WOLF
(18 items)
Intel Core i7-6800K MSI X99A GAMING PRO CARBON EVGA GTX 1080 FTW Hydro Copper G.SKILL TridentZ Series
Hard DriveCoolingCoolingCooling
Samsung EVO 850 500 EK-SBAY Dual DDC 3.2 PWM Serial Alphacool NexXxoS ST30 Full Copper Radiator 360 Hardware Labs Black Ice SR2 Multiport Black Car...
CoolingCoolingOSMonitor
EK-CoolStream RAD XTC 420 koolance 380i Windows 10 Pro ASUS VW246H Black 24" 2ms
PowerCaseMouseAudio
SeaSonic M12D SS-850 850W  Thermaltake core x71 CM Storm Sentinel Advance II Corsair Void
X5675@4400 1.344 ASUS P6X58D-E XfX RX480 RS F3-12800CL7T-6GBPI 6-7-6-21 1T
F3-12800CL9S-4GBRL WDC WD1001FALS-00J7B1 ST31000340AS WDC WD7500AAKS-00RBA0
Hitachi HDS723020BLA642 ihas 624-A SilverStone Heligon HE01 windows 10 64 Pro
MonitorPowerCase
Vizio 42inch lcd tv CORSAIR CMPSU-950TX Modded Rocketfish
SABERWOLF
(18 items)
XEON-WOLF
(18 items)
PowerCaseMouseAudio
MonitorPowerCase
post #7 of 8
Don't know too much about AMD, but you can try to up the NB voltage just a little.
intel
I7 920 D0 4.2ghz with HT @ 1.275V Bios EVGA 3X SLI, 132-BL-E758-A1 2x XFX HD5870 in Crossfire 6gb 3x2gb Corsair XMS3 1600mhz @ 7-7-7-20
3x WD 640gb AALS Raid 0 22x Samsung SATA DVD-RW Windows 7 Dell 3008wfp IPS
Logitech G19 Corsair 850TX, 70A on a single 12v rail!! Corsair 800D Logitech G500
intel
post #8 of 8
Not exactly. AMD memory controllers prefer 2 sticks to 4. It doesn't mean 4 sticks won't work.
Like others have said, try upping the NB voltage and/or trying each stick individually.
  Back to Forum: Memory
