Overclock.net › Forums › AMD › AMD CPUs › 2100x pali or TB?
2100x pali or TB?
post #1 of 4
anyone know anything about this oldie?
ax2100dmt3c
agoia0215tdaw
94515020168
can I do anything with this?
how far can you OC the pali? do I need to do a chipmod?
so far ive found conflicting reports.
Edited by DIRTYDUCK - 5/18/08 at 9:33am
Bong Rig
E6750 @3.6 1.40v P5N-D SLI 750i EVGA 9800GX2 4Gigs G.Skill 800
40G WD IDE/250G sata 40xDVDRW Vista 64bit 22" hp A4576A
Logitech Antec 650w Neopower herbal green Logitech
Mouse Pad
Rotting blue/black neo
Bong Rig
Mouse Pad
post #2 of 4
http://www.cpu-world.com/CPUs/K7/AMD...2100DMT3C.html
thats the chip. and its not dmtsc its dmt3c
As far as chipmods, for some, yes, for some, no. There are other ways though, doing a small motherboard monitor will work (gutting an old floppy ide cable and plugging it into your socket then dropping your cpu on it.. check around)
As far as how far you can OC, I wouldnt know, I OC'd my duron 800 to 1100 stable, but I needed hella cooling, 1000 was a nice operating temp.
Apollo
Core i7 920 D0 Asus P6T Sapphire 4870X2 3x2GB OCZ Gold DDR3-1600
2 x 500gb RAID 0, 2 x 1TB Caviar Black Samsung 22x Sata DVD+-R/DL Vista x64 Acer x223w
Logitech G15 gen2 Cooler Master 850w 6 Rail Antec Twelve Hundred OCZ Equilizer
Mouse Pad
Fellowes Ergonomic Wrist Support
Apollo
Mouse Pad
post #3 of 4
thanks for the help man...when I wrote the processer type down it was hard to read becouse of the small amount of TP on it. lol dislexia? maby.
Im interested in this mod your talking about ill look into it and if you have time to talk more about it that would be great becouse im not totaly sure what your talking about...however im pretty quick to catch on.
I will have a really good cooling system pretty soon...I have all the parts for my homemade waterblock now and all I have to do is stick them all tougether and prey. Its alot nicer then what I thought I would end up with, let me tell you. (pics comming today I think)
I also have a nice industrial squirlcage fan that I can attach to my case that blows much harder then needed...I call it aircooled overkill. its loud though and after a while the housing around the motor starts to heat up a bit...im sure it just needs the nasty old grease with some fresh oil or something. the air comming out dosnt seem to be changed much.
so im not worried about heat for the most part I guess. I do have enough old parts that I can tear up some stuff and not cry about it.
Tell me more!
Bong Rig
Mouse Pad
Bong Rig
Mouse Pad
post #4 of 4
ok so I love this guide you gave me...the more i play with it the more I understand it...
this is what I have, I think.
Athlon XP (Palomino) Desktop Processor (Model 6) 1733 MHz
OPGA Organic Pin Grid Array 1.75 Volt max. Temp. 90°C
256 KB L2 Cache 266 MHz Systembus (133 MHz FSB) x 13
With this sweet guide
http://www.ocinside.de/go_e.html?htt...md_pinmod.html
im not affraid to push it to the limit but if anyone can sudgest a good starting point that would be super!
Bong Rig
Mouse Pad
Bong Rig
Mouse Pad
  Back to Forum: AMD CPUs
