75Hz?
post #1 of 14
Hello,
I recently went to 75Hz, finding out my monitor can display it, but every so often the screen will go black for about 10 seconds then come back?
Help?
Thanks
lulwut
Intel Core i5-2500K GigaByte P67A-UD3P-B3 Sapphire Radeon HD5850 1GB 4x2GB Corsair 1600MHz
1x 1TB & 1x 250GB Lite-On SATA DVD-RW Windows 7 Professional x64 Dell SP2309W @ 2048x1152
Saitek Eclipse II Corsair HX620w CM-690 Logitech MX518
lulwut
post #2 of 14
there is no need for LCDs to display higher that 60hz.
post #3 of 14
Yes there is. 75 refreshes in a second is better than 60 last time I checked, which allows for higher actual framerates in games. A monitor going blank is pretty funky. Have you tried using another cable?
Indigo Hammer
(5 items)
Blue Danube
(7 items)
CPUGraphicsOSKeyboard
Core i5-4250U Intel HD5000 OS X 10.8.4 Filco Minila Air - MX Blue
Audio
TCA Gizmo > Axiom Audio M2ti
Indigo Hammer
(5 items)
Blue Danube
(7 items)
Audio
post #4 of 14
I run all of my LCDs @ 75hz... heck the one I'm using @ work is running 75hz.
Q8400 DFI LP DK P45-T2RS eVGA GTX 650 Kingston
2.8TB Total LG Super DVD Burner SATA VII Enterprise x64 Gateway FHD2401
PowerCaseMouseMouse Pad
Corsair VX550W NZXT Source 210 White Logitech G400 Razer Kabuto
Audio
Creative Audigy
Audio
Creative Audigy
post #5 of 14
for CRTs maybe, LCD's don't have the flicker problem that CRT's do because LCD's don't actually turn on and off, but rather they just change colors.
post #6 of 14
Could be an overheating issue? I don't know if refresh rate is necessarily correlated to heat output, but it might be, and it might be causing overheating. I'd say put it back to the lowest supported refresh rate and see if that helps. Also, keep in mind, you can force your monitor to use refresh rates higher than what it is rated for--so just 'cause you can doesn't mean you should.
i5-2500K Biostar TP67B+ XFX HD5750 1GB 2x4GB DDR3 Corsair 1600
Hard DriveOSMonitorPower
60GB OCZ SSD, 2x160GB HDD RAID0, 500GB+500GB+1.5TB Windows 7 Ultimate 64-bit Samsung SyncMaster 930B Antec SmartPower 450w
Antec 900
Antec 900
post #7 of 14
And at 75 hz, they change color faster. They don't put a CRT rating on LCDs just for the lulz.
Indigo Hammer
(5 items)
Blue Danube
(7 items)
Audio
Indigo Hammer
(5 items)
Blue Danube
(7 items)
Audio
post #8 of 14
Noting is overheating, and my Monitor apparently can use 75Hz according to the internet.
lulwut
lulwut
post #9 of 14
Well, just 'cause the monitor itself doesn't feel any warmer than usual, it doesn't mean it's not overheating. My girlfriend had a samsung monitor that would just go black all of a sudden (for longer than 10 seconds). Turns out it was getting too hot and one of the electrical connections/solder joints was coming loose when the components heated up and expanded. But hers would happen only when it got warm in the apartment, like above 75-80F. Have you tried blowing a fan over/around your monitor for better airflow to see if that helps? Overheating is the only thing that comes to mind...sorry!
Antec 900
Antec 900
post #10 of 14
I think it only happens when playing games O_o
lulwut
lulwut
  Back to Forum: Monitors and Displays
