9300 vs 8300
post #1 of 11
I am going to be swapping my T5550 for a 9300 or an 8300 in th enext few months. I know the 9300 is the penryn and am curious it is worth the 100 dollar price difference to get the 9300. Ive got a 8400gs vid card and 4gb ram, should I swap the video card while I am at it or will the proc upgrade give my laptop some guts? basically want to know if its worht 100 more dollars to get the 9300
Chatterwhite
(17 items)
Intel Core i5 4670k GRYPHON Z87 NVIDIA GeForce GTX 970 NVIDIA GeForce GTX 970
GraphicsRAMHard DriveHard Drive
Intel(R) HD Graphics 4600 g.skill sniper 1866 8GB Mushkin Chronos 120GB Kingston SSD Now v300 256GB
Hard DriveCoolingOSMonitor
2x WD Black in RAID 0 4TB Coolermaster Nepton 140XL Windows 10 Pro Yamakasi Catleap 1440P
ASUS V24H Corsair C70 EVGA Supernova 750 Thermaltake core v21
Mouse
Roccat Kone+
Chatterwhite
(17 items)
Mouse
Roccat Kone+
post #2 of 11
I don't think you can change the video card. Why are you getting a new processor, are you going to be doing cpu intensive work on it?
Heisenberg
(16 items)
Core i7 4930k Asus RIV BE HIS HD7970x3 4x4GB Corsair 2133
Hard DriveHard DriveHard DriveCooling
Samsung 840 Evo 500GB 2 Crucial m4 256gb raid 0 4TB Hitachi EK rivbe monoblock + ek 7970fc
OSMonitorKeyboardPower
Windows 8.1 Pro 27" LED Cinema + 27" Auria 2560x1440 Mionix Zibal 60 Corsair ax1200i
CaseMouseAudioAudio
Case Labs TH10 Mionix Naos 5000 Asus Xonar d2x Teac ha-501 amp & hd650/dt880 600 ohm cans
Heisenberg
(16 items)
CaseMouseAudioAudio
post #3 of 11
Yes get the 9300. Its got 2x the L2 Cache. The 9300 is one of the best C2D CPUs out right not besides the extreme series.
 iMac
Intel® i3 3.06GHz Apple Logic Board ATI® 4670 4GB DDR3 1333
Seagate Barracuda 500Gb 7200RPM 8x Superdrive Mac OS X 10.6.4 Snow Leopard 21.5" LED Backlit 1920x1080
CaseMouse
Aluminum Unibody Magic Mouse
 iMac
CaseMouse
post #4 of 11
I dont think you need more power in laptop or is it just me. You video card is way to low for the CPU you allready have so no point really.
Ishimura
(21 items)
Silent Knight
Intel Core i7 3770K @ 4.6GHz ASRock Z77E-ITX eVGA GTX 1080 Ti Hybrid AMD Radeon R9 16GB DDR3-2400MHz
Hard DriveHard DriveCoolingCooling
SanDisk Ultra II 960GB Toshiba X300 5TB Corsair H100i GTX eVGA Hybrid Water Cooler
CoolingOSMonitorKeyboard
4x GentleTyphoon AP-15 Windows 10 Pro 64-Bit Philips Brilliance BDM4065UC 4K Razer BlackWidow Chroma
PowerCaseMouseMouse Pad
eVGA SuperNOVA 750 G3 Define Nano S Logitech G502 Proteus Core PECHAM Gaming Mouse Pad XX-Large
AudioAudioAudioAudio
Audioengine D1 DAC Mackie CR Series CR3 Audio-Technica ATH-M50 Sennheiser HD 598
Audio
Sony XB950BT
AMD Phenom II X4 955 @ 4.2GHz ASUS M4A79XTD EVO AMD Radeon HD 7970 3GB @ 1200/1500 2x 4GB G.SKILL Ripjaws X DDR3-1600
OCZ Agility 3 60GB WD Caviar Green 1.5TB 2 x Seagate Barracuda 2TB XSPC Raystorm
CoolingCoolingOSPower
EK-FC7970 XSPC RS360 Windows 10 Pro 64-Bit Corsair TX750
NZXT Switch 810
Ishimura
(21 items)
Silent Knight
Audio
Sony XB950BT
NZXT Switch 810
post #5 of 11
no its not just you, i posted the same thing... and vostro, we're talking about laptop processors, not q9300...
Heisenberg
(16 items)
CaseMouseAudioAudio
Heisenberg
(16 items)
CaseMouseAudioAudio
post #6 of 11
Originally Posted by Vostro View Post
Yes get the 9300. Its got 2x the L2 Cache. The 9300 is one of the best C2D CPUs out right not besides the extreme series.[/B]
I know the T8300 and the T9300. The 8300 has 3MB L2 Cache and the 9300 has 6MB of L2 Cache like i said earlier. Its a better buy for $100 dollars more. The extreme series I talked about is the X9000 CPU that runs at 2.8 and is the only CPU that is DESIGNED to OC.
Edited by Vostro - 5/23/08 at 10:14am
 iMac
CaseMouse
 iMac
CaseMouse
post #7 of 11
Do a video card swap too. If you've got a Dell, then you probably can since you didn't go with the integrated solution to start with.
Other than that, I wouldn't buy the 9300 for $100 more, just not worth it IMO.
post #8 of 11
Thanks SGTSpike.
other guys, I do not have an integrated video card, my post says 8400GS. It is a dedicated card. The reason I am upgrading the processor is because the T5550 is weak as hell, and my wife loves to play the sims (most cpu intensive game ever imo, hope they fix their code for the next one) and I know the 5550 will explode. Its an hp laptop, the dv9000 series from best buy. I bought it for 1000 with plans to upgrade the cpu myself, it has 4gb ram, 8400gs dedicated graphics card, 320gb hdd, two hdd bays, 17"screen blah blah blah standard laptop crap. Point is I am upgrading it because I want to, and I bought it because I can upgrade it. Thanks again sgtspike for answering
Chatterwhite
(17 items)
Mouse
Roccat Kone+
Chatterwhite
(17 items)
Mouse
Roccat Kone+
post #9 of 11
And its actually the proc that is holding me back, HP kept the laptop price low by putting in a near-obsolete processor in it.
Chatterwhite
(17 items)
Mouse
Roccat Kone+
Chatterwhite
(17 items)
Mouse
Roccat Kone+
post #10 of 11
i know you have a discrete gpu, but its still not a desktop, it is really hard to upgrade graphics in a laptop. that, and the t5550 is not that weak, its a core 2, and its dual core, i don't know what sims game you're playing, but while it might be cpu dependant, i highly doubt you're going to get poor frame rates with it, you don't really even need that high of a framerate, its not an fps or anything.
Heisenberg
(16 items)
CaseMouseAudioAudio
Heisenberg
(16 items)
CaseMouseAudioAudio
  Back to Forum: Laptops and Netbooks
