8800gs
post #1 of 14
Ok first the specs
Cpu: Intel Pentium D Dual Core 2x3ghz
Ram: Buffalo 2gb Ram
HDD: 250 Gb Hdd
MOBO: GIGABYTE GA-945GZM-S2
Gpu (Was not orginally in there) XFX ALPHA DOG Nvidia 8800GS 384Mb DDR3
And my problem is the mobo supports x16 but only @x4 which i know can cause a big proformance diference in cases, is it possible to change it?, ive tried the bio's but theres nothing there about it i dont think.
Can anyone help me please?
Kadejd
post #2 of 14
First of all, contrary to the guy at Best Buy, a dual core does not mean you have 6ghz =P
Second, now many video cards have you got? Just the one?
post #3 of 14
Yep just the one
and :O i didnt say 6ghz , just two 3ghz
post #4 of 14
It's this motherboard right? http://www.gigabyte.com.tw/Products/...ProductID=2425
Yes you do have 1 PCIe x16 running at x4, the 8800gs will take a hit in performance but only a bit. It'll be miles better than the GMA950.
My home comp
Ph II X4 955 BE (C3) Asus M2N-SLI DELUXE EVGA 8800GTS 320MB 4GB G.Skill's DDR2 800
Seagate 7200.10 320GB LG DVDRW Windows 7 x64 Dell ST2410 & Samsung 2032BW
PowerCaseMouse
Hiper 530W Antec NSK6000 Logitech MX Revolution
My home comp
PowerCaseMouse
post #5 of 14
So you mean your card at 4x?
post #6 of 14
Yep thats the one
Oh right is there any way of changing it execpt replacing the mobo?
And yes cobra, its a x16 card, running at x4
post #7 of 14
Nope no way to change without replacing the mobo.
My home comp
PowerCaseMouse
My home comp
PowerCaseMouse
post #8 of 14
try to buy new motherboard 750i or x48.
post #9 of 14
man i asked the same question ages ago about a Bord with 4x pci.. ..
2 cores running at 3ghz= 3ghz. lol i made the same mistake when, i started with computers.
6700k z 170 pro gameing GTX980 16
samsung ssd  SUPER WRITE MASTER. Cooler Master Hyper 212 Evo win10
ASUS VW 199D g510 G7.. BitFenix Merc Beta Mid ATX Case
MouseAudio
logitech m185 onbord.
MouseAudio
post #10 of 14
buy an nforce 650i for 80$ off newegg.
Po' Pimpin'
(11 items)
CPUMotherboardRAMHard Drive
i5 2500k @ stock Biostar TZ68K+ [A3] 4GB  Sandforce 1222 64GB SSD
Optical DriveCoolingOSMonitor
LG 22x DVD-+RW  Stock Windows 7 x64 Acer S211HL 1080p
PowerCaseMouse
600w Diablotek Linkworld Electronic Inland
Po' Pimpin'
(11 items)
PowerCaseMouse
