Overclock.net › Forums › Graphics Cards › NVIDIA › 1920x1200 gpu
1920x1200 gpu
post #1 of 14
I just ordered my new 24" moniter and will be soon building a new comp to accompany this beaut of a screen. I've been having difficulty deciding what i should go with for my gpu. Right now i'm debating between 8800gts g92 sli or 8800gtx sli. Will the gtx sli give me that much more performance to justify the price difference?
My System
e8500 3.16ghz evga 750i FTW evga GTX 280 SSC G. Skill DDR2 1066 (8gigs)
Hard DriveOSMonitorKeyboard
WD Caviar 640 vista spk1 home 64bit Gateway FHD2400 Logitech G15
PowerCaseMouse
Corsair 1000hx Cooler Master Cosmos S Razer Lachesis
My System
PowerCaseMouse
post #2 of 14
U could wait until June 17th for the new Nvidia cards.
Q6600 G0 @ 3.24GHz w/ 1.36v (L724A760) Gigabyte P35-DS3R rev 1.0 EVGA GTX 285 1GB + ? BIOS (720c/1512s/1377m) 8GB G.Skill PQ @ 1000MHz 5-5-5-15
2x320GB 7200.11 Raid0 + 750GB 7200.11 for Storage Samsung SH-S203B Windows 7 Pro x64 Samsung T260HD 1920x1200 + Samsung 226BW 1680x1050
Saitek Eclipse II PC Power & Cooling Silencer 750W Antec Nine Hundred Razer DeathAdder
Mouse Pad
Razer Destructor
Mouse Pad
Razer Destructor
post #3 of 14
simple answer yes
longer answer yes because of the larger ammount of Vram available, 1920x1200 requires alot of texures and the more texures you can load into the vram the better the performance or as Muhahahaha said wait for the new GTX280 cards
post #4 of 14
I would say wait for the new cards mate, no point spending bucks on old tech now.
X79 Build
Intel Core i7-6950X @ 4.0Ghz Asus Rampage V Extreme [Bios:3101] 2x EVGA GeForce Titan X SC Editions in SLI 32GB (4×8) Corsair Dominator Platinums (3000Mhz)
Samsung 950 Pro 512GB M.2 Nvme 2x 256GB Vertex 4 SSD (RAID-0) 2x 2TB Seagate Barracuda [Storage] Pioneer BDR-207DBK Blu-ray Writer
CoolingOSMonitorPower
Corsair H105 (Push/Pull) Windows 10 Pro x64 2x 27" Asus PG278Q ROG Swift 144hz  Corsair AX1500i Digital ATX 80 Plus Titanium
CaseAudio
Lian Li PC-O8WX ATX Cube Case Logitech Z906 5.1 Surround
i7-3930K (C2) @ (4.6Ghz) Asus Rampage IV Extreme X79 (Bios 3204) 3x EVGA GTX780Ti's SC Editions 32GB (4x8GB) G-Skill TridentX 2400Mhz
2x 256GB OCZ Vertex 4's (RAID-0) 2x 2TB Seagate Barracuda 7200.14 64MB Cache Pioneer BDR-207DBK Blu-ray Writer Corsair H105 (Push/Pull)
OSMonitorPowerCase
Win7 Pro 64Bit & Win10 Pro 64Bit Asus ROG Swift (2560x1440 @144hz) Corsair AX1200 + Corsair RED sleeved cables Coolermaster Cosmos II Ultra
X79 Build
CaseAudio
OSMonitorPowerCase
post #5 of 14
well i would say wait if anything. the gtx can handle 1920x1200, but it is a dated card, and cannot scale as well as the 8800gts in sli.
heres the thing though, the gts runs a 256bit bus while the gtx run a 384, which is better for high resolutions. i would wait til the next gen cards come out, or at least til they drop the prices on the curent cards.
beast iv
(11 items)
Gateway FX 6860
Intel i7 920 c0 @ 4.0ghz eVGA x58 SLI 2x EVGA GTX670 SLI OCZ Gold 6gb 1600mhz
Hard DriveHard DriveCoolingOS
Patriot Inferno 120gb SSD Seagate Barracuda LP 2tb Corsair H100 Win7 Ultimate x64
MonitorPowerCase
Samsung 245BW Corsair AX1200 CM 690 II
CPUGraphicsRAMHard Drive
T5550 8800m GTS 4gb ddr2 667mhz 320gb 5400rpm
17 in 1440x900
beast iv
(11 items)
Gateway FX 6860
MonitorPowerCase
17 in 1440x900
post #6 of 14
Wait for a little bit if you can, ATI and Nvidia both have new offerings coming out
post #7 of 14
If you cant wait GTX is the better choice when it comes to 1900*1200.
Ishimura
(21 items)
Silent Knight
Intel Core i7 3770K @ 4.6GHz ASRock Z77E-ITX eVGA GTX 1080 Ti Hybrid AMD Radeon R9 16GB DDR3-2400MHz
Hard DriveHard DriveCoolingCooling
SanDisk Ultra II 960GB Toshiba X300 5TB Corsair H100i GTX eVGA Hybrid Water Cooler
CoolingOSMonitorKeyboard
4x GentleTyphoon AP-15 Windows 10 Pro 64-Bit Philips Brilliance BDM4065UC 4K Razer BlackWidow Chroma
PowerCaseMouseMouse Pad
eVGA SuperNOVA 750 G3 Define Nano S Logitech G502 Proteus Core PECHAM Gaming Mouse Pad XX-Large
AudioAudioAudioAudio
Audioengine D1 DAC Mackie CR Series CR3 Audio-Technica ATH-M50 Sennheiser HD 598
Audio
Sony XB950BT
AMD Phenom II X4 955 @ 4.2GHz ASUS M4A79XTD EVO AMD Radeon HD 7970 3GB @ 1200/1500 2x 4GB G.SKILL Ripjaws X DDR3-1600
Hard DriveHard DriveHard DriveCooling
OCZ Agility 3 60GB WD Caviar Green 1.5TB 2 x Seagate Barracuda 2TB XSPC Raystorm
CoolingCoolingOSPower
EK-FC7970 XSPC RS360 Windows 10 Pro 64-Bit Corsair TX750
NZXT Switch 810
Ishimura
(21 items)
Silent Knight
Audio
Sony XB950BT
NZXT Switch 810
post #8 of 14
If you have the money, this is definitely going to be your best option.
If the brand isn't important to you, CrossFire 4870's should make a competitive option as well, and they could possibly end up cheaper.
post #9 of 14
Or you can do this:
Buy 2 evga 8800GTS 512's and in a couple of months use the step up and get one or two of the new GTX 280 cards.
I am doing just that but with 9800GTX's.
Lucky 7
TJ07 Type R
(12 items)
Intel Core i9 7900X @ 4.70Ghz 1.2v MSI X299 Gaming Pro Carbon 2 x eVGA Nvidia GTX1080Ti SC2 SLI  32GB Corsair Vengeance LPX 3000Mhz
Hard DriveCoolingOSMonitor
Sandisk Ultra II 960GB SSD Custom Water w/ EK XE360 & EK XRES 140 D5 & EK ... Windows 10 Pro Acer Predator XB241YU 144Hz 1440p
Razer Blackwidow Chroma V2 Corsair RM1000x w/ Sleeved cables Modded Corsair 750D Razer Deathadder Elite
Audio
Creative Soundblaster ZxR
Intel i7 950 @ 4.2Ghz ASUS Rampage III Extreme (EK Full Coverage Block) 2 x ASUS GTX480's (EK Full Cover blocks / Black... 12GB Corsair Dominator GT 1866Mhz
2 x 128GB Crucial C300 SSD (RAID 0) & Samsung F... Pioneer DVR215D Heatkiller 3.0 Full Copper / Black Ice 360GTS Windows 7 Pro
MonitorPowerCaseAudio
3 x Samsung P2450's Corsair HX1000 (Sleeved Red) Modded TJ07 ASUS Xonar STX
Lucky 7
TJ07 Type R
(12 items)
Audio
post #10 of 14
Thanks a bunch for the advice. Yeah ive been reading a bit on the new cards which probably sounds like a good idea, anyone wanna speculate on a price tag?
My System
PowerCaseMouse
My System
PowerCaseMouse
  Back to Forum: NVIDIA
