$400 Pc
post #1 of 11
I'm trying to do a $400 gaming pc for someone. It shouldn't be any problem but I thought I'd post what I have so far and see if you guys think I could do with something better. I'll be ordering tonight so suggestions before then are very welcome.
Mobo-GIGABYTE GA-P35-S3G
Cpu-E2180
Gpu-GeForce 8800 GS
Ram-SUPER TALENT 2GB
Hard drive-Seagate Barracuda 250gb
Psu-Thermaltake TR2 W0070RUC 430W
Optical drive-LITE-ON 20X DVD±R DVD
Case-Already have one.
Glados
E8400@4.05ghz DFI LANPARTY DK P35-T2RS Radeon HD 3870 X2 G.SKILL 4GB(2 x 2GB)
Hard DriveOSMonitorKeyboard
250GB Vista Premium x64/XP Pro SP3 Samsung 226BW G15
CaseMouseMouse Pad
CM690 G5 Steal Pad
Glados
CaseMouseMouse Pad
CM690 G5 Steal Pad
post #2 of 11
I just found a better video card for cheaper
8800gt
That's a killer price with the MIR. I'll post it in the deals section.
Glados
CaseMouseMouse Pad
CM690 G5 Steal Pad
Glados
CaseMouseMouse Pad
CM690 G5 Steal Pad
post #3 of 11
No complaints from me, well perhaps a X2 5000BE instead of the E2180 but there's nothing wrong with that build.
post #4 of 11
I'm trying to cut corners with stuff but I think I've chipped away at the build as much as I can.
Glados
CaseMouseMouse Pad
CM690 G5 Steal Pad
Glados
CaseMouseMouse Pad
CM690 G5 Steal Pad
post #5 of 11
Any update on this?
I ask because a cousin of mine asked about getting a new PC. He's on a P3 800Mhz... To make it worse, he has less than 512MB RAM because the onboard graphics is using some resources. He asked me what he could do to make it faster... I told him to just buy a new one!
Paradise
Phenom II X6 1055T @ 3.7ghz Gigabyte GA-890GPA-UD3H XFX 5770 Crossfire 4x2GB G.Skill Ripjaws DDR3 1600
64GB MC SSD, 2x320 7200.10, 2x2TB Green Caviar Windows 7 Ultimate Samsung 205BW & 32" Panasonic LCD G15
PowerCaseMouse
Corsair HX620 (FTW) CoolerMaster HAF 932 MX518
Paradise
PowerCaseMouse
post #6 of 11
yes...add another stick....
still it is outdated machine so he should start planning//saving for some new build...
E5200, @3.5Ghz, 1.385 :/ Asus P5E3 Deluxe Sapphire HD 4850 Kingston 2*1gb, 1333Mhz, CL9 temp
Hard DriveOSMonitorPower
WD Caviar Blue 6400 AAKS Win XP SP3 dual boot Vista Ultimate SP1 Samsung T220 Thermaltake Purepower RX 600w
NZXT Tempest
NZXT Tempest
post #7 of 11
It's a great rig, make sure you overclock the processor though
also, any winners picked yet here?
post #8 of 11
For a $400 budget I would definitely go AMD. For $400 you could get an X2 4600+ (2.4GHz), 8800GT 512mb, solid OCing mobo, 2x1GB DDR2 800, 250gb HD, SATA DVDRW, and I would recommend a Rosewill Stallion Series 450W PSU (they have some of the best-reviewed PSUs on newegg).
Shmang it
(9 items)
AMD x4 965 Gigabyte GA-78LMT-S2P ATI Radeon HD 3850 4 gb DDR3
Hard DriveOSMonitorMouse
500 gb sataII Windows 7 Acer H203H Logitech MX510
Audio
Sony MDR-V6/ Sennheiser HD580/ Klipsch + Mini S...
Shmang it
(9 items)
Audio
post #9 of 11
yeah...but no future there...he could get some lighter Intel based system, and upgrade in 2-3 months when pricecuts are expected...
NZXT Tempest
NZXT Tempest
post #10 of 11
Newegg PSU reviews = useless.
Any reviews that do not have a load tester and oscilloscope isn't a review. It is an opinion with little weight.
Once again...
i7 920 [4.28GHz, HT] Asus P6T + Broadcom NetXtreme II VisionTek HD5850 [900/1200] + Galaxy GT240 2x4GB G.Skill Ripjaw X [1632 MHz]
Intel X25-M 160GB + 3xRAID0 500GB 7200.12 Window 7 Pro 64 Acer H243H + Samsung 226BW XARMOR-U9BL
PowerCaseMouseMouse Pad
Antec Truepower New 750W Li Lian PC-V2100 [10x120mm fans] Logitech G9 X-Trac Pro
Once again...
  Back to Forum: Build Logs
