Overclock.net › Forums › Components › Monitors and Displays › 32" hdtv
32" hdtv
post #1 of 2
hey guys, my mum is getting a HDMI adapter for me because shes going shopping, and i was wondering what resolution it would output at and can i choose or is it just 1920x1080?
System J
E4500@3.3Ghz (300x11) GIGABYTE GA-EP45-UD3 Sapphire HD4870 512MB GDDR5 3GB DDR2 667Mhz@600Mhz
Seagate 500GB 7200RPM DVD-RW Windows Vista Premium 32Bit 32" widescreen (1920x1080)
HP Keyboard Active power 850Watts AEROCOOL AERO-ENGINE II SSP BLACK GAMERS CASE HP Mouse
System J
post #2 of 2
Most 32'' TVs output in 720P (lower than 1920x1080), unless you dished out extra for a 1080P 32'' TV.
If it does accept 1080P / 1080i input, I'm not sure how it would look on your TV.
You can generally choose the resolution, whether its your PC, XBOX, PS3, or dvd player. Depends on the source itself, and the capabilities of the TV. The HDMI cable will enable you to output at better resolutions as opposed to the typical RCA cable (yellow)...
Cosmos
C2D E6300 @ 2.8GHz GA-965P DS3 BFG GeForce 8800GTS OC2 2x1GB Corsair XMS2 DDR2 800
Western Digital 80gb, 250GB, 500gb 7200RPM NEC DVD+/- Burner Windows XP SP2 LG L222WT
Logitech Media Keyboard Coolermaster 600W CoolerMaster Cosmos 1000 Logitech G5
Cosmos
  Back to Forum: Monitors and Displays
