Overclock.net › Forums › Cooling › Water Cooling › 20$ pump
20$ pump - Page 2
post #11 of 16
how do you power that thing?
Home 1
(14 items)
AMD FX-6300 Vishera  ASUS M5A78L-M LX PLUS HD7950 8GB DDR3
Hard DriveCoolingOSMonitor
WD 250GB Stock Windows 10 32 inch
PowerCase
EVGA 600B Rosewill
Home 1
(14 items)
PowerCase
EVGA 600B Rosewill
post #12 of 16
hmm... I wish I would have found those pumps when I was looking at going for water cooling a couple months ago... I had a limit of $100... but couldn't really find anything decent to make myself a kit for under 150. Oh well... my tt big typhon cools great and cost me a lot less.
Darkness
(14 items)
Q6600 G0 Gigabye GA-EP45-UD3P EVGA GTX660 8GB G.Skill PK
WD 640GB & Samsung F1 750Gb LG BD & HD Windows 8 Pro x64 HP w2207
FILCO FKBN87M/NPEK Enermax Modu82+ 525w CM 690 Logitech G9x
Mouse PadAudio
Razor Destructor ODAC
Darkness
(14 items)
Mouse PadAudio
post #13 of 16
ok well they have another pump with 3 feet of head 200GPH there for like 25$ . i thought that the lower the GPH the better because it gets longer time in the radiator just as long as its not to low. and i dont care if i have to have it sitting at the bottom of my resivor. and yes im going to get parts cheap i know ppl that work at hardware store, i plan on making my water block too. so i will have a 15% discount =)
My System
CPUMotherboardOSMonitor
P4 3.0 northwood abit GURU AI7 478 xp pro 17"
PowerCaseMouse
500watt aspire aspire razer diamonback
My System
PowerCaseMouse
post #14 of 16
I think the faster gph the better. the faster the water flows through the more water is cycled through the block and radiator
Darkness
(14 items)
Mouse PadAudio
Darkness
(14 items)
Mouse PadAudio
post #15 of 16
Originally Posted by Mako
How did you set it up and how well does it work? I was curious if anyone had tried using a bilge pump.
besides it a little nosiy its ok just rap an towel or rag around it.
My System
AMD 3700 Gigabyte K8NSC Xp Pro sp2 32" lcd
Microsoft Cordless 550w Custom Microsoft Cordless
My System
post #16 of 16
Originally Posted by Jazino
yes, i too want water but not at top dollar. i saw that pump and it seems ok but im worried about leaks. may try it anyway for 20-25 shipped.
I think the only reason some people have leak problems with them is because they damage the big "O" ring some way or some foreign material gets in there. I have been using mine for a few months now with no problems and like I said if you do the impeller O ring mod it is very quiet.
Don't forget if you do use some type of submersible it will add some heat to the coolant.
My System
E8400@4.0 DFI Blood Iron EVGA 9600GT 8 Gigs Gskill pc6400
Hard DriveOSMonitorKeyboard
Maxtor Diamond Max Windows7 Pro Acer AL2016W yes
PowerCaseMouseMouse Pad
OCZ 500w SXS Ultra Aluminus yes yes
My System
  Back to Forum: Water Cooling
