Overclock.net › Forums › Components › Hard Drives & Storage › 189gb instead of 200gb. Is this common?
189gb instead of 200gb. Is this common? - Page 2
post #11 of 15
it has nothing to do with losing space during format or windows not recognizing the full size
its all completely due to numbering/ marketing... the way the #s are converted is the exact reason... its already been said so read the previous posts and youll get it
ADHDcore
Pentium4 3.0 GHz Prescott MSI 865PE Neo2-P Platinum BFG 6800GT Rev2 Corsair Platinum XMS 2x512 Meg
WD SATA 80 & 200 Gig NEC 3550A & MSI Combo Drive XP Pro KDS 19" XF-9e Xtreme Flat CRT
Memorex Multimedia 500 watt Titanium Green X-Connect Wicked Green Scorpio 868 MS Trackball Optical
ADHDcore
post #12 of 15
Older versions of Windows had problems recognizing drives larger than 127GB. If you have XP SP2, you're fine. BTW, my 160GB shows as 149 and my 250GB shows as 233. Like Spooked said, it's just due to the fact that most people think its 1000 when it's actually more. I thought there was a hard drive company that used to make it's formatted capacity the advertised, but I can't remember which and if they still do it Oh, well.
Main System
Intel Q6700 Abit IP35 Pro MSI GTX570 6GB DDR2-800 (Crucial Ballistix/G.Skill HK)
1TB; 2x640GB; 2TB DVD-RW + Combo Drive 7 Ultimate x64 Samsung 2443bwt
Microsoft Sidewinder X4 650W Antec Corsair 600T Logitech G500
Main System
post #13 of 15
Ive always hated how they do that
I bought a 1 gb memory stick for my psp and when i put it in it was only 940 mb
that was annnoying because when i bought it it was about $160 and for that price i could have got a 250 gb harddrive
Q6600/E6600/P4 515/Celery 352 ASUS P5K Premium Black Pearl PNY 8800GTX Gskill HZ 1000s D9GKX
2x WD Raptors 36gb Raid 0 Lite On Sata DVD-RW Custom XP Pro Dual 22" Westys WS
A4 Tech Slim Tagan 1100w U95 TurboJet Gigabyte 3D Aurora The Original G5
Mouse Pad
Giant Rubber / Felt Pad (awesome)
Mouse Pad
post #14 of 15
I have heard about that theory before. However, i just bought a 200GB Cicero hard drive and it only detects it as 127GB. I have talked to some friends and they said to check the virtual memory cause it might take up some space. I did, only 748MB though. Where did the rest of the hard drive space go?
post #15 of 15
This is a different topic so I sent you a PM to help you out.
Q6600 B3 @ 3.6ghz ASUS MAXIMUS SE XFX HD5770 Gskill 2x2gb
2x seagate 500gb in raid 0 + wd geen 1.5terrabyte DVD-RW win 7 + xp samsung 712n w HP w2007
IBM type m PC Power + Cooling Silencer 610 CM storm G5
Mouse Pad
the desk
Mouse Pad
the desk
  Back to Forum: Hard Drives & Storage
