Overclock.net › Forums › AMD › AMD CPUs › 3400+ Temps
3400+ Temps
post #1 of 3
I have a 3400+ NewCastle running at 2.7ghz 1:1 2-2-2-5 , when I go to run Prime95 I start getting crazy temps like 38-62c and im getting variations of ~10c every 4-5 secs. I open the case and feel the heatsink and it feels hardy warm. I have a Venus 12 with the fan running at 5400 RPM, is it safe to keep this thing running prime 95 or is it just a temp bug? Im using a DFI Lanparty 250gb mobo with the lastest beta BIOS from DFI-Street. Thanks.
1
(14 items)
Intel Core i7 5820K ASUS X99-Deluxe MSI GTX 780 Lightning 4x 4GB (16GB) Corsair Vengence LPX 2800mhz
Crucial M500 512GB None Corsair AIO H110 Windows 8.1 Pro x64
2x X-Star 1440p Rosewill Mechanical (MX Blue) 1000w EVGA Supernova P1 NZXT H440 White
Mouse
Logitech G500
(14 items)
Mouse
Logitech G500
post #2 of 3
Sounds like a temp report bug... did you try a different ver of the BIOS!
Whats your BIOS temp ... if correct it should be aprox. 80% of full load.
X4 965 ASUS M4A79 Deluxe 9800GTx2 2x2G OCZ Reapers
500G WD Black LiteOn CD/DVD R/W Win7 64 22'' ws Acer AL2223W
KeyboardPowerMouse
MS KU462 Natural SS DA750 MS 5 button
KeyboardPowerMouse
post #3 of 3
The BIOS temp peaks at 49c
1
(14 items)
Mouse
Logitech G500
(14 items)
Mouse
Logitech G500
  Back to Forum: AMD CPUs
