Overclock.net › Forums › Cooling › Water Cooling › '77 Heatercore
'77 Heatercore
post #1 of 13
I just got the '77 heatercore for my future watercooling setup, and it has some rust on it, what is the best way to get rid of rust without damaging the heatercore?
FX-57 Rig
AMD Athlon64 FX-57 DFI Lanparty NF4 SLI-DR EVGA 7950GX2 OCZ 2x1 GB 2-3-2-5
Hard DriveOSMonitorKeyboard
74GB Raptor Windows Vista Ultimate Acer AL2216W 22" Widescreen Saitek Eclipse (Blue)
PowerCaseMouseMouse Pad
680W Aspire Thermaltake Armor Logitech G5 Icemat v2
FX-57 Rig
post #2 of 13
Steel wool maybe? Can you post some pics?
My System
Allendale E6400 Gigabyte GA-965P-DS3 EVGA 7900GT Team Xtreme 512x2 667
WD 200GB SATA XP Pro Service Pack 3 Samsung 793 CRT Logitech Wired
PowerCaseMouse
OCZ GameXsteem 600W Lian Li PC65 - Silver Logitech MX700
My System
PowerCaseMouse
post #3 of 13
Camera is out of battery at the moment, but basicly its silver on most of it, but some parts are redish dark gold, looks like rust to me, not sure.
FX-57 Rig
FX-57 Rig
post #4 of 13
Dark redish gold... Um, silver? Thats not rust, thats the brass colored finish. It sounds like some of the brass finish got rubbed off, and the bare aluminum is showing. That is not good, the brass finish is suposed to keep the heatercore from oxidizing. You should return it, or paint it with a protective layer of paint, to keep the heatercore from corroding.
My System
CPUMotherboardOSMonitor
3700 ClawHammer DFI NF4X Infinity Windows XP pro SP2 Env!sion 17" crt
crappy HP keyboard Aspire 520 + micro 193 Scorpio 868 Highly Modded Logitech mx310 :)
My System
post #5 of 13
Ah, It was my fault I was looking at it under funky light w/ shadows -_-, anyways forget that.
One thing though, is there an faq somewhere on cutting down the heatercore's pipes, i hear i have to do that?
EDIT: also do I need any barbs im using 1/2 tubes
FX-57 Rig
FX-57 Rig
post #6 of 13
All I did with my 77' was cut both of the pipes down, so that they were equal length, and both had an OD of 5/8", and I soaked the tubing (1/2" ID tygon) in warm water then stretched it over the barbs, and it works great.
You don't have to fit the barbs with 1/2" OD to 5/8" OD adapters.
My System
My System
post #7 of 13
Read Deathonator's guide.
New Belle
(10 items)
ImPA120.3
Old Rig
4770k Asus Maximus VI Impact 780 Ti Crucial 16GB Low Profile
Hard DriveHard DriveHard DriveCooling
Samsung Evo 1TB Seagate 2x2TB Raid 1 Samsung 1TB 2.5" Custom 360 Rad
OSPower
Windows 8 Pro evga supernova 1300 G2
X3350 Maximus Formula HD 4850 8GB G.Skill 1000
640GB WD Black Samsung SATA 7 64 Ultimate 20" Acer WS
Filco 104 Cherry Brown Corsair 520HX Three Hundred MX310
AMD Athlon XP 2800+ Asus A7V8X-LA X850Pro 1GB Kingston
120GB Caviar XP Home 32 20" 1680x1050 Acer Compaq
PowerCaseMouse
Modded HIPRO 250w Modded Compaq Microsoft Optical
New Belle
(10 items)
ImPA120.3
Old Rig
OSPower
PowerCaseMouse
post #8 of 13
My System
CPUMotherboardOSKeyboard
AMD Athlon Xp2900 Abit Nf7 Xandros/XP Home Z-Board
PowerCaseMouse
Antec SmartPower 500W Elegance X-Raider+Ratpadz
My System
PowerCaseMouse
post #9 of 13
Use a file to get the silver stuff off of the barbs... Mine had the same stuff. 10 minutes of 'sanding' will take it right off. To get the tubing over the barbs, you have to cuff part of it off with a dremel, then heat the tubing in water, and slide it over.
System
Core i7 2500k ASRock P67 Extreme4 Gen 3 AMD 7970 16GB DDR3
Intel 520 256GB SATA DVD Burner Windows 7 64 bit Deal U2410
KeyboardPowerMouse
Adesso Mechanical Silverstone OP650 Logitech G700
System
KeyboardPowerMouse
post #10 of 13
I talked to some people and they said all you have to do is cut down the heatercore, and just heat up the tubing and just stretch it on, no need for any attachments? Is this true?
FX-57 Rig
FX-57 Rig
  Back to Forum: Water Cooling
