Overclock.net › Forums › AMD › AMD CPUs › 146 vs 3700
146 vs 3700
post #1 of 29
I have ordered everything I need for my new system but am completely stuck on what cpu. I was thinking an Oteron 146 but with recent price increases they have gone up to around £160 for lesser CACJEs. For that price I could get a 3700 San Diago core. Which would be better bearing in mind I will want to overclock it as far as I can go?
Thanks
My System
E6550 GA P35 D3SR 8800 GTS OCZ 800
WD 500GB Sony DW12G1A Vista Ultimate SyncMaster 940N
PowerCase
Hyper Z 480W Lancer
My System
PowerCase
Hyper Z 480W Lancer
post #2 of 29
Thanks
Toss a coin, there's simply no way to answer that without knowing both chips.
My System
Intel 2500k Asus P8P67 Galaxy GTX580 8GB G Skill Ripjaws
Hard DriveOSMonitorKeyboard
Intel 80 gb SSD, Raptor 150 Windows 7 Home Premium 24" Samsung LCD Saitek Eclipse
PowerCaseMouse
PCP&C 750W Antec P180 Logitech MX-510 blue
My System
PowerCaseMouse
post #3 of 29
Have you thought about a Opteron 148?? They're only a bit more expensive than the 3700+ and the new steppings are good overclockers (2.8-2.9)
post #4 of 29
All you can do is toss a coin they perform similarly
devil's canyon
(18 items)
presler
(15 items)
haswell
(15 items)
i7-4790K Gigabyte Z97 MX-G5 ZOTAC 1060 AMP! 6Gb 16gb Corsair Vengeance 2400
Hard DriveHard DriveCoolingCooling
ADATA 128Gb NVMe Seagate Video 500Gb Phobya UC-2LT Plexi XSPC X4 Tank Combo
CoolingCoolingOSMonitor
Nexxxos XT45 280 2x AC F14 PWM Win 10 Pro BenQ GL2250HM
Cherry compact Corsair CX750M Bitfenix Pandora Core Corsair Sabre RGB
AudioOther
Realtek ALC1150 Aten CS682 KVM
Pentium D 915  Dell USFF Intel GMA 950 4gb Corsair ddr2
Hard DriveOptical DriveCoolingCooling
WD Caviar 80gb sata II  Slim dvd rw Stock Copper Heatpipe  2x 60mm Sunnon fans
OSMonitorKeyboardPower
XP sp2 BenQ GL2250HM Logitech k400 220W external
CaseMouseAudio
Optiplex USFF w/ cable cover Logitech k400 Onboard SoundMAX
i7-4790 Gigabyte H97N-wifi Zotac GTX 750Ti 16gb Corsair XMS3 1600
Hard DriveCoolingOSMonitor
Integral 480gb ssd AC Freezer i30 Win 10 Pro BenQ GL2250HM
Cherry compact Corsair CX550M Fractal Design Core 500 Logitech B100
Mouse PadAudioOther
venom gaming surface Realtek onboard Aten CS682 KVM
devil's canyon
(18 items)
presler
(15 items)
haswell
(15 items)
AudioOther
CaseMouseAudio
Mouse PadAudioOther
post #5 of 29
I would say go with the 146, they are better overclockers than the 148's as I have seen. Even though you would expect it to be the same core, just a lower multi. But it's up to you, determine if it's better for you to have a x11 multi or a x10 multi. If your memory would like a x11 multi for 1:1 performance, get the 3700. If it doesn't matter, then I would get the 146.
My System
i3-540 @ 3.68ghz Biostar TH55 HD HD 5770 1GB Gskill 2x2G DDR3 @ 1600mhz
Hard DrivePowerCase
Raptor75 10,000rpm ThermalTake TR2 500w Antec SuperLanboy
My System
Hard DrivePowerCase
post #6 of 29
I have Geil 4400 UltraX-TCCD CAS 2.5. I was going for 1:1 to really push the ram. I am going to see whats cheaper but I think its going to be the 3700. Thanks
My System
PowerCase
Hyper Z 480W Lancer
My System
PowerCase
Hyper Z 480W Lancer
post #7 of 29
The newer stepping 3700's are better that the first ones that came out. I would get a new 3700. But thats just me.
My Sandy Rig
(14 items)
Intel i7 2700K 4.8ghz @ 1.32 vcore Asus P8Z68-V/Gen3 PowerColor 7950 Boost Patriot DDR3 1600 4gb x 2
WD 1TB, 750 black LG SATA DVD burner Corsair A70 dual fan 7 Home Premium 64bit
Zalman 23"  Azio PC P & C 750 Silencer NZXT ZERO
MouseMouse Pad
Logitech MX-500 Laser My Desk
My Sandy Rig
(14 items)
MouseMouse Pad
post #8 of 29
I have a 3700, I went through the same purchasing decision you went through. Nota Bene: DFI and other companies do not support the 939 series Opterons, so I got a 3700 so that I'd have warranty support.
Burning Phoenix
Intel Q9550 Gigabyte EP45-UD3P eVGA GTX 260 Core 216 SuperClocked 4GB G.Skill DDR2-1000 5-5-5-15
3 WD 80GB RAID0, Seagate 500GB, WD 1TB Caviar BLCK Lite-On LH-20A1S Windoze 7 Professional Dual Dell E207WFP 20.1" Widescreen LCD's
Logitech G15 Silverstone OP750 Lian-Li PC-A10B Logitech G5
Mouse Pad
Harley Davidson
Burning Phoenix
Mouse Pad
Harley Davidson
post #9 of 29
I'd personally go with the 3700. The 3700 is more overclockable, as far as I know. I've got mine to a stable 2.8 GHz without even upping the vcore. I can hit 3.1 GHz if I really try, and with better RAM, I could probably push it to around 3.3-3.4ish. The 3700 is better than the 146, but I think the 148 is a little better than the 3700. If you're going for an Opty, don't settle for less than the 148. It's basically the same as a 3700, but slightly more OCable.
My System
CPUMotherboardOSMonitor
Athlon 64 3700+ San Diego Abit KN8 w/NF4 Chipset Windows XP/Various Linux 17" Samsung CRT
Logitech EX110 XG Vortec 500W Random Unknown Case Logitech EX110
My System
post #10 of 29
i love my opty 148. its running a slow 3 GHz now, but my GSkills are comin today so im gonna try and run 1:1 tonight.
Intel Q6600 G0 @ 3.6 GHz DFI Lanparty DK P35-T2RS Sapphire HD4850 @ 700/1035 2 x 2gb GSkill DDR1000
320gb + 2x750gb + 1tb + 2tb NEC 3550a 7 Ultimate x64 Dell Ultrasharp 2005FPW
Logitech DiNovo Edge Thermaltake 750w Rocketfish (Lian-Li PC-A71) Logitech MX700
  Back to Forum: AMD CPUs
