Overclock.net › Forums › Cooling › Water Cooling › 1977 Bonneville Heatercore question
post #1 of 6
Ok i found this heater core along with others, but this one has a input of 3/4" and an out-put of 5/8" 3/4 is bigger than the half in im buying, actually so is the 5/8". so how do i make this heater core work with a 1/2" water cooled system?
Deep Blue
AMD Phenom 2 X4 940 BE MSI DKA790GX Platinum Sapphire HD4890 OC Corsair C5D8500 2x1Gig Kit
WD Cavair Black 500 LG DVD+ RW Windows 7 Ultimate Samsung 2494hs 24 Wide
Razer Tarantula Enermax Liberty 620W DD Torture Rack Razer Lachesis
Mouse Pad
Razer Pro Solutions
Deep Blue
Mouse Pad
Razer Pro Solutions
post #2 of 6
adapters from the plumbing supply
Shop Dog
E8400 Asus Blitz Formula SE HD3870X2 G Skill 2 x 2GB DDR2 800
Velociraptor 150GB LG DVD Burner Vista Ultimate 64 AOC 21.5" LED 1080p
Deck Legend Silverstone 750 Modular OverClock Edition Lian Li V1100 Logitech Trackball
Mouse Pad
Nope
Shop Dog
Mouse Pad
Nope
post #3 of 6
adapters? i can buy fittings anywhere. what i want to know is what kind of pressure loss and gph fluctuation im looking at here?
Deep Blue
Mouse Pad
Razer Pro Solutions
Deep Blue
Mouse Pad
Razer Pro Solutions
post #4 of 6
You aren't looking at pressure loss, because the biggest fittings on blocks are 1/2". All you have to do is put the ends of the tubing in hot water for a minute or so and then push them on the tubing after you have cut it down past the 5/8" to 3/4" on the heatercore.
i7-3770k Asus Maximus IV Extreme-Z ASUS GTX 770 2x4GB Gskill Ripjaws
Samsung EVO 840 WD Caviar Green Sony AD-7260S-0B DVD Burner Scythe Mugen 2 Rev. B
OSMonitorKeyboardPower
Windows 8.1 Pro x64 QNIX QX 2710 Filco Majestouch-2 Rosewill Capstone-750-M R
CaseMouseMouse PadAudio
Zalman Z-Machine GT1000 Logitech MX518 Black Banshee Pad Krator N2-20020 (Garbage)
post #5 of 6
Ah ok so just cut down and fit the tube accordingly? damn shoulda thought of that while i was at shucks.... ohwell i have much to do tonight anyways.
Deep Blue
Mouse Pad
Razer Pro Solutions
Deep Blue
Mouse Pad
Razer Pro Solutions
post #6 of 6
My System
CPUMotherboardOSKeyboard
AMD Athlon Xp2900 Abit Nf7 Xandros/XP Home Z-Board
PowerCaseMouse
Antec SmartPower 500W Elegance X-Raider+Ratpadz
My System
PowerCaseMouse
  Back to Forum: Water Cooling
