Overclock.net › Forums › AMD › AMD Motherboards › 395mhz FSB
395mhz FSB - Page 2
post #11 of 17
well if you don't increase the vcore you won't be able to OC as far.
basically you need to find the max your cpu is stable at. so underclock your rAM by putting it on a dividor and increase your htt by about 10Mhz at a clip. (keep your cpu multi at 10x for this) and keep booting until your system is not prime95 stable for 5 min. then go down about 3mhz until it is stable. this is your max cpu speed. do this w/ stock voltage and it will tell you how high your cpu will go on stock vcore... then just add some vcore and go from there... you don't want to go any higher than about .3v higher... so you'll want to stay under 1.65v or so (actually that's a bit high depending on your cooling)
once you've found your board max (as I described in my last post) and yoru cpu max then find your RAM max. underclock your cpu and raise your htt w/ your RAM on a 1:1 dividor (no dividor) run memtest test 5 or 6 a couple passes to make sure it is stable... when it isn't stable anymore either loosen the timings and/or increase the voltage a bit and then try again to find your max RAM frequency. once you get to where you think the max is then run test 8 for about 20 passes.
once you know the max for your mobo, cpu and RAM multipy each by .95 and you'll have an idea where the safe frequencies are... then you can figure out what your overclocking settings should be.
Darkness
(14 items)
Q6600 G0 Gigabye GA-EP45-UD3P EVGA GTX660 8GB G.Skill PK
WD 640GB & Samsung F1 750Gb LG BD & HD Windows 8 Pro x64 HP w2207
FILCO FKBN87M/NPEK Enermax Modu82+ 525w CM 690 Logitech G9x
Mouse PadAudio
Razor Destructor ODAC
Darkness
(14 items)
Mouse PadAudio
post #12 of 17
ok, I am understanding OC now, thanx guys. But their is one last thing, I dont understand. Say my ram FSB tops was 230. But my mobo was running at 240 FSB
with a 10x multi, which makes 2400mhz. What divider will I need to use, what ratio?
My System
AMD 3700+ SD 2.9Ghz ASUS A8N 32x SLi Deluxe XFX 7600GT 630/1700 Crucial Ballistix 2x1GB
Hard DriveOSMonitorPower
Samsung SpinPoint P120S Windows XP Home SP2 ViewSonic VX922 Aerocool ZeroDBA 620w
Coolermaster Centurion 5
My System
post #13 of 17
166
My System
CPUMotherboardOSMonitor
3000+ LBBWE 0542 EPHW Gigabyte GA-K8N-SLI XP 15" Sony LCD's
Power
450W PR?
My System
Power
450W PR?
post #14 of 17
erm, how did you work that out? Is there some kind of equation? E=mc2 lol
My System
My System
post #15 of 17
cpu frequency/cpu multi x dividor = RAM speed
Darkness
(14 items)
Mouse PadAudio
Darkness
(14 items)
Mouse PadAudio
post #16 of 17
i got my board to 350...but never went anyfurhter cuz i knew my ramm would never make it that far!
My System
AMD OPTERON 175 MSI Diamond Plus Win XP PRO 17" CTX LCD
KeyboardPowerMouse
102 standard antec truepower 2.0 550 Logitech Optical
My System
KeyboardPowerMouse
post #17 of 17
Originally Posted by fredster102
When you raise the FSB does that affect the chipset?
yes, for me it did big time. i had to up the chipset voltagr by 0.3 volts to get it stable.
My System
Core 2 duo @ 3.6 DFI Dark X38 5770 OCZ Gold 8GB
Raid (striped) western digi LiteOn Vista Ultimate 23" widescreen
G15 520 watt corsair Cooler Master Logitech G5
Mouse Pad
A chunk of wood
My System
Mouse Pad
A chunk of wood
  Back to Forum: AMD Motherboards
