Overclock.net › Forums › Components › Sound Cards and Computer Audio › 1983 Bose 901 Series V!!!
post #1 of 10
So I got bored and decided to grab my dad's old Bose 901 Series V speakers instead of letting them collect more dust in our storage room and hook them up to my computer. But I had a few problems in hooking them up to my computer. My main problem is that we couldnt figure out much of a way to get the audio from my PC to our ancient amp/equalizer. My mobo had an S/Pdif output or something like that as well as the normal 6 jacks but we ended up just running the a cable from the green output to the "Mic" input on the front of the amp through an adapter and so far it works pretty well. One of the speakers might be a bit blown but as long as we don't turn the amp volume up too high we can't hear it. Just so you guys know these things are about 30+ years old. I'm not exactly sure how old but the copyright says 1983 on the speakers. I'm not sure about the amp but it is a pioneer and the serial number is EG 2901154 S so if any of you guys know what it is then please tell me. But here are a few pictures I took:
Blue Steel
(20 items)
HTPC
(12 items)
Macbook
i7 860 MSI P55-GD80 Gigabyte GTX 560Ti 1gb Kingston Hyper X Fury 4x4gb
Samsung F3 1tb Samsung 830 64Gb Western Digital Green 1tb Samsung 850 EVO 500gb
Optical DriveCoolingOSMonitor
Lite-On Blu-Ray Player Cooler Master Hyper 212+ Windows 7 Home Premium x64 Acer S231HLBID 23"
Vizio 32" 1080P Razer BlackWidow Rocketfish 900W HAF 912
MouseMouse PadAudio
Logitech G402 Hyperion Steel Series QcK Asus Xonar DG
i5 760 Asus P7P55D-E Pro XFX 5570 Corsair XMS3 2x1gb
Western Digital Caviar Black 640Gb HP DVD1260 Cooler Master GeminII S524 Windows 7 Enterprise x64
MonitorPowerCaseMouse
Vizio 32" 1080 Corsair 650TX Silverstone LC13B-E Droid X2
CPUGraphicsRAMHard Drive
2.4 GHz Intel Core 2 Duo GMA X3100 4GB DDR2 667 MHz 120 GB
Optical DriveOSMonitorCase
MATSHITADVD-R UJ-867 Mac OS X 13 Macbook
Mouse
Microsoft Arc
Blue Steel
(20 items)
HTPC
(12 items)
Macbook
MouseMouse PadAudio
Mouse
Microsoft Arc
post #2 of 10
Here's a review of your speakers from 1984:
http://www.gramophone.net/Issue/Page...1984/80/791723
Apparently they're some of the last Bose speakers to get any serious consideration in regard to their performance. They would have originally been used with an equalizer made specifically for the 901 series, and without setting it depending on a room's particular acoustics they didn't sound so great:
Now that I have been evaluating the Bose 901 Series V in my own home for the past few weeks, I have found the system surprisingly adaptable to different rooms and situations—provided that time is expended in getting everything just right. If this local optimization process is skimped, or if the room is too small or lacks a suitable reflective back wall, the results are generally disappointing.
The amp appears to be a SA-055. Can't find much about it, but you'd be better off connecting your PC to the Line input, or some other stereo input on the rear, rather than the Mic in.
Intel Q6700 @ 3.3 GHz ASUS P5N-D 750i SLi MSI N460GTX Hawk 1GB G.Skill 4GB PQ
WDCaviar Black Intel X25-V Lite-On DH-4O1S Blu-Ray OCZ Vendetta 2
OSMonitorKeyboardPower
Vista Ultimate x64 SP2 Samsung 245BW Logitech G11 Corsair HX520W
CaseMouseMouse PadAudio
Antec P182 Logitech G5 Rev. 2 Allsop Widescreen Mousepad X-Fi Xtreme Music
AudioOther
Audio-Technica ATH-A700 Logitech G13
AudioOther
post #3 of 10
The thing is that we couldn't figure out a way to hook it up to anything in the back. We do have the Bose equalizer but we don't have an adapter that will let us go from a normal head phone jack to a Red/White component which is what is needed for it to be an actual source for the back of it. Also if I hook it into the line port in the front I dont get any audio?
Blue Steel
(20 items)
HTPC
(12 items)
Macbook
MouseMouse PadAudio
Mouse
Microsoft Arc
Blue Steel
(20 items)
HTPC
(12 items)
Macbook
MouseMouse PadAudio
Mouse
Microsoft Arc
post #4 of 10
Just hit up a Radio Shack, they'll have the adapter for $5.
The line port on the front is probably some special input selection, like a tape monitor button but something else. Do note that the mic input frequency response range may well be neutered to be effective only for the range of the human voice. Who knows, could go either way on that one...
Edit: Adjust the mic volume as well, looks awfully low in the picture.
Sherlock
(12 items)
Intel i7 5775C Asus Z97i Plus Sapphire RX480 Corsair Dominator Platinum 2400
Hard DriveCoolingOSMonitor
1TB Samsung 960 EVO BeQuiet! Dark Rock 3 Windows 10 Pro Acer XR382CQK
Unicomp Ultra Classic Silverstone Strider 850w Platinum Lian Li V1000 Thermaltake Level 10
Sherlock
(12 items)
post #5 of 10
If you're looking at the one that is one the left half but all the way to the right then you're looking at the "Mic 2" volume. And I probably could get over to Radioshack but it's a bit late and really I'm not an audiophile and it works pretty well right about now but is there a adapter that goes from head phone jack to component?
Blue Steel
(20 items)
HTPC
(12 items)
Macbook
MouseMouse PadAudio
Mouse
Microsoft Arc
Blue Steel
(20 items)
HTPC
(12 items)
Macbook
MouseMouse PadAudio
Mouse
Microsoft Arc
post #6 of 10
what you need is a 3.5mm to RCA adapter
Epic Rig
(9 items)
AMD Phenom II X6 1090T 890FXA-GD70 (MS-7640) Radeon HD 5670 G. Skill
RAMHard DriveHard DriveOptical Drive
G. Skill WD Green Seagate Samsung Blu Ray reader
i inc 28 inch monitor
Epic Rig
(9 items)
post #7 of 10
Walmart $5, and you are loving life.. Those in the day were the best of the best. So worth restoring if you have any paper damage. That was/is the only knock on Bose, they use paper not polypropylene.
post #8 of 10
Any place you could get them restored? And roughly how much? Like I said we have the equalizer and even an AM tuner, haha but I'll see what I can do about that adapter. Thanks for the help guys.
Blue Steel
(20 items)
HTPC
(12 items)
Macbook
MouseMouse PadAudio
Mouse
Microsoft Arc
Blue Steel
(20 items)
HTPC
(12 items)
Macbook
MouseMouse PadAudio
Mouse
Microsoft Arc
post #9 of 10
You can to go to Parts Express, Speaker Repair, or Woofer Repair to buy reconing materials(if the speakers have damages), if not, then just wipe them clean and enjoy some music
Intel Junk
C2D E4500 @ 2.75GHz GIGABYTE 965P-S3 PNY 8800GT 512MB Crucial Ballistix Tracer DDR2 1000MHz 2GB
WD 750GB AALS, Hitachi 160GB laptop none Windows 7 Ulitmate 32bit 22" Acer LCD AL2216W
Logitech 350 Internet ASUS OEM 300W none Logitech RX300
Mouse Pad
pads pads pads
Intel Junk
Mouse Pad
pads pads pads
post #10 of 10
Yea, check them out.. Don't those have like (9) 4 1/2" drivers? I know people sell them on ebay and it can't be to terribly hard to do. I haven't seen to many amps that can blow them. When you do get them going notice the sound on the first day compared to the sound after about 2 weeks.. Great speakers don't wear out, just in.. and it will take a few for them to feel out your amp. Have fun.
  Back to Forum: Sound Cards and Computer Audio
