Overclock.net › Forums › AMD › AMD CPUs › 3700+ Sd
3700+ Sd
post #1 of 4
ok, there are two 3700+ SD cpu's on newegg. Just wondering what the difference between the two are?
ADA3700BNBOX - $213
ADA3700CFBOX - $215
Opps, stupid internet
post #2 of 4
ADA3700BNBOX - $213
ADA3700CFBOX - $215
I think the BN is the E4 revision and the CF is the new E6 revision.
Clevo P170HM
(6 items)
CPUGraphicsRAMHard Drive
i7 2760QM HD 6990m Samsung 1333mhz Crucial M4 SSD
Hard DriveOS
Western Digital Black 500gb Windows 7 64 Bit
Clevo P170HM
(6 items)
Hard DriveOS
post #3 of 4
Go with this amd 939 a64 3700+. I bought one here and it was a KAB2E stepping(One of the best steppings out there) Order them while there hot!
post #4 of 4
I think he's right. just click on the manufacture's link on newegg and it usually brings up the specific cpu specs and will tell you what revision it is.
Darkness
(14 items)
Q6600 G0 Gigabye GA-EP45-UD3P EVGA GTX660 8GB G.Skill PK
WD 640GB & Samsung F1 750Gb LG BD & HD Windows 8 Pro x64 HP w2207
FILCO FKBN87M/NPEK Enermax Modu82+ 525w CM 690 Logitech G9x
Mouse PadAudio
Razor Destructor ODAC
Darkness
(14 items)
Mouse PadAudio
  Back to Forum: AMD CPUs
