Overclock.net › Forums › Components › Memory › 2048 MB Corsair TwinX XMS2-6400 DDRII 800 MHz
post #1 of 5
Hi guys. I just bought new Corsair TwinX XMS2-6400, inserted in Asus P5WD2-E Premium motherboard with D930 CPU. I am looking for limits of these modules. They are designed for 5-5-5-12-1T timings (also on their label), but my motherboard detected them as 5-5-5-18 (so I set it manualy to 5-5-5-12 in bios, right?). I did some tests without OC and I got these results (200 FSB, 1:2): Sandra RAM 5133/5128 MB/s, PCMark05 RAM 4063.
I would like to ask u where I can set 1T (or 2T) in bios, because I dont see there any settings. And another thing, what is "Write recovery Time" ? I can define the number of clocks for it in bios... I noticed some guys overclocked these modules to 925MHz with 5-5-5-12 timings. I wanted to find best timings possible by memtest56, but when I want to configure timings there, I got a message my chipset is not supported (yes I have the latest version).
When I did decent overclock to FSB 260, 1.40V, 870MHz memory with 5-5-5-12, my score is: Sandra RAM 6591/6592 and PCMark05 RAM 5123.
Does anyone have these modules and could tell me its limits, so I can set there some better timings, or so? CPU seems to be stable on 4.05GHz and 1.45V, so I can increase FSB to 270. Thanks a lot. Lukke
post #2 of 5
Set ratio to 3:5 and timings at 4-4-4-8 and 2.2v or 4-4-4-12 and 2.2v
Corsair RAM is excellent for overclocking.
Those 5-5-5-15 timings are bad.
I have the Corsair 8000UL a.k.a. DDR2 1000 and run my system with a 1:2 ratio but with the fallowing timings:
post #3 of 5
And dont you know where I can check if it isnt runing with 2T? Because I noticed when 2T command is disabled, bandwidth is better. I already have 3:5 divider set. The last option in bios I dont know what to set is "Write recovery Time"... I can check it from 2 to 6 or so. Its default on 4.
post #4 of 5
whoa, my 920 only needs 1.3 to run at 275FSB stable, and 1.32 for 287FSB
Was your's unstable and needed the voltage? If not, you can probably back it down.
post #5 of 5
Yup, it was unstable in Prime95, so I had to increase voltage to 1.4. For 287 FSB I would need at least 1.5V and its become tooo hot. So I am now on 270 FSB and 1.45V... Memories are running on 2.1V and it seems no problem with 4-4-4-4 timings, but does anyone has better results?
  Back to Forum: Memory
