Overclock.net › Forums › AMD › AMD CPUs › 3200+ @ 3ghz or .....
post #1 of 10
Which should I see better gains with:
1. 3.0ghz with ram running at 300mhz.
2. 3.11ghz with ram running at 259mhz.
Timings and voltage are the same. SuperPi hundredths of differences. Which would you choose?
My System
e6850 p5n32-e sli 8800gtx Crucial Ballistix
Hard DriveOSMonitorKeyboard
WD 1tb vista basic. 20.1" samsung Zboard
PowerCaseMouse
Antec 550W Lian Li logitech g5
My System
PowerCaseMouse
post #2 of 10
I'd go with 3 Ghz because it's a round number...
My System
3800x2 Manchester, 2.5Ghz ASUS A8N SLI-Deluxe 7600GS --> Smoked 1GB Corsair XMS Platinum
OSMonitorPowerCase
Windows XP Pro IBM G74 Aspire 520W Purely Custom
Mouse
IntelliMouse Explorer
My System
OSMonitorPowerCase
Mouse
post #3 of 10
I'd go with the 3.0Ghz w/ RAM at 300Mhz because 3.11Ghz isn't really that much faster to have your RAM drop that much. I don't think there will be a performance gain with the 3.11Ghz.
My System
P4 3.0E Ghz Prescott Asus P4P800 SE ATI X700 PRO 2X512MB Patriot DDR400
Hard DriveOSMonitorPower
2X160GB Seagate's Windows XP Home SP 2 Acer 17" LCD X-Connect 500W
My System
post #4 of 10
def the 3.0ghz that 100mhz ant going to make much of a diference and the meo will definatly at those speeds go for it and i love your over clock ts amazing
z4ranger !
3700+ @ 2.9ghz asrock 939 dual ati x1950pro 2gb geil bh-5
Hard DriveMonitorKeyboardPower
samsung 250gb LG flatron(m1710a),8ms logitech diNovo 430w
CaseMouse
jeantech g-max Logitech diNovo
z4ranger !
CaseMouse
post #5 of 10
If my board would allow more than 1.55 Vcore, I think it would go farther.
My System
PowerCaseMouse
My System
PowerCaseMouse
post #6 of 10
Hmmm... what are the RAM's timings @ the 259? I would think TCCD would run higher in the second settings, or closer to the 1st settingd speeds!
X4 965 ASUS M4A79 Deluxe 9800GTx2 2x2G OCZ Reapers
500G WD Black LiteOn CD/DVD R/W Win7 64 22'' ws Acer AL2223W
KeyboardPowerMouse
MS KU462 Natural SS DA750 MS 5 button
KeyboardPowerMouse
post #7 of 10
I ran both speeds at 2.5-4-3-5 1t
My System
PowerCaseMouse
My System
PowerCaseMouse
post #8 of 10
what is your max
ht if its like 350 lower the muti and that will raise your memories speed dont know by how much but thats what i done lowerd mine 20 8x 300 and a divider or 166 and got higher clocks that 208
z4ranger !
CaseMouse
z4ranger !
CaseMouse
post #9 of 10
Are you losing stability with the RAM in the 2nd settings?
I just wonder why you have to drop it's speed so far down fron the 1st settings speed.
If so, have you tried a 2T for stability to get the speed back?
KeyboardPowerMouse
KeyboardPowerMouse
post #10 of 10
It's b/c my mobo doesn't offer many Divider options like DFI's. It's either 400mhz or 333mhz. That's why there is such a big drop off.
My System
PowerCaseMouse
My System
PowerCaseMouse
  Back to Forum: AMD CPUs
