Overclock.net › Forums › Components › Memory › 333 to 400?
333 to 400?
post #1 of 7
im getting 2.6 from my 3500+Venice with the memory @333 auto.
how can i get stable memory at 400? thank you
__________________
http://valid.x86-secret.com/show_oc.php?id=86089
__________________
My System
CPUMotherboardOSMonitor
3500+ A8N5X XP Pro old one
old one dunno Cooler Master Logitec 500
My System
post #2 of 7
Increase the vdimm.
Relax the timings.
Use the 11x multiplyer
The RAM you have may do the 236 needed with CAS2 using an 11x and enough but not to much voltage. If not up to CAS2.5
BTW nice OC and system
X4 965 ASUS M4A79 Deluxe 9800GTx2 2x2G OCZ Reapers
500G WD Black LiteOn CD/DVD R/W Win7 64 22'' ws Acer AL2223W
KeyboardPowerMouse
MS KU462 Natural SS DA750 MS 5 button
KeyboardPowerMouse
post #3 of 7
thank you for your speedy reply Duke and the kind words for my first effort. i was able to clock to 2.74 but felt that was too much for my needs. this is addictive..
My System
My System
post #4 of 7
Duke..
i tried some combinations with voltage and what not but to now avail. short answer.. different ram.. i have two sticks of hand-me-downs and 1g of newer C2. one gig alone wont run our latest games so im saving up for a two stick two gig set. when i get my gettas together id like to stop back for some suggestions.
thanks for your help.
My System
My System
post #5 of 7
2 x 1GB RAM:
G.SKILL Extreme Series 2GB (2 x 1GB) 184-Pin DDR SDRAM Dual Channel Kit System Memory - Retail
http://www.newegg.com/Product/Produc...82E16820231021
Hope you can save quickly, because this is a good price now for really good RAM!
E8400 @ 3.8 GHz DFI LANPARTY DK X38-T2R eVGA 8400GS 2GB Mushkin DDR2 800 (single stick)
250GB WD SATA None Windows XP Pro 32-bit HP Pavilion f1703
N/A Corsair HX520 Coolermaster Cavalier N/A
Mouse Pad
N/A
Mouse Pad
N/A
post #6 of 7
I have found that with my TWINX 3200C2 200MHZ fsb is possible at 2-3-3-6 on 2.7Vdimm. Any thing higher you need to take out the timmings as suggested. Why not run a divider to keep the RAM at 200MHz or close to it.
cheers
My System
3700+Sandiego KACAE DFI LP UT nF4 SLI-D 2 x eVGA6600GT 256Mb 2x512Mb TCCD
Hard DriveOSKeyboardPower
WD 80Gb SATAII XP Puss Pro Logiteck Multimedia Enermax Noisetaker 485W
CaseMouse
XG Quantum - modified Logitech MX518
My System
CaseMouse
post #7 of 7
first to xie67
the timings worked well but i loosened things up by using 3 in CAS. now with AquaMark3 my score went from 74000 (and a little) to 80865. after i changed my shorts i hastened to reply to your post. i took out the C2 v1.2 (which wouldnt boot installed) and left the new Twix 512x2 and i used your posted settings and it is smooth and so far stable.
http://valid.x86-secret.com/show_oc.php?id=86914
to Chozart
with these new numbers im waiting. im long on guts and just now short on $$. thank you both for your suggestions.
My System
My System
  Back to Forum: Memory
