Overclock.net › Forums › AMD › AMD CPUs › 165 or 170???
165 or 170???
post #1 of 8
well im saving up for a new processor and i cant decide between the 165 or 170, do u guys/girls think the 170 will be able to reach 3GHz???? and would the 165 reach 3Ghz???
My System
AMD X2 4400+ @ 2.64ghz DFI LanpartyUT SLI-DR NF4 bfg 8800gts 512 2X1 OCZ Ultra Performance
WD 3X320 WD 1X500 LG 16X DVD-RW Windows XP PRO 24" Viewsonic
ZBOARD TT 1000w NZXT ZERO Razer Diamondback
My System
post #2 of 8
Im pretty sure they can both get to 3Ghz with good air cooling, although i think it depends on the stepping.
2011 ~ Current
(16 items)
Core i7 2600K Asus P8P67 Pro B3 EVGA GTX970 FTW+ G.Skill 8GB RipJaws
2x 500GB WD Black RAID 0 1TB WD Black Samsung WriteMaster Prolima Tech Megahalems
OSMonitorKeyboardPower
Windows 7 Home Premium ViewSonic 22" VX2260wm Saitek Eclipse II Seasonic X-660
CaseMouseMouse PadAudio
ThermalTake Armor Silver Logitech G5 Sharkoon Asus Xonar D1
2011 ~ Current
(16 items)
post #3 of 8
I'd say the 170 just to be safer for 3ghz. Since it's 2.0 ghz and the 165 is only 1.8ghz.
Silverbullet
(19 items)
4690k MSI Gaming 5  Asus GTX670 DC2OG Corsair Vengeance
RAMHard DriveHard DriveCooling
Corsair Vengeance LP Kingston SSDnow 120gb m.2 Kingston SSDnow 240gb Enermax ETS-T40-BK
OSMonitorMonitorKeyboard
Windows 10 Acer GN246HL Acer X233H Logitech G710+
PowerCaseMouseMouse Pad
FSP Aurum 650w Lian Li PC-V1000PII Razer Deathadder Chroma Xtrac Pad Ripper
AudioAudio
Sound Blaster Z Sennheiser HD598
Silverbullet
(19 items)
AudioAudio
post #4 of 8
I'd really doubt either CPU would hit 3Ghz on Air or Water Cooling. If you can pick up a CC1BE stepping then you might get 2.8+Ghz out of it with a bit of luck.
Prob go for the 165 as your mobo should have no problem with the 9 Multiplier.
Clevo P170HM
(6 items)
CPUGraphicsRAMHard Drive
i7 2760QM HD 6990m Samsung 1333mhz Crucial M4 SSD
Hard DriveOS
Western Digital Black 500gb Windows 7 64 Bit
Clevo P170HM
(6 items)
Hard DriveOS
post #5 of 8
The advantage of the 170 is the 10x flexability where as the 165 has a 9x.
As to the actuall OCability to 3G ... hard to say... so many varables like stepping and other system components.
The 4400+ has been OCing rather well lately and has an even more flexable 11x but will set you back about $50 more than the 170.
Good point Ste... thats a great MB to work with
X4 965 ASUS M4A79 Deluxe 9800GTx2 2x2G OCZ Reapers
500G WD Black LiteOn CD/DVD R/W Win7 64 22'' ws Acer AL2223W
KeyboardPowerMouse
MS KU462 Natural SS DA750 MS 5 button
KeyboardPowerMouse
post #6 of 8
well i think i should have mentioned i have watercooling lol with my 3000+ oced to 2.7ghz its idles at 26-29C and full load of 38-40C
My System
My System
post #7 of 8
It's will be hit or miss as to whether either of those will hit 3.0ghz. The fastest I have gotten mine is 2.9 @ 1.625 volts. I backed it down as it was not 100% stable and didn't want to give it more voltage, even though the temps were still very low. I'd say with 1.7+v it may hit 3.0 but I don't really want to kill my chip.
MainframeIII
(14 items)
3930K Asus P9X79 Deluxe Asus R9 290X 16GB G-Skill
2x240GB Crucial SSD Raid 0 Lg DVD W7 64bit Benq 24" FP241W & 23" FP231W
G15 PC P&C Silencer 750 Thermaltake Armor Modded Rat 9
Audio
Asus Xonar Essence STX
MainframeIII
(14 items)
Audio
post #8 of 8
whats the max voltage you wanna give these chips anyway?
  Back to Forum: AMD CPUs
