Overclock.net › Forums › Graphics Cards › NVIDIA › 9000 Pro vs 5200?
9000 Pro vs 5200?
post #1 of 17
which card is better for playing bf2?
My System
CPUMotherboardOSMonitor
Athlon XP 2500+ OC@2.3ghz Asus A7N8X-E Deluxe Windows XP Professional Envision EFT720g
Microsoft Internet Antec 380W True Power Antec Sonata Microsoft Optical
My System
post #2 of 17
Theyre both pretty close but Id say the 5200 has a bit of an advantage because it has a 128bit bus and the 9000 has a 64bit bus.
Very nice!
Core 2 Duo E6600 Asus P5N32-E SLI EVGA 8800GTX 2 x 1GB GSkill HZ
2 x WD Caviar SE16 250GB Sony NEC Optiarc 18x SATA DVD Windows XP Pro Gateway FPD2485W 24"
Logitech G15 PC P&C Silencer 610W Thermaltake Tsunami Logitech MX518
Very nice!
post #3 of 17
lol i used to have 9000PRO
i loved it
not really lol it will play BF2 on low
My System
Opteron 144 eVGA NF4 SLi eVGA 7800GT G.Skill 2GB
Hard DriveOSMonitorKeyboard
80GB +30GB+500GB-30=580 Win. XP Pro Acer 19' WideScreen LCD eh... microsoft
PowerCaseMouse
400W cheap-o for now MX 610
My System
PowerCaseMouse
post #4 of 17
dude my old 9000PRO has 128 bit
in your face
My System
PowerCaseMouse
My System
PowerCaseMouse
post #5 of 17
in your face
If its a 128bit 9000Pro then it should beat the 5200.
Very nice!
Very nice!
post #6 of 17
how can you check if its 128bit or 64bit?
My System
My System
post #7 of 17
Everest would tell you, under Display>GPU, then it lists your "Bus Width".
Everest: http://www.lavalys.com/products/down...?pid=5&lang=en
Da Gallardo
C2D E6420@3.60ghz 4MB L2 Asus P5B Deluxe eVGA 8800GTS 640MB Super Talent 4x1GB DDR2 667
2x250GB WD2500KS RAID0 DVD±RW & DVD-ROM/CD-RW Windows Vista Ultimate 64-bit Hanns-G 19'' LCD 1280x1024
Logitech Cordless Desktop EX110 Antec SP2 500W X-Ventilator Logitech Cordless Desktop EX110
Da Gallardo
post #8 of 17
ok the 9000pro is 128bit but it has 1 vertex shader rather than 2 on the 5200. so should i go with the 9000pro and also what drivers would be good for the 9000pro
My System
My System
post #9 of 17
I say the 5200 since you can flash it to a 5500, which will the 9000pro.
post #10 of 17
oh ya my 5200 is 64bit
My System
My System
  Back to Forum: NVIDIA
