Overclock.net › Forums › Case Mods & Cases › Builds & Case Mods › Build Logs › $1350 computer
$1350 computer
post #1 of 18
build me a computer that costs 1350+/-50 with triple rad watercoling full set
c2d 1.6ghz laptop laptop 8600 M GT 2GB DDR 667MGHZ
DELL 120gb Sata dell dvdrw windows xp 15.4" laptop
KeyboardCaseMouseMouse Pad
thermaltake set laptop thermaltake set everglide dual side thingy
post #2 of 18
I don't know much about water cooling... but I will give a shot at building a rig that leaves you money to spare fore the watercooling. You have any thoughts about a water cooling set?
E8400 @ 3.8 GHz DFI LANPARTY DK X38-T2R eVGA 8400GS 2GB Mushkin DDR2 800 (single stick)
250GB WD SATA None Windows XP Pro 32-bit HP Pavilion f1703
N/A Corsair HX520 Coolermaster Cavalier N/A
Mouse Pad
N/A
Mouse Pad
N/A
post #3 of 18
Morpheus Mini
(7 items)
i7-6700T SN970 GTX 960 Crucial CT102464BF160B
Hard DriveOSAudio
Samsung 850 Evo M.2 Windows 10 Pro MOTU Audio Express
Morpheus Mini
(7 items)
Hard DriveOSAudio
post #4 of 18
Dang you just beat me!
Well... what can I say? I had same CPU, same motherboard, same RAM, same Hard drive.. was just thinking about PSU.. LOL
In other words, excellent picks with which I totally agree!
Mouse Pad
N/A
Mouse Pad
N/A
post #5 of 18
Morpheus Mini
(7 items)
Hard DriveOSAudio
Morpheus Mini
(7 items)
Hard DriveOSAudio
post #6 of 18
I would recommend a Pentium D 925 (3.0Ghz 2x2Mb L2 800Mhz FSB dual core). They are only $178 dollars and will be released Monday. With watercooling, the will overclock to about 4.5Ghz without a sweat. The 925 has the C1 revision, meaning it uses less power and generates less heat, giving a even better overclock than the B1 revision. Tests on the 965 (C1 revision) show it running 10C cooler than the 955 (B1 revision) even though it is running at 340Mhz faster.
Pentium D 925- $178
ASUS P5WD2-E $220
eVGA Geforce 7900GT $319
Patriot eXtreme Performance 1GB DDR2-800 $115 (runs at 3-3-3-4 on stock voltages, best DDR2 timings)
Sunbeam NUUO 550W SLI $84
Western Digital Caviar SE16 250GB SATA 3.0 16mb Cache $90
Gigabyte 3D Aurora (Designed for watercooling) $140
Cooling:
Swiftech Apogee $45
Black Ice Xtreme III Triple 120mm Radiator $70
Swiftech MCP655 1200LPH $80
Swiftech MCRES-1000 - Bay Reservoir $19
ClearFLEX 60 Tubing 1/2" ID / 3/4" OD $10 $8.90
Swiftech RadBox MCB-120 Revision 2 $15
MASSCOOL FD12025S1L3/4 120mm x2 $4.99x2 =$10
Total: $1366 + Shipping
That is a pretty powerful CPU. You will be able to overclock to about 4.3-4.5Ghz on the processer, at 4.2Ghz a Pentium D matches a FX60....
System
Core i7 2500k ASRock P67 Extreme4 Gen 3 AMD 7970 16GB DDR3
Intel 520 256GB SATA DVD Burner Windows 7 64 bit Deal U2410
KeyboardPowerMouse
Adesso Mechanical Silverstone OP650 Logitech G700
System
KeyboardPowerMouse
post #7 of 18
Originally Posted by Chipp
lol, sorry Chozart.
No problem LOL . We're all here to help
I thought it was just funny we had the same exact main parts down to the detail (including the premium model of that MoBo).
When is that tax return coming through...grrr.. I want my new stuff!!!
Mouse Pad
N/A
Mouse Pad
N/A
post #8 of 18
post #9 of 18
I'd take the Sandy over the Opty at the moment. They're great overclockers, and I've heard the Opty's don't clock as well as they used to. However, the Opty is Dual core, and might be the better choice if you want to be future proof.. However, if you want dual core, the Intel suggestion is not a bad idea at all. Check prices next week... the drops are significant.
Also, the PSU you picked has 2 12V rails of 22A... but total combined only 32A on the 12V rails. This should be more than enough, but just to let you know not to expect 44A on the 12V rails.
The Antec TRUEPOWERII TPII-550 ATX12V 550W Power Supply has 2 12V rails of 19A each, but a total of 36A on the 12V rails.
http://www.newegg.com/Product/Produc...82E16817103931
All PSU (Enermax Liberty, Sunbeam NUUO, and the TPII) are solid choices, although the NUUO as a bit of low efficiency for my taste, resulting in higher power bills and heat dissipation.
For vid card, look at eVGA: they have a 90-day stepup program.
Mouse Pad
N/A
Mouse Pad
N/A
post #10 of 18
Pentium D 925 - $178 3.0GHz ??????????????????
are you sure ?
Piji
(16 items)
Intel Core i5 4460 Gigabyte H97-D3H EVGA GeForce GTX 960 SuperSC ACX 2.0+ Kingston HyperX Fury 1866MHz 16GB
Samsung 840 EVO 250GB WD Caviar Green 1TB Pioneer DVR-S21FXV Noctua NH-U12S
OSMonitorKeyboardPower
Windows 10 Pro x64 SAMSUNG P2270 Logitech K400 ENERMAX NAXN 450W
CaseMouseMouse PadAudio
ENERMAX Clipeus ECA3210A Logitech Performance MX GIGABYTE PreSonus FireBox
Piji
(16 items)
  Back to Forum: Build Logs
