Overclock.net › Forums › Cooling › Air Cooling › 478 temps
478 temps
post #1 of 14
i encouraged my friend to buy the TT BT instead of my beetle because i hear it is the best of the best, but the prob is that he hasnt seemed to have found that much of a difference in his temps maybe about 1-5 degree's this is a bit odd considering that my temps dropped quite a bit with my lga 775 p4 + TT beetle. "its beeter for you in the long run" is the only excuse i have until i find out why his temps aare like this. imo i think its the 478 chip? (correct me if im wrong)
so do 478 chips get hotter then 775's?
is the stock thermal paste to blame?
we installed it perfect all the scres are fitted in nice and secure and we double checked that.
Intel Core2 Quad E9400 Asus P5Q-EPU Gigabyte GTX 275 896MB 2x GSkill Trident DDR2 1066
Hard DriveOptical DriveOSPower
Seagate 1TB | WD 300GB Pioneer DVDRW Windows XP Pro SP3 Antec TP 750W
CaseMouse
Antec 300 Logitech MX510
CaseMouse
post #2 of 14
Where are you taking the temps from?
i5 2500k @ 4.5GHz 1.4v ASRock Z68 Extreme3 Gen3 MSI R9 290x Gaming 2x4GB Corsair XMS3 1600
Hard DriveHard DriveCoolingOS
Crucial BX100 250GB Toshiba 2TB Thermalright Macho 120 Rev.A Win 10 Sexy Phwoar bits
LG 29UM68 (2560x1080) Logitech MK600 SuperFlower GG HX 650W FD Define R4 White Window
MouseMouse PadAudioAudio
Logitech G502 CM SWIFT-RX XXL Cheap USB DAC Epiphany Acoustics EHP-O2
Audio
AKG K612 Pro
Audio
AKG K612 Pro
post #3 of 14
he has a gigabyte software which came with his mobo. the night after installing his temp were around 30-35 degree's as with his stock fan prior from uninstalling the Stock Hsf
CaseMouse
CaseMouse
post #4 of 14
Welll the 478 and 775 series of the later Cpus in 478's case both use 90NM technology so Heat output is roughly the Same un less you Friends CPU runs on 130 Nm and that would Explain the Extra heat. When it comes to thermal Comound it is always good to use a good one such as Arctic Silver 5 as its the best about.
post #5 of 14
yeah im planning on buying some as5 for myself and ill give him some to see if there are any differences in temps.
CaseMouse
CaseMouse
post #6 of 14
Sounds good Also make sure that the fan on the BT is going at its FULL speed if its plugged straight into the Motherboard then it should be but you may also wish to buy a better fan for cooling Especially if your FRiend has an older 478 Cpu such as a northwood which is 130Nm which will run a little hotter.
post #7 of 14
yeah i recomended him to change the bt fan which i made a seperat thread on a while ago. but ill jus use some as5 to see if that helps.
CaseMouse
CaseMouse
post #8 of 14
Well a better fan combined with AS5 i could see atleat an 8c drop in temps. after the AS5 has Cured.
post #9 of 14
More than likely it is installed slightly wrong with to much paste. Use very little. Also be sure the fan is blowing down on to the cooler. A higher cfm fan will help also.
Busa's Opti
intel E6700 P5W DH Deluxe Wifi BFG 7800gtx 2g pc6400 4-4-4-12
2x WD 74G raptors in raid0 NEC 3520 winXP sp2 Dell 24" widescreen LCD
Z board w/bf2 keyset Zeus 650sli+450 dual booting UFO Opti1203 blk/UV blue logitech G7
Mouse Pad
Xtrack "ripper"
Busa's Opti
Mouse Pad
Xtrack "ripper"
post #10 of 14
i was thinking of a fan around the range of 100cfm, led light for extra blingage and a fan control. he isnt concerned about the noise level (he plays techno loud and i mean loud thats why his old 5.1 speakers popped)
CaseMouse
CaseMouse
  Back to Forum: Air Cooling
