Overclock.net › Forums › Case Mods & Cases › Case Mod Work Logs › 379 Pete "Blade Transport"
379 Pete "Blade Transport" - Page 33
post #321 of 326
Originally Posted by the_beast View Post
Nice.
I'd forgotten all about this beauty til it popped up in my subs list after it's LONG break smile.gif
Got most of the tires cut but ran short on plastic sheet more here in the morning.
Here's a boring vid of the roughing cuts ,then will be finished on the lathe.
All 4 tandem axles cut and are ready to be drilled and tapped.
I have the front window frame cut and will finish the side ones in the morning.....pics incoming.
Intel i7 CPU 860 @ 3.80GHz GIGABYTE P55A-UD7 2x-ASUS ENGTX470 SLI G Skill 4gig
Vertex 2 60gig /Raptor 150 Asus DVD Lightscribe Win7 64 bit Pro Asus VW246 24", (2) Dell 20's
G-15 Cosair 850 watt Custom HAF-932 EXT G-9
Mouse Pad
Razor eXactMat
Mouse Pad
Razor eXactMat
post #322 of 326
Been Following this mod from day 1, its great to see some progress again biggrin.gif
AMD Phenom II x4 965 @ 4.1ghz Asus Crosshair IV Formula EVGA GTX580 1.5gb 8gb DDR3 1866mhz Corsair Vegeance
Hard DriveCoolingCoolingCooling
OCZ Vertex 3 80gb SSD x2 , 1tb Seagate Barracuda Ek Supreme HF, EK Full Cover Copper/Acetal GPU ... XSPC RX240 Rad, Ex360Rad W/ 10 Gentle Typhoon A... Bits-power Uber D5 Pump , Bits-power 250ml Tube...
OSMonitorKeyboardPower
Win7 Pro x64 Samsung 24" 2494sw Filco Majestouch 2 10keyless MX Red Corsair AX850
CaseMouseMouse PadAudio
CM HAF 932 Black/White Modded Razer Lychesis Steelseries Qck Medium Klipsch Pro-Media 2.1 / Audio-Technica A-700
Other
MDPC Sleeving
Other
MDPC Sleeving
post #323 of 326
Got the rest of the plastic for the tires today but mill was tied up with the grill.
Window grills almost done just need to do a relief cut the back sides. Grill started but looks like I will need to order longer mill bit to clear the clamps.
Mouse Pad
Razor eXactMat
Mouse Pad
Razor eXactMat
post #324 of 326
just read through the whole of this, this looks like an amazing mod, excited to see the rest biggrin.gif
post #325 of 326
Ok after what seems like a week of work I finally got all the tires finish,painted and mounted. Polished the rims also!
Turned the inside and outside then cut all the tread then rounded over then edges then sanded then painted!!
Got a bunch of aluminum ordered to keep the work flow going.
Here is what the "load" will look like on the trailer...this unit will house the PC hardware except the PSU that will be in the cab.
Mouse Pad
Razor eXactMat
Mouse Pad
Razor eXactMat
post #326 of 326
Originally Posted by allikat View Post
Looking great. Thank you for making a Pete. I'd have flamed you all to heck if you'd done a freightshaker or cornbinder lachen.gif
Will you have a couple buttons hidden away to make noises? Just don't bother putting in one with gear shift noises, no-one deserves to be driving this beauty if they don't know how to shift gears right biggrin.gif
Best wishes from a European trucker.
13 letter $H1T spreader? LOL...Another Trucker checkin in. Subbed. Very nice.
  Back to Forum: Case Mod Work Logs
