Overclock.net › Forums › Graphics Cards › NVIDIA › 7900gt
7900gt
post #1 of 13
im thinking about getting the eVGA 7900GT. Will it be able to do the same speeds as the 7900GT co? or are they different cards?
iCode
Intel Core i5 2500K ASUS P8Z68 Deluxe 2X EVGA DS GTX 580 Superclocked SLI CORSAIR Vengeance 8GB (2x4GB)
OCZ Vertex 3 MAX IOPS Edition ASUS DRW Win 7 Ultimate x64 HP ZR30w
Logitech Ultra-Thin Illuminated Keyboard COOLER MASTER Silent Pro Gold Series 1000W LIAN LI PC-B25FWB Black Logitech MX518
iCode
post #2 of 13
The 7900GT OC is a pre-factory overclocked G-card. In other words the overclock has been done for you to stable speeds so it will be a little better than a normal 7900gt.
post #3 of 13
You'll be able to get the CO speeds easily. The difference in negligible. The real power comes in when you vmod either of the cards and slap a VF900CU on it. Then you're running like 700 core, and 1850 memory....
Good luck.
Desktop
(15 items)
AMD FX 8120 Gigabyte XA990-UD3 Gigabyte GTX670 Windforce III G. Skill RipJaws
Crucial M4 Western Digital Blue LG Dual Layer Sata Antec Kuhler 920
OSMonitorKeyboardPower
Windows 8 Dell 2007wfp 20.1" Logitech G710+ Corsair Professional HX650
CaseMouseMouse Pad
Coolermaster Silencio Steelseries Sensei [RAW] Func F10.s
Desktop
(15 items)
CaseMouseMouse Pad
post #4 of 13
Good luck.
Yes the Volt mod gives you astonishing overclocks..Not so sure how easy it is to do but ill get a guide on it :
Here is one : http://www.vr-zone.com/print.php?i=3330
Here is review on the card : http://www.gdhardware.com/hardware/v...7900gt/001.htm
post #5 of 13
so i just gotta scribble some pencil on those really tiny things
iCode
iCode
post #6 of 13
I made a FAQ (still needs to be approved) as well that's only for the conductive ink mod....but it doesnt go into all the jargon of the other sites.
It's pretty straight forward and tells you exactly what you need.
$30 and a steady hand
Asus G1
2.0Ghz C2D T7200 Asus GeForce Go 7700 512MB 2GB (2x1GB) DDR2 667
Hard DriveOSMonitorCase
160GB MCE 2005 -> Vista 15.4" Wide SXGA Black Honeycomb
Mouse
Wireless Controller
Asus G1
Mouse
Wireless Controller
post #7 of 13
i thought CO just meant copper. but i guess that is what KO means.
cant complain..
3800 X2 Asus A8N5X EVGA 7600GT CO 2GB G.SKILL DDR400
2x80GB WDC TSST DVDRW + Samsung DVD XP Pro SP2 Samsung 17" 710n LCD
Not good... ASPIRE 520w 35@12V RAIDMAX SMILODON Razer Diamondback
Mouse Pad
BriteMat
cant complain..
Mouse Pad
BriteMat
post #8 of 13
It's really easy. I did it. Just some conductive paint on some little tiny thingers...and you're good to go.
Desktop
(15 items)
CaseMouseMouse Pad
Desktop
(15 items)
CaseMouseMouse Pad
post #9 of 13
The KO version was the highest clocked 7800GTX that had a special cooling aparatus on it....since the 7900GT's do not need much to cool it and the 7900GTX's use the behemith cooler they transfered the name to the GT line
The CO version is just as good, maybe clocked slightly less with a different cooler.
Asus G1
Mouse
Wireless Controller
Asus G1
Mouse
Wireless Controller
post #10 of 13
They just released a evga 7900gt ko. Its essentially the same as the 7900gt co, except the heatsink/fan covers the memory too. Their website also says a 7900gt ko superclocked will be available soon as well.
Heavy Armor
(19 items)
Intel i5 2500K @ 4.5GHz Gigabyte GA-Z68XP-UD4 Asus GTX 980 Strix 16GB G.Skill RipjawsX DDR3-1600
Hard DriveHard DriveCoolingOS
Sandisk Extreme SSD Samsung Spinpoint F3 (RAID 0) Under Water Windows 7 Ultimate (64-bit)
Catleap Q270 (2560x1440) Deck Legend "Fire" Corsair TX750W "Heavy" Armor (Thermaltake Armor Case Mod)
MouseMouse PadAudioAudio
Mionix Naos 7000 Mionix Sargas 400 Creative Titanium HD Sound Card AKG Q701 Headphones
AudioAudio
Schiit Vali Headphone Amp Zalman Clip-on Mic
Heavy Armor
(19 items)
AudioAudio
  Back to Forum: NVIDIA
