Overclock.net › Forums › AMD › AMD CPUs › 3000+ help
3000+ help
post #1 of 6
hey my dumb ass mobo donsnt support ocing so i figured clockgen would help... well its working and i have my 3000+ (s754) at "2065.62mhz" anything over that it locks up windows. whats wrong? the fsb is at 206.56. im a lil confused... am i running at 2.6ghz or like 2.06 ghz? how can i get a better oc? thanks guys.
My System
AMD athlon 3000+ vinice tul somthin or other... 6600gt 625mhz 1.3ghz mixed genaric
Hard DriveOSMonitorKeyboard
200gig maxtor windows (monopoly) 17" sony lcd one i found layin around
PowerCaseMouse
aspire 520w raidmax logitech media play
My System
PowerCaseMouse
post #2 of 6
The problem is that you are not able (through Clockgen or BIOS) to lock your PCI/AGP bus and you will not get stable on any decent overclock without this lock. All decent overclocking boards have this feature.
R
Roped In
Core i7 2600k P8P67 Pro Rev (3.1) @ B3 XFX Radeon HD 6950 XXX 16GB G.SKILL Ripjaws 9-11-9-28
2 X Callisto Deluxe 25nm 60GB Plextor PX-B910SA 4x Blu-ray DVD-RW Win7 64 2 x Samsung 275T+
Logitech G15 Corsair HX10000 Antec 1200 Logitech G7
Mouse Pad
Splatter Game Pad
Roped In
Mouse Pad
Splatter Game Pad
post #3 of 6
yea hey im in safe mode now cuz windows locked up cuz my pci bus was too high im guessing... any suggestions? im cant log on in reg mode it locks up. i cant open clockgen in safe either.... hmmm in a bit of a pickle. anything would help.
My System
PowerCaseMouse
My System
PowerCaseMouse
post #4 of 6
still hangin here about to scream! i would really like to use my computer out of safe mode... anyone know how to disable clockgen or get my comp back on track...? (sitting pressing f5)
My System
PowerCaseMouse
My System
PowerCaseMouse
post #5 of 6
Clockgen should not have saved your settings, but try this: Try shuting down your computer then unplugging it, then on your board reset the CMOS. This should reset all your settings to default and reset your PCI back to 33.
BlackMesa
(14 items)
Phenom II x6 Gigabyte XFX RF460 16gb G.Skill
Hard DriveHard DriveOSMonitor
OCZ Vertex2 Sata II Coorsair Force GS Sata III Debian (testing) Shimian 27"
KeyboardMouse
Filco w/ blue cherries Who needs a mouse?
BlackMesa
(14 items)
KeyboardMouse
post #6 of 6
Since you can not lock your PCI bus there is a good possibility that you have corrupted data and need to perform a "Repair" of your Windows installation.
Are you running Windows XP? If so, here is how to perform the "Repair". You will not lose your programs, personal data or settings with a "Repair".
Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
Reboot your computer with the Windows XP CD in the CD drive.
The following message will appear on a black screen with white letters:
Press any key to boot from the CD.
Press the <Spacebar> to boot to the Windows XP CD.
After several moments of initializing some modules, the Windows XP Setup screen will appear.
When you see the "Welcome To Setup" screen, you will see the options below:
This portion of the Setup program prepares Microsoft Windows XP to run on your computer --> To setup Windows XP now, press ENTER --> To repair a Windows XP installation using Recovery Console, press R.
Do NOT press R
To quit Setup without installing Windows XP, press F3 and Press Enter to start the Windows Setup.
Press Enter
The Windows XP Licensing Agreement will appear --> Press the <F8> key to agree.
Setup will search for previous versions of Windows and find your previous installation that you wish to repair.
The prompt will be:
If one of the following Windows XP installations is damaged, Setup can try to repair it.
Use the UP and DOWN ARROW keys to select an installation.
To repair the selected Windows XP installation, press R.
Press "R"
To continue installing a fresh copy of Windows XP without repairing, press ESC.
DO NOT PRESS ESC. Allow the installation to continue and repair your system.
R
Roped In
Mouse Pad
Splatter Game Pad
Roped In
Mouse Pad
Splatter Game Pad
  Back to Forum: AMD CPUs
