Overclock.net › Forums › Components › Memory › 2240MHz Mushkin Ridgeback RAM W/ Phenom II X6 1090T & 890FXA-UD5
2240MHz Mushkin Ridgeback RAM W/ Phenom II X6 1090T & 890FXA-UD5 - Page 2
post #11 of 18
Great to hear my quest inspired others!
It made me want some Ln2
I know it's super hard to push memory on AMD, compared to Intel, especially the tighter timings, so you are doing a great job!
Ya, Chew will be hard to tackle on AMD, good luck though if you go for it!!
Intel i7 980X EE ES Gigabyte GA-X58A-UD7 GIGABYTE GV-R587SO-1GD SOC 1GB GDDR5 Mushkin 998826 Ridgeback / 998966 Radioactive
OSMonitorPower
Vista Business x64 SP2 Asus Designo MS238H 23" LED NZXT HALE90 750W 80+ GOLD
OSMonitorPower
post #12 of 18
Originally Posted by Slappa View Post
2000MHz is ...[o]nly possible on thuban, not deneb.
Absolutely possible, even with Mushkin modules. At least in single-channel (testing dual-channel now)...
Edited by adamlau - 12/11/10 at 12:37am
ThermoChilled
Phenom II X6 1100T ASUS Crosshair IV Extreme EVGA GTX 580 SuperClocked STT WX200UB2G7
VelociRaptor WD6000HLHX Sony Optiarc AD-7260S Arch Linux x86_64 + JWM NEC MultiSync PA241W-BK
Topre Realforce 87UKB Corsair CMPSU-850AX Lian Li Tyr PC-X500FX Logitech G9x
Mouse Pad
ZOWIE GEAR P-TF
ThermoChilled
Mouse Pad
ZOWIE GEAR P-TF
post #13 of 18
Wow, great job Slappa!
post #14 of 18
Well, 8-10-6 is a bit radical; going by the rules of timings (i.e. 7-9-7 ~= 8-8-8) it should be about equal to 9-9-9, still a fairly good result.
post #15 of 18
970 X4 = new IMC revision...i'm talking 955, 965. they wouldnt budge past 1800MHz
you also are using single channel
are you ganged or unganged?
Edited by Slappa - 12/11/10 at 2:58am
ISS
(17 items)
Voyager-1
(8 items)
Apollo
(15 items)
Core i5 2500K Quad Core Asus P8P67 Rev 3.1 Radeon HD 7950 12GB Kingston HyperX 1600MHz
Crucial MX300 500GB 500GB Seagate 7200.12 1TB WD Blue LG SuperMulti Combo Drive
CoolingOSMonitorKeyboard
Thermalright Venomous X-RT Windows 10 Pro x64 Samsung SyncMaster S24B300 23.6" 1080P CoolerMaster QuickFire XT Mechanical
PowerCaseMouseMouse Pad
PCP&C 750W Silencer Zalman Z9 Razer Deathadder SteelSeries
A10-6800K Gigabyte F2A85XN-WiFi ITX AMD HD Radeon 8670D 8GB AMD Performance Series
Hard DriveOSPowerCase
1TB WD Blue Windows 8 Pro x64 Seasonic 380 Watt CoolerMaster Elite 120 Advanced
A6-3400m Llano APU 1.4GHz-3.4Ghz HP A60M UMA Socket FS1 6520G 6GB 1333MHz 9-9-9-24
Hard DriveCoolingOSCase
64GB OCZ Vertex 4 Stock ARCH HP g6
Audio
IDT
ISS
(17 items)
Voyager-1
(8 items)
Apollo
(15 items)
Audio
IDT
post #16 of 18
You mentioned Deneb . Unganged. But that was with a Mushkin module. I have hit suicide runs of 2006 MHz several times on the STT sticks (4 x 2GB).
Voltage isn't as important when clocking the newer DDR3.
With both the Mushkin 996902 and STT sticks used within the confines of my setup, voltage has been a key factor in being able to hold a stable memory overclock. For example, the 996902 modules will not hold 5-8-5-18-23 1T without at least 1.725v.
ThermoChilled
Mouse Pad
ZOWIE GEAR P-TF
ThermoChilled
Mouse Pad
ZOWIE GEAR P-TF
post #17 of 18
Really? What do you mean, is it a C4 revision or a variant of the E0 revision?
post #18 of 18
Well I used deneb and overclocked ram with it long before there was ever a 970 X4. Theres still tonnes of users that have the 955 and 965, my apologies.
With every model they change the IMC, which changes how the ram can be overclocked. The 970 X4 is obviously the most recent deneb IMC revision. The highest binned cores combined with an IMC that was either improved or slacked off a few timings in order to support 1800MHz+
Most PSC chips, voltage only comes into play when passing a certain clockspeed. I can run all the way up to 2240MHz like I did in the OP, with no voltage increases. The only reason I had the voltage increased was to see if it could provide me with more headroom. All sticks are different, some like more than others. But PSC should not be run above 1.75V on air as it won't gain much benefit and will just add heat to the ram. It will also degrade or kill your ram after awhile above that voltage.
Nah the whole chip isn't a new rev. Just the IMC.
It's still a highly binned Deneb C3 , with an IMC that has been slacked off to allow for higher memory SPD support.
Edited by Slappa - 12/11/10 at 11:00am
ISS
(17 items)
Voyager-1
(8 items)
Apollo
(15 items)
Audio
IDT
ISS
(17 items)
Voyager-1
(8 items)
Apollo
(15 items)
Audio
IDT
  Back to Forum: Memory
